PIC16LF1937
Piccolo
PIC16LF1937
PostPosted: Fri Feb 05, 2010 8:44 am     Reply with quote
Using PCWH 4.103
Here's my FUSEs:
#include <16LF1937.h>
#device *=16
#FUSES NOWDT                   //No Watch Dog Timer
#FUSES INTRC_IO                //Internal RC Osc, no CLKOUT
#FUSES NOPUT                   //No Power Up Timer
#FUSES NOPROTECT               //Code not protected from reading
#FUSES NOMCLR                  //Master Clear pin used for I/O
#FUSES NOCPD                   //No EE protection
#FUSES BROWNOUT                //Reset when brownout detected
#FUSES NOIESO                  //Internal External Switch Over mode disabled
#FUSES NOFCMEN                 //Fail-safe clock monitor disabled
#FUSES NODEBUG                 //No Debug mode for ICD
#use delay(clock=125000)
#use rs232(baud=2604,parity=N,xmit=PIN_C6,rcv=PIN_C7, bits=8)
Here's the SETUP:
 setup_wdt(WDT_OFF);
  setup_adc(ADC_OFF);
  setup_adc_ports(NO_ANALOGS);
  setup_spi(FALSE);
  //setup_lcd(LCD_MUX13|LCD_STOP_ON_SLEEP,1); //used on TM99A-EX
  setup_lcd(LCD_MUX13|LCD_LFINTOSC|LCD_VOLTAGE3|LCD_VOLTAGE2|LCD_VOLTAGE1,0);
  setup_timer_0(RTCC_INTERNAL|RTCC_DIV_64);
  setup_timer_1(T1_DISABLED);
  setup_timer_4(T4_DISABLED,0,1);
  setup_CCP4(CCP_OFF);
  setup_vref(FALSE);
  setup_low_volt_detect(FALSE);
  setup_oscillator(OSC_125KHZ);
The problem I am having is I cannot get PIN_D1 to operate as an input.
I can get PIN_D1 to operate as an output but it does not operate as an input. As an input, when the voltage is logic 1 the code sees logic 0.
Any help is greatly appreciated.
Piccolo
PIC16F1937 PIN_D1 won't work as input
PostPosted: Fri Feb 05, 2010 10:16 am     Reply with quote
Here's what I found to fix the problem:
I need to go and clear the ANSELD register bit 1.
 bit_clear(ANSELD,1);
Works fine now.
Piccolo
PIC16LF1937 PIN_D1 won't work as input
PostPosted: Fri Feb 05, 2010 10:18 am     Reply with quote
I should have included this:
#byte ANSELD = 0x18F
Piccolo
Charlie U
PostPosted: Mon Mar 15, 2010 3:09 pm     Reply with quote
I am using a PIC16F1937 in a new project and have been wracking my brain for a couple of days on problems with Port E. I finally resorted to reviewing the list file and found a bit of a problem. I am a big believer in setting the tris registers myself for speed's sake. Well, V4.104 tries to set the old TRISE register (89h) rather than the new one (90h). I "upgraded" to 4.105 and a simple file with about 15 lines that was generated by the "Wizard" won't even compile now. It appears that the function parameters for Timer 1 have been left out of the 16F1937.h include files. Two steps forward and three steps back. @#$%^&*
