		| Author | Message |
		| vietlongIPD
				| help- impulse noise encoder - pic 18f4331 - use int ext |
				|  Posted: Tue Mar 16, 2010 8:50 am |   |
				| Hi everybody
 I have a strange problem. I control my motor (servo with encoder 200 slot - 2 sign A B) with module ccp1 and I use int_ext1 (PIN_C4) to receive signA of encoder. But if I don't connect supply power for motor (one pole connect with +12v, other pwm1 = ccp1) program recognize correct number of pulse encoder and if have motor run program is wrong, same have noise. PIC auto count pulse and perform program although I don't rotate encoder (I take apart the motor & encoder).
 Here is my circuit, assured that there is no virus  ( orcad 10.5)
   http://www.mediafire.com/?mjmjm5w3myv
 My program
  	  | Code: |  	  | #include <18f4331.h>
 #FUSES HS //High speed Osc (> 4mhz)
 #FUSES PUT //Power Up Timer
 #FUSES NOLVP //Low Voltage Programming on B3(PIC16) or B5(PIC18)
 #FUSES NOWDT
 #use fast_io(b)
 #use fast_io(c)
 #use fast_io(a)
 #use fast_io(d)
 #use fast_io(e)
 int1 flag_ngat1=0,flag_ngat2=0,ngat1=0,ngat2=0;
 int16 signA,signB,en_t,en_p;
 int8 en;
 #int_ext1 //count encoder left
 void ngat_int1()
 disable_interrupts(int_ext1);
 signA++;
 if ((signA >= en_t)&&(flag_ngat1 == 0))
 ngat1 = 1;
 flag_ngat1 = 1;
 signA = 0;
 enable_interrupts(int_ext1) ;
 #int_ext2 //count encoder right
 void ngat_int2()
 disable_interrupts(int_ext2);
 signB ++;
 if ((signB >= en_p)&&(flag_ngat2 == 0))
 ngat2 = 1;
 flag_ngat2 = 1;
 signB = 0;
 enable_interrupts(int_ext2) ;
 void main(){
 set_tris_A(0xB1); // pin A7 -> pin A0 1011 0001
 set_tris_B(0xC0); // pin B7 -> pin B0 1100 0000
 set_tris_C(0x39); // pin C7 -> pin C0 0011 1001
 set_tris_D(0x03); // pin D7 -> pin D0 0000 0011
 set_tris_E(111);
 setup_ccp1(CCP_PWM);
 setup_ccp2(CCP_PWM);
 setup_timer_0( RTCC_INTERNAL| RTCC_DIV_256 | RTCC_8_BIT);
 setup_timer_2(T2_DIV_BY_16, 255, 1);
 /* setup_power_pwm_pins(PWM_BOTH_ON,PWM_BOTH_ON,PWM_O FF,PWM_OFF);
 setup_power_pwm(PWM_CLOCK_DIV_128|PWM_FREE_RUN,
 1, //postscale, not used
 0, //initial PTMR
 63, //**************PTPER9 //
 0, //compare special event, not used
 1, //postscale compare special event, not used
 0); //dead_time
 set_power_pwm_override(1, false, 0);
 set_power_pwm_override(3, false, 0);
 set_power_pwm_override(5, false, 0);
 set_power_pwm_override(7, false, 0);*/ // use mode PWM cua 18f4331
 enable_interrupts(int_ext1);
 enable_interrupts(int_ext2);
 ext_int_edge(1, L_TO_H );
 ext_int_edge(2, L_TO_H );
 output_high(PIN_B0);
 output_high(PIN_B1);
 output_high(PIN_B2);
 output_high(PIN_B3);
 output_high(PIN_B4);
 output_high(PIN_B5);
 output_high(PIN_D2);
 output_high(PIN_D3);
 output_high(PIN_D4);
 output_high(PIN_D5);
 output_high(PIN_D6);
 output_high(PIN_D7);
 output_high(PIN_C6);
 output_high(PIN_C7);
 set_pwm1_duty(255); //high V on  CCP1
 set_pwm2_duty(255); //high V on  CCP2
 signA=0
 while(true){
 if(signA>100) output_low(PIN_B0); //if encoder rotate 1 round then indicator light of Pin B0 lighted
 if(signA>200) output_low(PIN_B1); //if encoder rotate 2 round then indicator light of Pin B2 lighted
 if(signA>300) output_low(PIN_B2); //if encoder rotate 3 round then indicator light of Pin B0 lighted
 if(signA>400) output_low(PIN_B3); //if encoder rotate 4 round then indicator light of Pin B0 lighted
 if(signA>500) output_low(PIN_B4); //if encoder rotate 5 round then indicator light of Pin B0 lighted
 This is simple program for test encoder but as I said, if I connect motor with CCP1 and run it -> my program auto light lamp although I don't rotate encoder. I don't know why (of course pin 17 ccp1 connect - octo - uln2803 - bjtb562 // d468 - mosfet irf540 - 1pole of motor) .
 My friend advise me to use module QEi for filter noise but I don't know how to config module QEI - somebody can help me -  I  fabricate one robot and I need use encoder --> for control the motor and calculate distance of the robot correctly.
 Sorry for my English level is not very good, but I hope that you can understand a little piece and help me.
 Best regards.
		| PCM programmer
				|  Posted: Tue Mar 16, 2010 4:15 pm |   |
				|  	  | Quote: |  	  | PIC auto count pulse and perform program although I don't rotate encoder
 Does the encoder have open-collector outputs ?   (or open-drain)
 If it does, then the PIC interrupt pins will be "floating" inputs.
 This means an interrupt could be triggered by noise at any time.
 To fix this, you need to use pull-up resistors on the INT0 and INT1 pins
 on the PIC.  You can use 4.7K ohms.   This will hold the INT0 and INT1
 pins at a logic '1' level, and prevent interrupts due to noise.
  	  | Quote: |  	  | set_tris_A(0xB1); // pin A7 -> pin A0 1011 0001
 set_tris_E(111);
 Also, the '111' value is probably not intended. You probably mean 0b111
 or 0x07.
 | You cannot post new topics in this forum You cannot reply to topics in this forum
