Calamar
Joined: 07 Sep 2003 Posts: 60 Location: Buenos Aires (Argentina)
| 16f873 10 bits adc |
Posted: Sun Apr 20, 2003 12:55 pm |
Could someone help me?
I cant get 10 bits resolution, the next code
give me a error when I try compile it:
PRINTF FORMAT TYPE IS INVALID,
#include <16f873.h>
#use delay (clock=4000000)
#fuses NOPROTECT, XT, NOWDT, PUT, NOLVP, BROWNOUT
#use rs232(baud=19200, xmit=PIN_C6, rcv=PIN_C7 )
byte seconds=0;
byte count=15;
byte mem=0;
#int_rtcc
clock_isr() {
if(count--==0) {
++seconds;
count=15;
main() {
setup_adc_ports ( RA0_ANALOG );
setup_adc ( ADC_CLOCK_INTERNAL );
set_adc_channel(0);
set_rtcc(0);
setup_counters (RTCC_INTERNAL, RTCC_DIV_256);
enable_interrupts (INT_RTCC);
do {
if(seconds!=mem) {
printf ("\n\r \%lu",read_adc());
mem=seconds;
} while(1);
Original Post ID: 13834 _________________ Best Regards
Daniel H. Sagarra
La Plata (Argentina) |
R.J.Hamlett Guest
| Re: 16f873 10 bits adc |
Posted: Sun Apr 20, 2003 1:39 pm |
:=Could someone help me?
:=I cant get 10 bits resolution, the next code
:=give me a error when I try compile it:
:=PRINTF FORMAT TYPE IS INVALID,
:=#include <16f873.h>
:=#use delay (clock=4000000)
:=#fuses NOPROTECT, XT, NOWDT, PUT, NOLVP, BROWNOUT
:=#use rs232(baud=19200, xmit=PIN_C6, rcv=PIN_C7 )
:=byte seconds=0;
:=byte count=15;
:=byte mem=0;
:=#int_rtcc
:=clock_isr() {
:= if(count--==0) {
:= ++seconds;
:= count=15;
:=main() {
:= setup_adc_ports ( RA0_ANALOG );
:= setup_adc ( ADC_CLOCK_INTERNAL );
:= set_adc_channel(0);
:= set_rtcc(0);
:= setup_counters (RTCC_INTERNAL, RTCC_DIV_256);
:= enable_interrupts (INT_RTCC);
:= enable_interrupts(GLOBAL);
:= do {
:= if(seconds!=mem) {
:= printf ("\n\r \%lu",read_adc());
:= mem=seconds;
:= } while(1);
Add the following line, after the include file.
#DEVICE ADC=10
This switches the compiler to returning a 10 bit value. Without this, 'read_adc' will return an 8 bit value.
This is in the manual entry for the read_adc function.
Original Post ID: 13835 |
Calamar
Posted: Sun Apr 20, 2003 5:35 pm |
Thanx you a lot,,, it work perfectly
best regards
Original Post ID: 13845 _________________ Best Regards
Daniel H. Sagarra
