salgulsen
| using interrupt spi1 with button.c |
Posted: Sat Feb 13, 2010 9:55 am |
I'm trying to use button command that is in code library with the int_spi1 of dspic30f4013. But it doesnt work quite correctly. Here is my code :
#include <30F4013.h>
#FUSES NOWDT, HS, PR, NOCKSFSM, WPSB16, WPSA512, PUT64, NOBROWNOUT, BORV47, LPOL_HIGH, HPOL_HIGH, NOPWMPIN, MCLR, NOPROTECT, NOWRT, NODEBUG, NOCOE, ICSP1, RESERVED
#include <button.c>
#byte SPI1BUF = 0x224 // Register address for dspic30f4013
int8 resp=0,B0,B1,B2,B3,sendit=0x00,counter;
#int_spi1
void spi1_isr(void)
int8 command;
command = SPI1BUF;
switch (command){
case 0xFF: SPI1BUF = 0;
case 0xFE: SPI1BUF = sendit;
case 0xFD: resp++;
SPI1BUF = resp;
int1 menubut,upbut,downbut,selbut,startbut,stopbut,bolusbut;
int8 cnt,anl81=0,anl82;
int16 anl16=0;
//int16 TRISDE;
setup_spi(spi_slave | spi_L_to_H);
clear_interrupt(INT_SPI1);
enable_interrupts(INT_SPI1);
setup_wdt(WDT_OFF);
setup_timer1(TMR_DISABLED|TMR_DIV_BY_1);
//TRISDE = GET_TRIS_D();
//TRISDE = TRISDE && 65279;
//Set_TRIS_D(TRISDE);
//menubut = input(pin_b0);
//upbut = input(pin_b1);
//downbut = input(pin_b3);
//selbut = input(pin_b4);
menubut = button(pin_b0,0,100,50,B0,1);
upbut = button(pin_b1,0,100,50,B1,1);
downbut = button(pin_b3,0,100,50,B2,1);
selbut = button(pin_b4,0,100,50,B3,1);
if(menubut){
bit_set(sendit,0);
}else{
bit_clear(sendit,0);
if(upbut){
bit_set(sendit,1);
}else{
bit_clear(sendit,1);
if(downbut){
bit_set(sendit,2);
}else{
bit_clear(sendit,2);
if(selbut){
bit_set(sendit,3);
}else{
bit_clear(sendit,3);
delay_ms(10);
By the way if I use input(pin) command that are slashed out in code instead of the button commands, it works. I just want to suppress the buttons while I'm using the interrupts.
Thanks in advance. |
Posted: Sat Feb 13, 2010 12:25 pm |
The button.c code was written and tested only with the PCM and PCH
compilers (for 16F and 18F PICs). Also, it was written back in version 3
of the compiler (at about vs 3.229). With that version, the input()
function would not take a variable for the PIN number. It required a
constant. So I wrote a macro that would accept a variable pin number.
(Note: Vs. 4 of the compiler allows variables for the input() function).
If you look at the button.c code, you'll see this macro:
| Code: | | #define read_bit_var(x) bit_test(*(int8 *)(x >> 3), x & 7) |
This macro probably doesn't work with the PCD compiler. I don't have
that compiler, so I don't know for sure. But there I believe there is a
work-around. Edit the button.c file. Comment out the call to the
read_bit_var() function, and add a call to the input() function, as shown
below. See if that fixes the problem with PCD.
int8 button(int16 pin, int8 downstate, int8 delay,
int8 rate, int8 &BVar, int8 action)
int8 pin_value;
// Read the button pin.
//pin_value = read_bit_var(pin); // *** Comment out this line
pin_value = input(pin); // *** Add this line |
