kben Guest
INT_RDA & PIC16F628 & ver 2.717 |
Posted: Sat Apr 19, 2003 1:29 am |
I posted this a long time ago, and moved on to other projects.
However, I have never been able to get the hardware uart ISR to work with ver 2.717 & a pic16f628. I read through every post on this forum and none address this problem directly. I did download the new example files and *.h files, but the new file
(1/4/2001) for the 16f628 is the exact same as the old one (7/21/2000). I would be very happy if anyone could explain to me what the proper procedure is to get this working. It's not my hardware or my code, it is some kind of bug in ver 2.717 of the compiler, and I am not sure how to fix it.
INT_RDA is 0x8C20, and Global is 0x0BC0
Thanks in Advance
Original Post ID: 13803 |
Humberto
Re: INT_RDA & PIC16F628 & ver 2.717 |
Posted: Sat Apr 19, 2003 8:07 am |
:=I posted this a long time ago, and moved on to other projects.
:=However, I have never been able to get the hardware uart ISR to work with ver 2.717 & a pic16f628. I read through every post on this forum and none address this problem directly. I did download the new example files and *.h files, but the new file
:=(1/4/2001) for the 16f628 is the exact same as the old one (7/21/2000). I would be very happy if anyone could explain to me what the proper procedure is to get this working. It's not my hardware or my code, it is some kind of bug in ver 2.717 of the compiler, and I am not sure how to fix it.
:=INT_RDA is 0x8C20, and Global is 0x0BC0
:=Thanks in Advance
Hi:
I´m not sure if somebody still have that old PCM version to test your code.
CURRENT SOFTWARE VERSION : 3.152
Post your code and we will try to help you.
Best wishes
Humberto
Original Post ID: 13817 _________________ Humberto |
kben Guest
Posted: Sat Apr 19, 2003 2:26 pm |
:=:=I posted this a long time ago, and moved on to other projects.
:=:=However, I have never been able to get the hardware uart ISR to work with ver 2.717 & a pic16f628. I read through every post on this forum and none address this problem directly. I did download the new example files and *.h files, but the new file
:=:=(1/4/2001) for the 16f628 is the exact same as the old one (7/21/2000). I would be very happy if anyone could explain to me what the proper procedure is to get this working. It's not my hardware or my code, it is some kind of bug in ver 2.717 of the compiler, and I am not sure how to fix it.
:=:=INT_RDA is 0x8C20, and Global is 0x0BC0
:=:=Thanks in Advance
:=Hi:
:=I´m not sure if somebody still have that old PCM version to test your code.
:=CURRENT SOFTWARE VERSION : 3.152
:=Post your code and we will try to help you.
:=Best wishes
:=Humberto
//Code Sample
#device PIC16F628
#include "C:\PROJECTS\DEFS\16f628.h"
#fuses xt,nowdt,noprotect,put,nobrownout,nolvp
#use delay (clock=4000000)
#use rs232 (baud=9600, rcv=PIN_B1, xmit=PIN_B2, parity=N, bits=8,ERRORS)
void flashled();
char c;
#INT_RDA // Commented out for NON INT_RDA
void serial_isr(){ // Commented out for NON INT_RDA
c = getc(); // Commented out for NON INT_RDA
} // Commented out for NON INT_RDA
main ()
enable_interrupts(INT_RDA); // Commented out for NON INT_RDA
enable_interrupts(GLOBAL); // Commented out for NON INT_RDA
flashled();
puts("\r\n Starting Test ...\r\n");
while(1){
delay_ms(2000); // Commented out for NON INT_RDA
// c=getc(); // Commented out for INT_RDA
puts("\r\n In Loop ...\r\n");
putc(++c); // add 1 to c and display it
c = 'Y'; // assign char c a known value when using INT_RDA
} // if I don't press a key 'Z' will display
void flashled() {
int i;
for(i=0;i<=8;i++) {
output_low(PIN_A4);
delay_ms(200);
output_high(PIN_A4);
delay_ms(200);
// End Code Sample
This example works fine with the c=getc() NON INT_RDA code.
If I uncomment the INT_RDA rtns, it just conitually displays
In Loop ...
Z
So it is acting like it never get the INT_RDA when a
key is pressed on the keyboard.
Thanks in advance for any suggestions.
Original Post ID: 13826 |
