Dead part on ICD-64, trying to figure out what the part is..
jventerprises
PostPosted: Fri Jan 29, 2010 12:59 pm     Reply with quote
I have a bunch (8) of ICD-64s that no longer work. They died from static. After poking around i have determined that the data line no longer toggles. I have traced it to the following part on the PCBs:
8 pin SOiC, marking WH-125
does anybody know what that part actually is? I can post a pic if you can tell me how....
thanks
Jon
PostPosted: Sun Jan 31, 2010 2:07 am     Reply with quote
If you put "WH125" (without the quotes) into Digikey's search engine,
http://www.digikey.com/
it comes up with some Toshiba dual bus buffers with the markings:
WH
125
But they are not in the Soic-8 package. They are smaller packages.
http://www.toshiba.com/taec/components2/Datasheet_Sync//168/7368.pdf
Also, there is no dash "-" shown in the markings in the data sheet.
See the diagram on page 1.
jventerprises
thanks
PostPosted: Sun Jan 31, 2010 9:16 am     Reply with quote
I swear I tried that! It looks like the SSOP package. The function
sounds right though, a bus buffer. I will replace them and let everyone
know if it works.
Jon
wayneosdias
Re: thanks
PostPosted: Fri Jul 23, 2010 1:23 pm     Reply with quote
know if it works.
I've gone thru this, I used digikey p/n TC7WH125FKFCT-ND and all is well now.
It is interesting the icd40 pgd, pcm lines seem much more robust than the icd64, but I have had failures.
