		| Author | Message |
		| mindstorm88
				| Faster simulated port ?? |
				|  Posted: Mon Mar 15, 2010 10:21 am |   |
				| Hi guys , just fooling around a bit , and would like to know if there a faster way to do it ?  I'm using a macro to create an 8 bit port, but to transfer data to that port takes 96.5 uSec. Any faster way ??
  	  | Code: |  	  | #include <16F684.h>
 //#device adc=10
 #fuses NOWDT,INTRC_IO,BROWNOUT,NOMCLR
 #use delay(clock=8000000)
 const unsigned char sine_table[256] = {127,130,133,136,139,
 143,146,149,152,155,158,161,164,167,
 170,173,176,178,181,184,187,190,192,195,198,200,203,205,
 208,210,212,215,217,219,221,223,225,227,229,231,233,234,
 236,238,239,240,242,243,244,245,247,248,249,249,250,251,
 252,252,253,253,253,254,254,254,254,254,254,254,253,253,
 253,252,252,251,250,249,249,248,247,245,244,243,242,240,
 239,238,236,234,233,231,229,227,225,223,221,219,217,215,
 212,210,208,205,203,200,198,195,192,190,187,184,181,178,
 176,173,170,167,164,161,158,155,152,149,146,143,139,136,
 133,130,127,124,121,118,115,111,108,105,102,99,96,93,90,
 87,84,81,78,76,73,70,67,64,62,59,56,54,51,49,46,44,42,39,
 37,35,33,31,29,27,25,23,21,20,18,16,15,14,12,11,10,9,7,6,
 5,5,4,3,2,2,1,1,1,0,0,0,0,0,0,0,1,1,1,2,2,3,4,5,5,6,7,9,10,
 11,12,14,15,16,18,20,21,23,25,27,29,31,33,35,37,39,42,44,
 46,49,51,54,56,59,62,64,67,70,73,76,78,81,84,87,90,93,96,
 99,102,105,108,111,115,118,121,124};
 // spare pins
 #bit RC0 = 7.0
 #bit RC1 = 7.1
 #bit RC2 = 7.2
 #bit RC3 = 7.3
 #bit RC4 = 7.4
 #bit RC5 = 7.5
 #bit RA1 = 5.1
 #bit RA2 = 5.2
 // MACRO
 // DAC_PORT from spare pins
 #define DAC_PORT(x)\
 RA1 = x & 1;\
 RA2 = (x>>1)& 1;\
 RC0 = (x>>2)& 1;\
 RC1 = (x>>3)& 1;\
 RC2 = (x>>4)& 1;\
 RC3 = (x>>5)& 1;\
 RC4 = (x>>6)& 1;\
 RC5 = (x>>7)& 1;\
 BYTE sine_index;
 // main
 set_tris_c(0b00000000);
 set_tris_a(0b00000000);
 sine_index=0;
 DAC_PORT(sine_table[sine_index]);   // takes 96.5 usec
 if(++sine_index==256)
 sine_index=0;
 If you have a better subject name for this topic lmk !!!
		| dezso
				|  Posted: Mon Mar 15, 2010 11:54 am |   |
				| I'm not expert in CCS You should try to use a bigger pic, where you have a full 8 bit port.
 Check your disassembly list, I'm sure the port translation take a few cycle. I find C is best for complex programs, ASM for speed and code space saving.
 Try to write a segment in ASM and optimize it.
 This 18F code in ASM will change the port in .600 us if you run 40Mhz or 1.2 us at 20 Mhz and 3 us at 8 Mhz
  	  | Code: |  	  | ;****************************************************************************** ;Start of main program
 Main:   ;********************
 banksel   trisb
 movlw   0x00
 movwf   trisb
 banksel   portb
 clrf   portb
 movlw   high(sin_table)
 movwf   tblptrh
 movlw   low(sin_table)
 movwf   tblptrl
 send_sin:
 tblrd*+                  * 0.00 us
 movf   tablat,w
 movwf  portb
 goto   send_sin          * 0.400 us + 200 ns to return
 sin_table:
 db .27,.130,.133,.136,.139
 db .143,.146,.149,.152,.155,.158,.161,.164,.167
 db .170,.173,.176,.178,.181,.184,.187,.190,.192,.195,.198,.200,.203,.205
 db .208,.210,.212,.215,.217,.219,.221,.223,.225,.227,.229,.231,.233,.234
 db .236,.238,.239,.240,.242,.243,.244,.245,.247,.248,.249,.249,.250,.251
 db .252,.252,.253,.253,.253,.254,.254,.254,.254,.254,.254,.254,.253,.253
 db .253,.252,.252,.251,.250,.249,.249,.248,.247,.245,.244,.243,.242,.240
 db .239,.238,.236,.234,.233,.231,.229,.227,.225,.223,.221,.219,.217,.215
 db .212,.210,.208,.205,.203,.200,.198,.195,.192,.190,.187,.184,.181,.178
 db .176,.173,.170,.167,.164,.161,.158,.155,.152,.149,.146,.143,.139,.136
 db .133,.130,.127,.124,.121,.118,.115,.111,.108,.105,.102,.99,.96,.93,.90
 db .87,.84,.81,.78,.76,.73,.70,.67,.64,.62,.59,.56,.54,.51,.49,.46,.44,.42,.39
 db .37,.35,.33,.31,.29,.27,.25,.23,.21,.20,.18,.16,.15,.14,.12,.11,.10,.9,.7,.6
 db .5,.5,.4,.3,.2,.2,.1,.1,.1,.0,.0,.0,.0,.0,.0,.0,.1,.1,.1,.2,.2,.3,.4,.5,.5,.6,.7,.9,.10
 db .11,.12,.14,.15,.16,.18,.20,.21,.23,.25,.27,.29,.31,.33,.35,.37,.39,.42,.44
 db .46,.49,.51,.54,.56,.59,.62,.64,.67,.70,.73,.76,.78,.81,.84,.87,.90,.93,.96
 db .99,.102,.105,.108,.111,.115,.118,.121,.124
 END
		| mindstorm88
				|  Posted: Mon Mar 15, 2010 1:21 pm |   |
				|  	  | dezso wrote: |  	  | You should try to use a bigger pic, where you have a full 8 bit port.
 I agree %100 with you
  , but just want to know if there a way to improve with this pic !!  |  |
		| PCM programmer
				|  Posted: Mon Mar 15, 2010 1:35 pm |   |
				| Use #fast_io to get rid of the TRIS in the ASM code.  This reduces the instruction count.  You can see this by looking at the .LST file.
 Then notice that most of your bits are in PortC.  So use output_c()to do
 them all at once.  Do the two remaining bits with output_bit(). Example:
  	  | Code: |  	  | #use fast_io(A)
 #use fast_io(C)
 int8 temp;
 sine_index=0;
 temp = sine_table[sine_index];
 output_c(temp >> 2);  // Bits 7-2
 output_bit(PIN_A2, bit_test(temp, 1));  // Bit 1
 output_bit(PIN_A1, bit_test(temp, 0));  // Bit 0
 The .LST file shows the result:
  	  | Code: |  	  | ....................     output_c(temp >> 2);  // Bits 7-2
 0125:  RRF    25,W
 0126:  MOVWF  26
 0127:  RRF    26,F
 0128:  MOVLW  3F
 0129:  ANDWF  26,F
 012A:  MOVF   26,W
 012B:  MOVWF  07
 ....................     output_bit(PIN_A2, bit_test(temp, 1));  // Bit 1
 012C:  BTFSC  25.1
 012D:  GOTO   130
 012E:  BCF    05.2
 012F:  GOTO   131
 0130:  BSF    05.2
 ....................     output_bit(PIN_A1, bit_test(temp, 0));  // Bit 0
 0131:  BTFSC  25.0
 0132:  GOTO   135
 0133:  BCF    05.1
 0134:  GOTO   136
 0135:  BSF    05.1
		| John P
				|  Posted: Mon Mar 15, 2010 1:48 pm |   |
				| You could save a little time by setting the two pins in port A like this:
  	  | Code: |  	  | output_bit(PIN_A2, 0);
 if (bit_test(temp, 1))
 output_bit(PIN_A2, 1);
 That's if it's OK to set them low, then high again whenever a 1 gets sent out.
 But really, the best thing would be to put all 8 outputs on the same port. It would be faster, and all the bits would change at one time.
		| dezso
				|  Posted: Mon Mar 15, 2010 8:01 pm |   |
				| I was just thinking, the write to the designated port will occur in 2 or more write cycle, your sine wave will be very choppy since the portc update before porta or vice verse. Like .233 will output to 0b11101001, portc 0b111010 will set your R2R to a specific voltage than in a few us later porta add 0b01 to the final voltage.
		| mindstorm88
				|  Posted: Tue Mar 16, 2010 4:58 am |   |
				| PCM way reduce from 96 uSec to 18 uSec  , this give a very crude wave that could be cleaned by a good filter !!! Thanks guys all this is a very good learning experience !!! |  |
 | You cannot post new topics in this forum You cannot reply to topics in this forum
