Shawn Cherewick
Joined: 07 Sep 2003 Posts: 5 Location: Abbotsford, BC, Canada
| What clock frequency to use if using internal RC with respec |
Posted: Sun Apr 20, 2003 12:07 pm |
Quick question:
Which clock frequency should I use if I'm using the internal RC clock of a PIC12F675 and am using #use delay()?
#use delay(clock = 4000000) //Fosc of internal RC.
or
#use delay(clock = 1000000) //Fosc/4
I'm getting strange timing if I use 4 MHz, all seems fine at 1 MHz (this could be misleading as the delay routines are faster). I would think that I should be using the Fosc (4 MHz)as described in the CCS manual.
If anyone can confirm that I should be using 4 MHz, I'll look elsewhere in my code for problems.
Regards,
Shawn.
Original Post ID: 13833 |
liche Guest
| Re: What clock frequency to use if using internal RC with re |
Posted: Mon Apr 21, 2003 6:32 am |
Check out the PIC datasheet. You should be able to find the frequency (+/-) range of the internal oscillator. Its not going to be real accurate (assuming you're using internal oscillator you don't need accuracy anyways). If you do need accurate timing, you'll need to go to a crystal oscillator.
:=Quick question:
:=Which clock frequency should I use if I'm using the internal RC clock of a PIC12F675 and am using #use delay()?
:=#use delay(clock = 4000000) //Fosc of internal RC.
:= or
:=#use delay(clock = 1000000) //Fosc/4
:=I'm getting strange timing if I use 4 MHz, all seems fine at 1 MHz (this could be misleading as the delay routines are faster). I would think that I should be using the Fosc (4 MHz)as described in the CCS manual.
:=If anyone can confirm that I should be using 4 MHz, I'll look elsewhere in my code for problems.
:=Regards,
:=Shawn.
Original Post ID: 13861 |
Shawn Cherewick
Posted: Mon Apr 21, 2003 11:58 am |
Thanks, but that's not what I'm after. The question I'm asking is about the compiler and the "#use delay" directive.
Normally, using an external crystal (say 11.0952 MHz) I would put #use delay(clock = 11059200) and everything will be happy.
When using an internal oscillator, should I use the actual oscillator frequency (4 MHz) or should I use what the operation frequency will be (1 MHz, Fosc/4)?
Shawn.
:=Check out the PIC datasheet. You should be able to find the frequency (+/-) range of the internal oscillator. Its not going to be real accurate (assuming you're using internal oscillator you don't need accuracy anyways). If you do need accurate timing, you'll need to go to a crystal oscillator.
:=:=Quick question:
:=:=Which clock frequency should I use if I'm using the internal RC clock of a PIC12F675 and am using #use delay()?
:=:=#use delay(clock = 4000000) //Fosc of internal RC.
:=:= or
:=:=#use delay(clock = 1000000) //Fosc/4
:=:=I'm getting strange timing if I use 4 MHz, all seems fine at 1 MHz (this could be misleading as the delay routines are faster). I would think that I should be using the Fosc (4 MHz)as described in the CCS manual.
:=:=If anyone can confirm that I should be using 4 MHz, I'll look elsewhere in my code for problems.
:=:=Regards,
:=:=Shawn.
Original Post ID: 13877 |
| Re: What clock frequency to use... |
Posted: Mon Apr 21, 2003 12:16 pm |
<font face="Courier New" size=-1>:=Thanks, but that's not what I'm after. The question I'm asking is about the compiler and the "#use delay" directive.
:=Normally, using an external crystal (say 11.0952 MHz) I would put #use delay(clock = 11059200) and everything will be happy.
:=When using an internal oscillator, should I use the actual oscillator frequency (4 MHz) or should I use what the operation frequency will be (1 MHz, Fosc/4)?
The following program makes an LED on GP2 (pin 5)
turn on for 1 second and then off for 1 second.
I checked this with a stop watch.
(12F629 is similar to 12F675).
So the answer is, use 4 MHz.
If you're getting weird results, I would check:
1. Has Osccal setting at 0x3FF been trashed ?
Read the ROM using your programmer and check it.
2. Are the config bits correct ?
Read them with your programmer. Compare them to
the ones in the .HEX file. Compare both to the
data sheet.
3. Possibly your compiler has a bug. I tested the
following program with PCM vs. 3.148. What is
your version ?
<PRE>
#include <12F629.h>
#fuses INTRC, NOWDT, NOPROTECT, NOMCLR
<BR>
main()
<BR>
output_low(PIN_A2);
output_high(PIN_A2);
<BR>
</PRE>
--</font>
Original Post ID: 13884 |
Shawn Cherewick
Posted: Mon Apr 21, 2003 12:29 pm |
:=<font face="Courier New" size=-1>:=Thanks, but that's not what I'm after. The question I'm asking is about the compiler and the "#use delay" directive.
:=:=Normally, using an external crystal (say 11.0952 MHz) I would put #use delay(clock = 11059200) and everything will be happy.
:=:=When using an internal oscillator, should I use the actual oscillator frequency (4 MHz) or should I use what the operation frequency will be (1 MHz, Fosc/4)?
:=The following program makes an LED on GP2 (pin 5)
:=turn on for 1 second and then off for 1 second.
:=I checked this with a stop watch.
:=(12F629 is similar to 12F675).
:=So the answer is, use 4 MHz.
:=If you're getting weird results, I would check:
:=1. Has Osccal setting at 0x3FF been trashed ?
:= Read the ROM using your programmer and check it.
:=2. Are the config bits correct ?
:= Read them with your programmer. Compare them to
:= the ones in the .HEX file. Compare both to the
:= data sheet.
:=3. Possibly your compiler has a bug. I tested the
:= following program with PCM vs. 3.148. What is
:= your version ?
:=<PRE>
:=#include <12F629.h>
:=#fuses INTRC, NOWDT, NOPROTECT, NOMCLR
:=<BR>
:=main()
:=<BR>
:=while(1)
:=output_low(PIN_A2);
:=delay_ms(1000);
:=output_high(PIN_A2);
:=delay_ms(1000);
:=<BR>
:=</PRE>
:=--</font>
I'm using PCM 3.152, maybe I'll roll back to 3.148 and check again. I will look at each item you described to see if there is a problem somewhere.
Thanks,
Shawn.
Original Post ID: 13886 |
