CCS Embedded WEB with PIC 18F4620
Rodrigo Rios A de Souza
View user's profile Send private message Send e-mail MSN Messenger ICQ Number
PostPosted: Fri Apr 30, 2010 1:05 am     Reply with quote
Hi guys,
I'm having some problems with pages using User program memory.
I'm currently running very well all web sites that don't contain any image file.
If I put some file like 10kb or more, the CCS compiler gives the follow error:
Out of ROM. A Segment or the program is too Large
Any ideas????
Bye,
Rodrigo Rios
bkamen
PostPosted: Fri Apr 30, 2010 10:13 am     Reply with quote
Yep!
The Image is too big and is filling up your memory space!
There's only so much flash ya know.
If you need images, consider moving the web pages to an external flash IC which then can be loaded up with an MPFS image.
I just did a project with an SST flash that was 2MB in size (16Mb) -- it was very nice and plenty of room for stuff.
Also keep in mind, this isn't going to work well holding uncompressed BMP's.
Make sure your images are only as large as they need to be!
-Ben
Dazed and confused? I don't think so. Just "plain lost" will do. :D
Embedded WEB
PostPosted: Sat May 01, 2010 9:48 am     Reply with quote
Thks for the reply,
I am using MPFS for eeprom now but i can use FAT16 or EEPROM, it depends on which one i choose on the webserver example that comes with the Embedded WEB developer KIT .
I think i will buy a Flash IC card. But i don“t have any ideas about the size and other specs. Which one do you recommend? about the size can it be 1GB or less????
All this stuff is related to my final project in computer Engineering.
I am quite new to micontrollers... only have 6 months of experience.
I have to hurry up.
Thks a lot, regards,
Rodrigo RIos
