Need 7-segment display CCS driver for 18f4550
kizuc
PostPosted: Wed Nov 25, 2009 7:44 pm     Reply with quote
Good day,
I am working on a project with PIC18F4550 using 7 segment for my display. I need a CCS driver for this 7 segment display, to include in my code.
I am planning to use either 2 digits or 4 digits display.
Please can anyone help me out?
mskala
PostPosted: Thu Nov 26, 2009 11:26 pm     Reply with quote
I have this code for 2-digit which works great and only needs 1 resistor.
See the top comments for exact parts used.
/*  Mark A. Skala                                                             */
/*  Dual 7-segment driver stuff.                                              */
/*  Uses Lumex LDD-E302NI part (Digikey 67-1410-ND) with                      */
/*  TI 8-chan driver TLC5916IPWR (Digikey 296-22711-1-ND) and                 */
/*  Dual P-mosfet Fairchild FDW2508PB (Digikey FDW2508PBCT-ND                 */
/*  All 3.3V logic                                                            */
#define LED_TABLE_LENGTH 20
#define LED_L     16
#define LED_T     17
#define LED_DASH  18
#define LED_BLANK 19
#define PIN_LED_LEFT_EN  PIN_C2    // go to dual fet
#define PIN_LED_RIGHT_EN PIN_C1    // go to dual fet
#define PIN_LED_LE       PIN_B3    // go to TI driver
#define PIN_LED_CLK      PIN_B5    // go to TI driver
#define PIN_LED_SDI      PIN_B4    // go to TI driver
static int8 const led_table[LED_TABLE_LENGTH] =
//      ----           seg A
//     |    |   seg F         seg B
//      ----           seg G
//     |    |   seg E         seg C
//      ----           seg D
// bit7 .. bit0  ==>>   seg  None,G,A,F,D,E,C,B
// TI Driver connections:
// OUT0 -> None
// OUT1 -> Seg G
// OUT2 -> Seg A
// OUT3 -> Seg F
// OUT4 -> Seg D
// OUT5 -> Seg E
// OUT6 -> Seg C
// OUT7 -> Seg B
0x3f,    // 0
0x03,    // 1
0x6d,    // 2
0x6b,    // 3
0x53,    // 4
0x7a,    // 5
0x7e,    // 6
0x23,    // 7
0x7f,    // 8
0x7b,    // 9
0x77,    // A
0x5e,    // b
0x3c,    // C
0x4f,    // d
0x7c,    // E
0x74,    // F
0x1c,    // L
0x5c,    // t
0x40,    // -
0x00     // blank
// globals holding displayed value and ram copy of table (for speed reasons)
int8 left_led_val;
int8 right_led_val;
int8 ram_led_table[LED_TABLE_LENGTH];
#INT_RTCC
void clock_isr() {                 // the RTCC (timer0) overflows (255->0).
   rtcc_toggle=1-rtcc_toggle;      // For this program this is apx 8.2ms @ prescale 128
   if (rtcc_toggle) {
      LED_serial(ram_led_table[left_led_val]);
      output_high(PIN_LED_RIGHT_EN);
      output_low(PIN_LED_LEFT_EN);
   } else {
      LED_serial(ram_led_table[right_led_val]);
      output_high(PIN_LED_LEFT_EN);
      output_low(PIN_LED_RIGHT_EN);
   int8 a;
   for (a=0;a<LED_TABLE_LENGTH;a++) {                 // copy led table to RAM
      ram_led_table[a]=led_table[a];
   left_led_val=LED_BLANK;          // init or you could have garbage at start
   right_led_val=LED_BLANK;
// Note I'm using 16MHz clock
   setup_timer_0( RTCC_INTERNAL | RTCC_8_BIT | RTCC_DIV_128);
   enable_interrupts(INT_RTCC);
// your program here
   left_led_val=LED_DASH;          // show "-7"
   right_led_val=7;
senator
PostPosted: Mon Dec 07, 2009 7:27 pm     Reply with quote
Please Mr Mskala, how can I use your code because I am working on a similar project.
Undefined identifier "rtcc_toggle"and "led_serial" error keeps recurring.
Can you give step by step details on how a newbie can use your program codes.
anandpv2009
PostPosted: Tue Dec 08, 2009 8:38 am     Reply with quote
what kind of display r u using(common anode or cathode)
dyeatman
PostPosted: Tue Dec 08, 2009 9:17 am     Reply with quote
Did you bother to read the part number info he gave and look up the data sheet?
The LDD-E302NI is common anode.
kizuc
"Expecting an identifier"
PostPosted: Tue Dec 08, 2009 9:54 am     Reply with quote
The major problem now is compiling this code successfully with CCS compiler. It keeps bringing up this error ""Expecting an identifier"" for clock_isr.
I am using PIC18F4550.
What might be wrong? Pls help out.
senator
I use a common cathode 7 segment display.
Thanks in advance.
anandpv2009
PostPosted: Tue Dec 08, 2009 11:33 am     Reply with quote
Thanks in advance.
I think this quotes are enough for dyeatman
My qustion is not to mskala
decode details for common cathode (Decimal values)
0 - 63
1 - 6
2 - 91
3 - 79
4 - 102
5 - 109
6 - 95
7 - 7
8 - 127
9 - 103
mskala
PostPosted: Tue Dec 08, 2009 11:40 am     Reply with quote
My apologies, I cut out a bit too much.
The variable rtcc_toggle is just a global 1-bit var. Since there are 2
characters in the display, every 8.2ms we have to change which 7-seg
is being driven. At that rate (or faster) it does not flicker.
The driver chip takes the 8 segments to be displayed serially. This is the routine.
void LED_serial(int8 val) {
   int8 i;
   for (i=0;i<7;i++) {
      output_bit(PIN_LED_SDI,val&1);
      val>>=1;
      output_high(PIN_LED_CLK);
      output_low(PIN_LED_CLK);
   output_high(PIN_LED_CLK);     // last bit is unimportant
   output_high(PIN_LED_LE);      // latch
   output_low(PIN_LED_LE);
Hope this helps.
kizuc
Error-Free code
PostPosted: Wed Dec 16, 2009 5:20 am     Reply with quote
Hello mskala,
Thanks for your assistance so far. I want to suggest you the complete code for the 7 segment (an error-free code) display. I am compiling with CCS PCWH 4.032 compiler for PIC.
Thank you once again.
Kingsley
