ferkar
| sending string and decoding |
Posted: Mon Jan 04, 2010 3:57 pm |
hi everyone,
I am sending serial data to PIC via rs232 port using Visual Basic.
The data is like this "f123k456h789".
I get these data to 18f452 by using gets().
How can I separate this data to:
f,123k,456,h,789
Then I am going to use it in PIC code.
thanks |
ferkar
Posted: Mon Jan 04, 2010 4:11 pm |
| Thanks for help. However it is not the answer I want I think. I need to find a command or something like that is used for splitting the string and get the characters that I want. |
Posted: Mon Jan 04, 2010 4:17 pm |
| Sorry. I put in the wrong link. I have corrected it now. |
mbradley
Joined: 11 Jul 2009 Posts: 118 Location: California, USA
Posted: Tue Jan 05, 2010 12:12 am |
Just out of curiosity, why don't you send the data with the ',' commas in the string?
At that point, loop through all chrs, building a new string, and when you encounter "," process what you have thus far, then continue.
Or do you have a string when each field is separated by ',' and thus not data items? ie: 'username,phone,cell_phone' type of thing?
If the latter is the case, I usually make an array of strings, and parse the string into the array, such as GPS data, then I know which field has the data I want. _________________ Michael Bradley
www.mculabs.com
Open Drivers and Projects |
Wayne_
| Re: sending string and decoding |
Posted: Tue Jan 05, 2010 3:24 am |
| ferkar wrote: | hi everyone,
f,123k,456,h,789
thanks |
This can be very easy or quite complicated, it all depends.
Is each section a fixed length e.g 1 char, 4 chars, 3 chars, 1 char, 3 chars (numbers will have leading 0's 056) ?
Are the numbers to be translated into values (456, 789) ?
Does the k (123k) represent 1024 or 1000 and can there be an m, g ?
Can they be uppercase and do they mean the same thing. ?
The simple solution is to do something like
char a, b[5], c[4], d, e[4]; // need space for the null terminating for the strings
char s[] = "f123k456h789";
a = s[0];
strncpy(b, s[1], 4; // Will put a null on the end
strncpy(c, s[5], 3);
d = s[8];
strncpy(e, s[9], 3);
