| Torello
				|  Posted: Sun Jan 24, 2010 7:50 am |   |
				| Hi,
 Below a solution. You need to setup the Spi-bus first. The function typecasts the struct as pointer to a byte array. Therefore you also need to pass along the size of this array. The sizeof takes care of this.
 Be aware: int16 are put in memory as Lsbyte-Msbyte, so that is also the order that this function will put out int16.
  	  | Code: |  	  |
 // --- Typedef the struct
 Typedef struct{
 struct {
 int16 a;
 int8 b;
 int8 c;
 int16 d;} IamStructType;
 //--- Declare the struct variable
 IamStructType  Iam;
 //--- call the function somewhere in your program
 spi_writeStruct(&Iam, sizeof(Iam));
 // === function ====================================
 void spi_WriteStruct(int8 *src, int8 szf) {
 // usage: spi_WriteStruct( (int8*)&Struct, sizeof(Struct) )
 int8 wbyte;
 int8 idx;
 for(idx=1; idx < szf; idx++) {
 wbyte = src[idx];                                    //get the byte out the structure
 spi_write(wbyte);                                    //spi write the byte
