Andreas
| write_configuration_memory fails ?? |
Posted: Wed Feb 10, 2010 1:45 am |
I am trying to make a repair programm because the initial bootloader had the BORV set wrong.
So I was thinking of doing the following:
define: int data[6]
read_configuration_memory[data,6];
change data[1] to new content
write_configuration_memory[data,6];
..... it hangs up !
any suggestions ??
appriciate your help
best regards
Andreas
#define SDL32
#define Master_Slave
#define NewAtmel
#define IntGPRS
#define GPRSActive
#define LCD4X20
#define NewGSM
//#define Bootloader // Define for using with bootloader only !!
//#undef bootloader
#include "C:\SDL_All_Versions\SDL32_Intern_GPRS\SDL32_Intern_GPRS.h"
#include <string.h>
#include <stdio.h>
#include "C:\SDL_All_Versions\SDL32_Common\LCD420_8B.c"
#ifdef Bootloader
#include "C:\SDL_All_Versions\SDL32_Intern_GPRS\Bootloader_New_SDL32_GPRS.h"
int data[6];
// Set All Output Signals to Init Values
// Flash Interface Signals
set_tris_B(0xff);
set_tris_E(0x00);
Set_Tris_H(0xff); // Set All Keyboard Lines to Input
Output_Low(E_Input); // Input Latches Enable Line
Output_Low(E_OUT); // Disable Output Latch
Output_Low(LCD_EN); // Disable LCD Enable Pin
Output_Low(RS); // LCD Command Line
Output_High(RW); // LCD Read/Write Line
Output_High(RReset); // RAM Reset
Output_Low(RReset); // RAM Reset
Output_High(ROut_E); // RAM Output Enable
Output_High(RDir); // RAM Data Direction Set to Write to Flash
Output_High(E_Out_Buffer); // Disable Output Driver
Output_High(WP); // Page Write Protect NOT USED
Output_High(RB_2);
Output_High(RB_3);
Output_High(RB_4);
Output_High(CS_1); // -Chip Select for RAM
Output_High(CS_2);
Output_High(CS_3);
Output_High(CS_4);
Output_High(CS_RAM);
// Output Driver Interface
OutLatch = 0x00; // Clear Output Latch Variable
// LED Backlight Control
Output_High(BackLight); // Switch Off for ModemControl
Output_High(CLK); // Set Clk for Polarity Low Timing
// General Setups
setup_adc(ADC_OFF);
setup_psp(PSP_DISABLED);
setup_wdt(WDT_OFF);
setup_timer_0(RTCC_INTERNAL);
setup_timer_1(T1_DISABLED);
setup_timer_2(T2_DIV_BY_16,0xFF,8);
setup_timer_3(T3_INTERNAL|T3_DIV_BY_1);
setup_ccp2(CCP_PWM);
setup_vref(FALSE);
set_timer3(0xFA20);
lcd_init(); // Init LCD Display
switch ( restart_cause() )
case WDT_TIMEOUT:
lcd_gotoxy(1,4);
lcd_putc("Watch DOG Reset");
case NORMAL_POWER_UP:
lcd_gotoxy(1,4);
lcd_putc("Power Up Reset");
case MCLR_FROM_SLEEP:
lcd_gotoxy(1,4);
lcd_putc("Reset from Sleep");
case MCLR_FROM_RUN:
lcd_gotoxy(1,4);
lcd_putc("Reset Button");
case BROWNOUT_RESTART:
lcd_gotoxy(1,4);
lcd_putc("Brown Out Reset");
case WDT_FROM_SLEEP:
lcd_gotoxy(1,4);
lcd_putc("WDT from Sleep Reset");
case RESET_INSTRUCTION:
lcd_gotoxy(1,4);
lcd_putc("Reset Instruction");
lcd_gotoxy(1,1);
read_configuration_memory(data,6);
Disp_Hex (data[0]);
Disp_Hex (data[1]);
Disp_Hex (data[2]);
Disp_Hex (data[3]);
Disp_Hex (data[4]);
Disp_Hex (data[5]);
delay_ms(10000);
data[1] = 0x1E;
lcd_gotoxy(1,2);
Disp_Hex (data[0]);
Disp_Hex (data[1]);
Disp_Hex (data[2]);
Disp_Hex (data[3]);
Disp_Hex (data[4]);
Disp_Hex (data[5]);
write_configuration_memory(data,6);
reset_cpu();
delay_ms(2000);
lcd_gotoxy(1,3);
Disp_Hex (data[0]);
Disp_Hex (data[1]);
Disp_Hex (data[2]);
Disp_Hex (data[3]);
Disp_Hex (data[4]);
Disp_Hex (data[5]);
} //main
Posted: Wed Feb 10, 2010 3:11 am |
First, what chip....
Then, you are executing 'reset_cpu' after writing. It won't ever get to the program beyond this. Reset_cpu, makes the code restart.
Posted: Wed Feb 10, 2010 3:18 am |
Hi Ttelmah,
Thanks for the quick reply !
Yes You are right I removed it already, was a thinking loop -:(
I found now, that the program hangs after write_configuration_memory !
Chip : 18F8722
I cant find any hint on how it should really work, the manual is not very detailed in that !
best regards
ANdreas |
Posted: Wed Feb 10, 2010 4:31 am |
If int means int8 in your code, you're not writing to the BORxx bits. Byte 1 is CONFIG1H (FOSCx).
Generally, if you don't know what a built-in function actually does, look at the generated code or trace it with
MPLAB SIM or assembly level debug. |
Andreas
Posted: Wed Feb 10, 2010 6:15 am |
Hi FvM,
That was the perfect hint, I was mixing up high and low Byte, because in the Config table in the microchip manual it starts with 300001h BUT this is the 1H Byte and not the 1L Byte !
Many thanks for Your help.
Best regards out of vienna
Andreas |
