alexandrecf80
| Help on CDC serial emulator and PIC18F46J50 |
Posted: Tue May 04, 2010 8:14 am |
I need an example code for CDC serial emulator on PIC18F46J50.
My code works great on PIC18F4550, but the device is not recognized when I compile for PIC18F46J50.
#include <18F4550.h>
//configure a 8MHz crystal to operate at 48MHz
#fuses PLL2,CPUDIV1,USBDIV,HSPLL,NOFCMEN,NOIESO,BROWNOUT,BORV20,VREGEN,NOWDT,WDT32768,MCLR,NOLPT1OSC,NOPBADEN,CCP2C1,STVREN,NOPROTECT,NOCPB,NOCPD,NOWRT,NOWRTC,WRTB,NOWRTD
#use delay(clock=48000000)
#include <usb_cdc.h>
int8 data,i=0;
unsigned long int a;
usb_cdc_init();
usb_init();
a=0;
while(!usb_cdc_connected())
do
usb_task();
output_low(PIN_D0);
output_high(PIN_D0);
if (usb_enumerated())
if(usb_cdc_kbhit())
data = usb_cdc_getc();
output_low(PIN_D0);
if(data == 0x00)
usb_cdc_putc(0x00);
usb_cdc_putc(0xFF);
delay_ms(50);
} while (TRUE);
Thanks,
Alexandre |
