lgeorge123
| what is the max speed of this UART function |
Posted: Mon Feb 01, 2010 3:15 am |
I am using ft232BM ( virtual com port IC) and 18f4550 and connect to pc usb port. Under the following codes what is the speed of the transfer rate in baud rate ? If I set the baud rate in 1M , will it transfer in this rate ?
| Code: | #include <18F4550.h>
#fuses HSPLL,NOWDT,NOPROTECT,NOLVP,NODEBUG,USBDIV,PLL5,CPUDIV1,VREGEN
#use delay(clock=48000000)
#use rs232(UART1, baud=1000000, errors)
char c;
setup_adc( ADC_CLOCK_INTERNAL );
setup_adc_ports( ALL_ANALOG );
set_adc_channel(1);
c= read_adc();
putc(c);
Posted: Mon Feb 01, 2010 5:29 am |
The bytes will clock in/out at 1000000Hz.
However, the actual overall transfer 'speed' will be well below this, limited by several things, primarily:
1) How fast you can load a new byte, after one is sent.
2) How fast the data can actually be transferred over USB.
FTDI, claim 1Mb/sec using the D2XX drivers, but only 300KB/sec with the VCP drivers. Since you talk about using the virtual com port, you are using the latter. Even this speed will be dependant on what else is being done on the USB bus at the time.
Then you also have the qustion of wheher the physical connection between the PIC, and the STDI chip, can handle 1MHz. It will, provided the lines are reasonably laid out, but if there is significant length, or you start using RS232 transceivers, then 'no'...
Posted: Mon Feb 01, 2010 7:50 am |
The requested speed is 1 MBit/s which is < 300kByte/s. Handling this throughput by the PIC18
application may be still an issue. Also at the PC side, the driver interface should be well-considered. |
Posted: Mon Feb 01, 2010 8:08 am |
No, should be lower case 'b' for the second. 300Kb/sec. Shift key slipped....
If you notice, it is correct for the 1Mb/sec on the first driver, and this will be faster than the VCP driver.
If you think about the packet overhead of the VCP driver, and it's priority on USB, this makes good sense.
