davekelly
Joined: 04 Oct 2006 Posts: 53 Location: Berkshire, England
| USB HID Serial Number |
Posted: Thu Aug 30, 2007 10:42 am |
V3.249, PIC 18F4550
I have a hid application, which is working fine.
My system will use several of these device simultaneously, so I want to use the serial number feature to identify each interface.
I can add the serial number manually in the descriptor code, but instead I would like to read the string from eeprom, so that I don't need a different version of firmware for every device.
I am struggling to find the location where the descriptors are sent, so that I can intercept at this point and replace the serial number string with the values as read from eeprom.
Anyone done something similar, or know a better approach? |
Bcox
Posted: Fri May 30, 2008 6:10 am |
Hello all,
No one ever replied to this post. i am actually in the same boat as this. I have created an HID device and have the possibility of having multiple of these devices connected to one computer. Right now, I am able to communicate with two devices through my host program on my PC but cannot distinguish which one is which. I could easily serialize these using the #serialize command and have my host program distinguish which device is which by requesting the device to send the serial number to it. Perhaps this will be a better option for me also.
I would like to know if there is a way to set the usb serial number in the descriptor code for a HID device. i am using the usb_desc_hid.h file and modifying to suit my needs. What I can't tell is if using the HID class, the serial number is only defined by Windows and cannot be physically set in the PIC.
I am using a 18F4550 with Compiler V.4.06
Thanks for your help! |
davekelly
Posted: Fri May 30, 2008 6:26 am |
I did actually come up with a solution to this, although I subsequently abandoned HID and went to virtual comms instead.
I am just leaving for the day, but will try to dig out what I did next week and post |
3PO Guest
Posted: Sun Dec 20, 2009 1:52 pm |
I have the same problem.
How to set serial number on my HID device ? |
ELCouz
Posted: Thu Dec 24, 2009 2:08 pm |
3PO since you have problem using the forum search button let's search together okay ?
The second item in the list
and then you have this also:
Third item
ouch that was hard !!!  |
