T6963.c and pic16F877A
abawan
PostPosted: Mon Feb 15, 2010 3:08 am     Reply with quote
I am working on PG12864F LCD, with PIC 16F877A and compiler is CCS. I downloaded "T6963C LCD driver for Microchip 16F877" from techtoys.com.hk (which I found from this forum). My circuit is same as given by the author. I want to display ASCII characters from internal RAM only. The code I wrote is
#include <16F877a.h>
#Fuses HS,NOWDT,NOPROTECT,NOLVP,NOBROWNOUT
#include "t6963.h"
#include "t6963.c"
void main (void)
GDispInit( );
FontSize= 8;
GDispSetMode(XOR_MODE | INT_CG_MODE);
GDispSetMode(TEXT_GRH_ON);
GDispClrTxt( );
GDispClrGrh( );
GDispGoto(0,0);
GDispChar(0x85);  // any ASCII char
Crying or Very sad
When I use this in original circuit, the LCD shows rubbish and behaviour is unusual. While same code is working in Proteus simulation. Kindly help me regarding configuration of PG12864F LCD.
abawan
arunb
RE:
PostPosted: Tue Feb 16, 2010 2:52 am     Reply with quote
I use a similar Graphical LCD (240x128) with the T6963 driver and it works perfectly, but I used this driver code..http://www.ccsinfo.com/forum/viewtopic.php?t=19957&highlight=t6963
Also check the PIC connections to the LCD.
thanks
arunb
abawan
PG12864-f
PostPosted: Wed Feb 17, 2010 1:07 am     Reply with quote
I have checked circuit. Circuit is ok. I want to confirm that POWERTIP
PG12864-F (128x64) uses T6963 controller or if it has some other.
Anybody working on this LCD please share his code.
