BITWISE & not working...
uslimey
PostPosted: Tue Jan 16, 2018 6:57 pm     Reply with quote
I am trying to do a bitwise AND on two uInt16 numbers.
unsigned int16 A = 0b0001000000000000;
unsigned int16 B = 0b0001010101010101;
A &= B; // the result (A) should be 0b0001000000000000, instead the result is 0???
This makes no sense... Try it again...
unsigned int16 C = A & B; // the result (C) should be 0b0001000000000000, instead the result is 0???
This is with a PIC16F722A and version 5.075 of the compiler...
Any suggestions?
PostPosted: Tue Jan 16, 2018 7:24 pm     Reply with quote
The first test gives 0x1000, which is accurate:
A = 1000
First test program:
#include <16F722A.h>
#fuses INTRC_IO, NOWDT
#use delay(clock=4M)
A &= B;
printf("A = %lx \r", A);
while(TRUE);
The 2nd test also gives 0x1000, which is accurate.
A = 1000
So I think you may have a problem with your binary display routine.
These tests were both done in MPLAB v8.92 simulator with CCS v5.075.
2nd test program.
printf("C = %lx \r", C);
while(TRUE);
