DS1302 problem working with 18f4550
theasus
PostPosted: Sun Feb 21, 2010 4:03 am     Reply with quote
I can use DS1302 with PIC16F877A. But I can't use DS1302 with 184550.
I couldn't understand the problem. Nothing appears on LCD.
Here is my code:
#include <18F4550.h>
#FUSES WDT128                   //Watch Dog Timer uses 1:128 Postscale
#FUSES HS                       //High speed Osc (> 4mhz)
#FUSES BORV20                   //Brownout reset at 2.0V
#FUSES LVP                      //Low Voltage Programming on B3(PIC16) or B5(PIC18)
#FUSES NOWRTD                   //Data EEPROM not write protected
#FUSES FCMEN                    //Fail-safe clock monitor enabled
#FUSES NOWRTC                   //configuration not registers write protected
#FUSES NOWRTB                   //Boot block not write protected
#FUSES NOEBTR                   //Memory not protected from table reads
#FUSES NOEBTRB                  //Boot block not protected from table reads
#FUSES NOCPB                    //No Boot Block code protection
#FUSES NOMCLR                     //Master Clear pin enabled
#define use_portd_lcd TRUE
#include <lcd.c>
#include <DS1302.c>
byte hour,minute,second;
   setup_adc(ADC_OFF);
   setup_vref(FALSE);
   lcd_init();
   rtc_init();
   rtc_set_datetime(21,02,10,6,12,52);
   while(true)
      rtc_get_time(hour,minute,second);
      printf(lcd_putc,"\nTime:%02d:%02d:%02d",hour,minute,second);
PostPosted: Sun Feb 21, 2010 1:48 pm     Reply with quote
#FUSES LVP
This fuse can cause the PIC to lock-up if Pin B5 goes high.
Change it to NOLVP. Do that in all your programs.
If that doesn't fix the problem, then post the list of PIC pins
that you have connected to the ds1302 chip.
