unexpected change of variables (solved)
gs
PostPosted: Tue Nov 24, 2009 4:15 pm     Reply with quote
Compiler version PCH 4.084
PIC18F4550
In my application I see that certain variables change, when a specific code part is executed. The change is always on the same byte, same bit.
If I define a dummy variable, the problem is temporarily solved, but this is not the solution, because this might also happen anywhere in the program in variables that I dont check externally.
Have you ever met this behavior before?
I know I have to post a part of code for you to reproduce the problem but I have to strip it down first as it is fairly big file.
Thanks a lot in advance
www.hlektronika.gr
meereck
PostPosted: Tue Nov 24, 2009 4:26 pm     Reply with quote
Perhaps, you are addressing a wrong index which is beyond the variable size. Such as
int myarray[10];
myarray[10]=5;
etc...
Try to post some source code example. It might also be a compiler bug.
cheers
cseusy
PostPosted: Tue Nov 24, 2009 11:39 pm     Reply with quote
See responses to my post called "randomly changing variables". Maybe they can shed some light. I have been fighting the same or similar problem for two weeks. A friend who is an expert computer scientist says this is called memory stomping. That is an accurate description. I can always change code to make the problem go away, then when I add more code, the "stomp" manifests somewhere else. Best of luck! If you find the solution, please post it.....pleeeeeeeeaaassse!!!
gs
PostPosted: Wed Nov 25, 2009 3:13 pm     Reply with quote
It is very big code to strip it down. It uses 18F4550 and a glcd 128*64
I use graphics.c and HDM64GS12.h math and string functions.
glcd_rect(x-1,y-1,x+29,y+7*size, YES, !color);            // Lain menu and -255
//glcd_rect(x,y,x+29,y+7*size, YES, !color);               // Lain menu only
the two lines above, both make problems.
Both of them change the first character of a string that is M and it changes to L
The first one changes the bit0 of the high byte of a 16bit variable (makes it 0) the second line does not do this but the result is not the desired.
If I do this
xx=x-1;
yy=y-1;
glcd_rect(xx,yy,x+29,y+7*size, YES, !color);
has the same result as
Note that x,y are integers that I use a lot in many subroutines as locals
Any suggestions on how to debug this situation? I have ICD2 availiable.
www.hlektronika.gr
FvM
PostPosted: Wed Nov 25, 2009 4:49 pm     Reply with quote
If I understand right, you already found out, that the glcd_rect() call writes somehow out of bounds. You can set a breakpoint on write to the specific variable address and identify, which exact instruction does the write. You should be able to understand, if the compiler does something wrong or it's a coding error, e.g. in the subroutine.
gs
PostPosted: Mon Nov 30, 2009 12:42 pm     Reply with quote
Finally I solved the problem.
cseusy, did you also use graphics lcd?
I use fast glcd
My problem was created because I was displaying text at the bottom right corner of the lcd and the y value was one pixel over the proper value.
100% my coding fault.
I wrote a routine to display value with an option to select the polarity of the text displayed and the background of the text. That background is always 1 pixel around the text displayed. The routine that draws that background goes out of the glcd displaydata table and writes in the next memory positions.
I have to confess that I was quite brute while debugging today...
Thanks a lot for your time
www.hlektronika.gr
