		| Author | Message |
		| sindyme
				| My #int_RDA can't work on PIC24F256GB106 |
				|  Posted: Thu Feb 11, 2010 11:59 pm |   |
				| My CCS Verison is 4.104 for "PCDIDE Compiler". I'm use "PIC24F256GB106" for RS232.
 If I no use "#int_RDA" that PIC will be normal work.
 But when I use "#int_RDA" function that  PIC will  unceasing redundant reset.
 It will not do main function !
 Where is bug at my code ?
 These is normal work code.
  	  | Code: |  	  | #include <stdio.h>
 #include <string.h>
 #pin_select U1TX=PIN_G6
 #pin_select U1RX=PIN_G7
 #pin_select U2TX=PIN_D8
 #pin_select U2RX=PIN_D9
 #use rs232(UART1,baud=115200,parity=N,bits=8,stream=coma)
 #use rs232(UART2,baud=115200,parity=N,bits=8,stream=comb)
 //setup_spi(SPI_MASTER | SPI_MODE_3 |SPI_CLK_DIV_1);
 //setup_spi2(SPI_SS_DISABLED);
 setup_wdt(WDT_OFF);
 setup_timer1(TMR_DISABLED|TMR_DIV_BY_1);
 enable_interrupts(INT_RDA);
 enable_interrupts(INT_RDA2);
 for(;;)
 fprintf(coma,"comb test a ... \r\n");
 fprintf(comb,"comb test b ... \r\n");
 delay_ms(2000);
 If I add #INT_RDA function that PIC will reset again and again
 There is bug code.
 #include <string.h>
 //One rs232 module setting:
 char rs_buff[512],check_str[20],str_temp[20];
 int16 buff_number,i,j,k,fund_str_point,temp1,temp2;
 //Two rs232 module setting:
 char rs_buffb[512],check_strb[20],str_tempb[20];
 int16 buff_numberb,ib,jb,kb,fund_str_pointb,temp1b,temp2b;
 #int_RDA
 void RDA_isr(void)
 //clear_interrupt(INT_RDA2);
 disable_interrupts(INT_RDA2);
 rs_buff[buff_number]=getc(coma);
 if(buff_number<512)
 buff_number=buff_number+1;
 buff_number=0;
 #int_RDA2
 void RDA2_isr(void)
 //clear_interrupt(INT_RDA);
 disable_interrupts(INT_RDA);
 rs_buffb[buff_numberb]=getc(comb);
 if(buff_numberb<512)
 buff_numberb=buff_numberb+1;
 buff_numberb=0;
 //RS232 Buff Cls
 void rs232_buff_cls()
 for(buff_number=0;buff_number<512;buff_number++)
 rs_buff[buff_number]=' ';
 buff_number=0;   //RS232 Buff Point set to 0
 //RS232 Buff Clsb
 void rs232_buff_clsb()
 for(buff_numberb=0;buff_numberb<512;buff_numberb++)
 rs_buffb[buff_numberb]=' ';
 buff_numberb=0;   //RS232 Buff Point set to 0
 //Check string
 void string_buff_check(int str_num_check)
 temp1=i;
 temp2=j;
 if(buff_number<str_num_check)
 fund_str_point=512;            //代表無找到或錯誤
 for(i=0;i<(buff_number-str_num_check);i++)
 for(j=0;j<20;j++)
 str_temp[j]=' ';
 for(j=0;j<str_num_check;j++)
 str_temp[j]=rs_buff[i+j];
 //將RS232 BUFF內的字元與輸入字元比較
 if(strncmp(str_temp,check_str,str_num_check)==0)
 fund_str_point=i;
 i=buff_number+1;
 fund_str_point=512;
 i=temp1;
 j=temp2;
 //Check stringb
 void string_buff_checkb(int str_num_checkb)
 temp1b=ib;
 temp2b=jb;
 if(buff_numberb<str_num_checkb)
 fund_str_pointb=512;            //代表無找到或錯誤
 for(ib=0;ib<(buff_numberb-str_num_checkb);ib++)
 for(jb=0;jb<20;jb++)
 str_tempb[jb]=' ';
 for(jb=0;jb<str_num_checkb;jb++)
 str_tempb[jb]=rs_buffb[ib+jb];
 if(strncmp(str_tempb,check_strb,str_num_checkb)==0)
 fund_str_pointb=i;
 ib=buff_numberb+1;
 ib=temp1b;
 jb=temp2b;
 void Module_Initial()
 RE_Module_Initial:
 if(Module_ERR==0)
 rs232_buff_cls();
 fprintf(coma,"AT\r\n");                         //check module
 delay_ms(200);
 strcpy(check_str,"OK");
 string_buff_check(2);
 if(fund_str_point==512)
 fprintf(coma,"AT Command Error...\r\n");
 GOTO RE_Module_Initial;
 setup_wdt(WDT_OFF);
 Module_ERR = 0;   GSM_Inlcnt = 0;   Msg_ERR = 0;   GPRS_ERR = 0;
 SISW_ERR = 0;
 fprintf(coma,"coma working OK ... \r\n");
 fprintf(comb,"comb working OK ... \r\n");
 output_high(EEPROM_SELECT);                  //SPI CS Initial
 delay_ms(2000);
 Module_Initial(); //<--- First do this
 for(;;)
 delay_ms(2000);
 There is PIC .h file.
  	  | Code: |  	  | #include <24FJ256GB106.h>
 #FUSES NOJTAG                   //JTAG disabled
 #FUSES ICSP1                    //ICD uses PGC1/PGD1 pins
 #FUSES WINDIS                   //Watch Dog Timer in non-Window mode
 #FUSES WPRES128                 //Watch Dog Timer PreScalar 1:128
 #FUSES WPOSTS16                 //Watch Dog Timer PostScalar 1:32768
 #FUSES PR                       //Primary Oscillator
 #FUSES NOCKSFSM                 //Clock Switching is disabled, fail Safe clock monitor is disabled
 #FUSES NOOSCIO                  //OSC2 is clock output
 #FUSES HS                       //High speed Osc (> 4mhz for PCM/PCH) (>10mhz for PCD)
 #FUSES IOL1WAY                  //Allows only one reconfiguration of peripheral pins
 #FUSES WPEND_LOW
 #FUSES NOWPCFG
 #FUSES NOWPDIS
 #FUSES WPFP3
 #FUSES WPFP4
 #FUSES PLL6                   //Divide By 12(48MHz oscillator input)
 #FUSES DISUVREG
 #FUSES WPFP5
 #FUSES WPFP6
 #FUSES WPFP0
 #FUSES WPFP1
 #FUSES WPFP2
 #FUSES WPFP7
 #FUSES WPFP8
 #FUSES RESERVED                 //Used to set the reserved FUSE bits
 #use delay(clock=22118400)
		| FvM
				|  Posted: Fri Feb 12, 2010 2:28 am |   |
				| - Interrupt nesting is disabled by default, you don't need to disable or enable any interrupts in the interrupt function.
 - You're writing one byte out of bounds of your rx buffers (rs_buffb[512]).
 Apart from these points, I don't see problems with your code. RS232 interrupts are generally working with PIC24 chips and recent PCD versions.
		| Ttelmah Guest
				|  Posted: Fri Feb 12, 2010 4:00 am |   |
				| Has the problem with the UART numbers being reversed, been fixed?. If not, then the code would hang.
 I really would suggest, getting just _one_ UART working first.
		| FvM
				|  Posted: Fri Feb 12, 2010 7:20 am |   |
				|  	  | Quote: |  	  | Has the problem with the UART numbers being reversed, been fixed?. |
 Yes, if I remember right. But it's a good idea to check correct SFR usage and PIN_SELECT coding anyway. It has
 been partially wrong with PIC24FJxxGB1xx in previous compiler versions and is still wrong for some more exotic
 PIC24 types.
		| sindyme
				|  Posted: Fri Feb 12, 2010 8:34 am |   |
				|  	  | FvM wrote: |  	  |  	  | Quote: |  	  | Has the problem with the UART numbers being reversed, been fixed?. |
 PIC24 types.
 I will continue try. This week is chinese new year , I have seven day's holiday.
 Next week I will try again ~
 | You cannot post new topics in this forum You cannot reply to topics in this forum
