problem of 4x4 keypad
project2010
PostPosted: Sun Mar 14, 2010 3:50 am     Reply with quote
I have built a 4x4 keypad code, using port B0-7 col1=pin_b0.
Anyone can tell me what's the problem? It doesn't work....
#include <18F4620.h>
#fuses HS,NOWDT,NOPROTECT,NOLVP,NODEBUG
#use delay(clock = 20000000)
#include <LCD16x2.c>
#byte   TRISB= 0xF95
#byte   PORTB = 0xF83      //move the port d into address 0xF83
#bit   row1 = PORTB.4      //set the row connector to port d bits
#bit   row2 = PORTB.5
#bit   row3 = PORTB.6
#bit   row4 = PORTB.7
int8 key_scan(void);
int8 keypad();
int8 key_scan(void)
int8 key_array[17]={1,4,7,12,2,5,8,0,3,6,9,14,10,13,11,15,16}; //set the pattern of keypad
   int8 i,key_no=0,temp = 0xFE;
   TRISB= 0xF0;            //set rows connector to high on software
   for (i=0;i<4;i++)         //loop four times to check buttons
      PORTB = temp;
      if (row1) key_no++; else goto keyexit;
      if (row2) key_no++; else goto keyexit;
      if (row3) key_no++; else goto keyexit;
      if (row4) key_no++; else goto keyexit;
      temp*=2;
      temp++;
keyexit:
   return key_array[key_no];      //export a number
int8 keypad()
  int8 key;
   key=key_scan();
if (key==0) printf(lcd_putc,"Y");
if (key==1) printf(lcd_putc,"1");
if (key==2) printf(lcd_putc,"4");
if (key==3) printf(lcd_putc,"7");
if (key==4) printf(lcd_putc,"2");
if (key==5) printf(lcd_putc,"5");
if (key==6) printf(lcd_putc,"8");
if (key==7) printf(lcd_putc,"3");
if (key==8) printf(lcd_putc,"6");
if (key==9) printf(lcd_putc,"9");
if (key==10) printf(lcd_putc,"N");
if (key==11) printf(lcd_putc,"C");
if (key==12) printf(lcd_putc,".");
if (key==13) printf(lcd_putc,"0");
if (key==14) printf(lcd_putc,"/");
if (key==15) printf(lcd_putc,"D");
   delay_ms(50);
   while (key_scan()!=16);         //wait for leave pressing
   delay_ms(50);
   return key;
  int8 key;
   setup_psp (PSP_DISABLED);
   printf(lcd_putc,"Biometric attendance");
   printf(lcd_putc,"Welcome!!");
   printf(lcd_putc,"1.123456\n");
   printf(lcd_putc,"2.abc");
   delay_ms(50);
   while(true)
   key=key_scan();
   if (key == 1)
      { printf(lcd_putc,"xxxx");
        delay_ms(50);
        delay_ms(50);
   if (key == 2)
      { printf(lcd_putc,"yyyy");
        delay_ms(50);
        delay_ms(50);
   { printf(lcd_putc,"99999");}
my sch., always high??
FvM
PostPosted: Sun Mar 14, 2010 5:50 am     Reply with quote
How do you determine, that particularly the keypad is "not working"? All debug output goes to the LCD.
Is it a real circuit or a simulation?
Where did you connect the LCD?
PostPosted: Sun Mar 14, 2010 3:43 pm     Reply with quote
Try using the Flex 4x4 keypad driver:
http://www.ccsinfo.com/forum/viewtopic.php?t=28022&start=14
PostPosted: Sun Mar 14, 2010 3:51 pm     Reply with quote
Though I agreee 'use the existing driver', The reason it doesn't work, is the maths of 'temp'.
You want this to pull each line low in turn.
Ignoring the top nibble, you have 1110 in it at the first loop. At the end of this loop, you multiply it by 2 -> 1101, then increment it -> 1110. Er.....
You only need to multiply it by two to move the '0' left.
