		| Author | Message |
		| a3ka2000
				| dsPIC30F6014A restart? |
				|  Posted: Wed Mar 17, 2010 12:27 am |   |
				| Hi, I have a problem with dsPIC30F6014A used for TCP/IP communication with ENC28J60.
 I'm implementing the code based on CCS Ethernet Development Tutorial, ex-7b. The board seems to restart by itself when coming to access this following struct:
  	  | Code: |  	  | __mac_tx_buffers[NICCurrentTxBuffer].len=len; |
 The declaration for that struct is as follows:
  	  | Code: |  	  | struct { int8 isReserved;
 int8 isActive;
 int8 isFlushing;
 int16 len;
 } __mac_tx_buffers[MAC_TX_BUFFER_COUNT];
 How do I know it was restarting is because it keeps going back to the start without executing the remaining portion after the abovementioned part. This is funny because when I used MPLAB debug mode to animate the code, the process ran smoothly.
 Is there anyway I can prevent restart? I already disabled watchdog (NOWDT) by using #fuses.
 thank you very much
 best wishes
		| FvM
				|  Posted: Wed Mar 17, 2010 12:52 am |   |
				| You may want to check the restart cause by reading the RCON register.
 Generally, address error trap and stack overflow trap are popular reset causes with PIC24/dsPIC. See the respective forum discussion.
		| a3ka2000
				|  Posted: Wed Mar 17, 2010 1:24 am |   |
				|  	  | FvM wrote: |  	  | You may want to check the restart cause by reading the RCON register.
 Hi, thanks for the suggestion. Let me try to take a look. Most prob it's not caused by voltage drop, unregulated PSU, or watchdog timer.
 If I replace NICCurrentTxBuffer with a fixed number, say, '0', the the program runs okay without reset occuring (but still incorrect TCP/IP response).
 best rgds
