dev39
| Passing NULL as pointer to function gives error |
Posted: Fri Jan 01, 2010 5:45 am |
I am trying to pass NULL for pointer to function, the compiler complains
"Expecting function Name". Is there any way I can pass NULL for pointer to function. Compiler version is 4.081.
#include <18F46K20.h>
#include <stdio.h>
typedef int (* _ptr_to_fn_)(int a,int b);
int test(int a , int b){
return (a+b);
int operation(int a, int b, _ptr_to_fn_ fn){
return (*fn)(a,b);
void main(){
operation(1,2,test); //compiles ok
operation(1,2,NULL); //Error 53: Expecting function name
