iKevin
| #int_RDA never fires (18F4520) compiler version = PCH 4.094 |
Posted: Sun Feb 21, 2010 8:06 pm |
I have an interrupt for RS232 (#int_RDA), but it never fires when it receives data.
So I checked the include file 18f4520.c and found:
| Code: | | #define INT_RDA 0x9D20 |
I checked the datasheet and the SPFs for RDA is bit 5 of PIR1 (RCIF)
Can I do the following because the RDA interrupt address might be wrong?
#define PIR1 0xF9E
#bit RCIF = PIR1.5
#define int_UART_RX RCIF
#int_UART_RX
void uart_rx_isr(void)
//blah blah
Here is the completed program:
#include <18f4520.h>
#device ICD=TRUE
#fuses HS,NOLVP,NOWDT
#use delay (clock=20000000)
#define tx_pin PIN_C6
#define rx_pin PIN_C7
#use rs232(baud=2400, xmit=tx_pin, rcv=rx_pin, stream=PC, ERRORS)
#int_RDA
void RDA_isr(void)
printf("RDA fires\n\r");
My compiler version is PCH 4.094u
Thanks |
Posted: Sun Feb 21, 2010 8:46 pm |
You need to call the enable_interrupts() routine for both INT_RDA and
GLOBAL interrupts (2 lines of code). |
iKevin
Posted: Sun Feb 21, 2010 9:06 pm |
I put those enables in and it works, thanks a lot buddy.
| Code: | #include <18f4520.h>
#device ICD=TRUE
#int_RDA
void RDA_isr(void)
enable_interrupts(INT_RDA);
