		| Author | Message |
		| Oli Guest
				| manually changing oscillator source on PIC24 [how-to] |
				|  Posted: Fri Feb 12, 2010 5:33 am |   |
				| I needed to change the clock source and found the setup_oscillator function inadequate, especially if switching from a non-PLL mode to PLL mode. There is an unlocking sequence that must be followed first and executed in assembly.
 The code below changes the NOSC 2:1 bits to 011 to select the oscillator source as primary, with PLL enabled.
  	  | Code: |  	  | #asm //;Place the new oscillator selection in W0
 MOV.b #0x03, w0                                 // NOSC2:0 = 011 - primary osc with PLL
 //;OSCCONH (high byte) Unlock Sequence
 MOV #0x0743,w1
 MOV #0x78, w2
 MOV #0x9A, w3
 //DISI #0x5               // uncomment if you have interrupts enabled
 MOV.b w2, [w1]
 MOV.b w3, [w1]
 //;Set new oscillator selection
 MOV.b w0, [w1]
 mov #0x01, w0                                   // clock switching enabled
 //;OSCCONL (low byte) unlock sequence
 MOV #0x0742,w1
 MOV #0x46, w2
 MOV #0x57, w3
 MOV.b w2, [w1]
 MOV.b w3, [w1]
 //;Start oscillator switch operation
 MOV.b w0, [w1]
 #endasm
 EDIT: The values 0x0742 and 0x0742 are the addresses for the OSCCON high and low bytes on the PIC24FJ256GB110
		| FvM
				|  Posted: Fri Feb 12, 2010 7:27 am |   |
				| Yes, curiously CCS PCD is using a non-operational unlocking sequence in some places. The below code (used in PCD #PIN_SELECT code) does not work, because W0 is loaded between both writes to the unlock register. In this case, the pin select register shall be proteceted, but they aren't.
  	  | Code: |  	  | 00334:  MOV     #46,W0 00336:  MOV.B   W0L,742
 00338:  MOV     #57,W0
 0033A:  MOV.B   W0L,742
 0033C:  BSET.B  742.6
 | You cannot post new topics in this forum You cannot reply to topics in this forum
