GLCD (ks0108) 128x64 - Image (bitmap) - Create? (help-me)
eduardoludgero
PostPosted: Sun Oct 14, 2007 12:24 pm     Reply with quote
I looked at the site and did not find anything concrete on GLCD and image. So I decided to write questions to see if you can help me?
CCS compiler version: 4.049
Settings: main.h
#include <16F877A.h>
#device adc=10
#FUSES NOWDT              //No Watch Dog Timer
#FUSES LP                      //Low power osc < 200 khz
#FUSES NOPUT               //No Power Up Timer
#FUSES NOPROTECT       //Code not protected from reading
#FUSES NODEBUG          //No Debug mode for ICD
#FUSES NOBROWNOUT   //No brownout reset
#FUSES NOLVP               //No low voltage prgming, B3(PIC16) or B5(PIC18) used for I/O
#FUSES NOCPD              //No EE protection
#FUSES WRT_50%          //Lower half of Program Memory is Write Protected
Settings: main.c
#include "main.h"
#include <GLCD.c>
#include <math.h>
//Variables of the main program
 int16  lm35i, MPX5700i;
 float lm35f,  MPX5700f;
 char  TempText[] = "Temperatura: ";
 char  PressaoText[] = "Pressao...:: ";
 char  conversao[20];
   setup_adc_ports(AN0_AN1_VSS_VREF);
   setup_psp(PSP_DISABLED);
   setup_spi(SPI_SS_DISABLED);
   setup_timer_1(T1_DISABLED);
   setup_vref(FALSE);
   // Begin CODE!
   glcd_init(ON);
   delay_ms(1);
   glcd_fillScreen(OFF);
   glcd_rect(1, 5, 126, 62, NO, ON);
   glcd_text57(3, 8, TempText, 1, ON);
   glcd_text57(3, 16, PressaoText, 1, ON);
  do
      // begin code - LM35 ---------------------------------------------
      set_adc_channel(0);                      //Arrow reading in the channel AN0
      delay_ms(1);
      lm35i= read_adc();
      delay_ms(1);
      //Conversion
      lm35f= (lm35i*0.0048828125*100);
      delay_ms(1);
      sprintf(conversao,"%f", (float)lm35f);
      glcd_text57(80, 8, conversao, 1, ON);
      glcd_text57(80, 8, conversao, 1, OFF);
      //end code - LM35 ----------------------------------------------
      //begin CODE - MPX5700A --------------------------------------------------
      set_adc_channel(1);                     //Arrow reading in the channel AN1
      delay_ms(1);
      MPX5700i= read_adc();
      delay_ms(1);
      //Conversion
      MPX5700f= (22.281*(MPX5700i*0.004882))+9.0869;
      delay_ms(1);
      sprintf(conversao,"%f", (float)MPX5700f);
      glcd_text57(80, 16, conversao, 1, ON);
      glcd_text57(80, 16, conversao, 1, OFF);
      //end CODE - MPX5700A ----------------------------------------------------
  }while(1);
The code in my application is posted before, now I need help putting a background image?
Thanks! (Forgiveness by my English, I am Brazilian!)
PostPosted: Sun Oct 14, 2007 12:36 pm     Reply with quote
#FUSES LP // Low power osc < 200 khz
For a 4 MHz crystal, you should use the XT fuse.
eduardoludgero
Need Files (posted)
PostPosted: Tue Oct 16, 2007 9:33 am     Reply with quote
Need files:
* Imagemakerv2.rar
* Glcdanim.rar
* Animation.avi
Sending me by e-mail. PLEASE!
Files in post: www.ccsinfo.com/forum/viewtopic.php?t=27615&highlight=glcd + animation
Thanks!
Mail: eduardolu@hotmail.com
dda
Re: Need Files (posted)
PostPosted: Sat Jan 02, 2010 11:45 pm     Reply with quote
eduardoludgero wrote:
Need files:
* Imagemakerv2.rar
* Glcdanim.rar
* Animation.avi
Files in post:
Thanks!
all links in the above link are dead, could you please post another link or could you please share the files.
