CCSLOAD / MACH X erasing problem
EmmKay
PostPosted: Wed Dec 23, 2009 11:56 pm     Reply with quote
Hi All,
It might be a simple question to answer but none the less it has got me confused. I am working pic 16f822. When I erase the chip, ccsload displays that the erasing has been successful. So when I go into verify chip is blank it comes up with the message 'chip not erased'. Because of this the writing to the chip is not working.
Also the file info shows the target chip field to be blank, while all other options in CCSload recognise the chip as being the correct one.
Any help / insight is much appreciated.
Cheers
CORRECTION it should say 16f882 and not 16f822... My typeo..!!!!!
EmmKay
wwinch
PostPosted: Tue Dec 29, 2009 6:11 pm     Reply with quote
If you figure it out, please update. I have the same problem.
I haven't used the Mach X in a year or more, so went thru the whole update to CCSLOAD/firmware business. Now I can't erase a 18LF2680 in the ZIF socket. Have not yet tried a different chip or programmer.
EmmKay
PostPosted: Sun Jan 03, 2010 10:35 pm     Reply with quote
I have had no luck with my issue!.. does any one have any insight that they can offer!!!!! any hint to look into a particular direction..?????
PostPosted: Sun Jan 03, 2010 11:33 pm     Reply with quote
Does any one have any insight that they can offer?
If I go to the Microchip website and use their search engine to search for:
16F822
or
PIC16F822
Then I get this response:
Your search PIC16F822 did not match any documents
It's also not listed in the Microchip Data sheet finder page:
http://www.microchip.com/stellent/idcplg?IdcService=SS_GET_PAGE&nodeId=2046
EmmKay
PostPosted: Mon Jan 04, 2010 1:32 am     Reply with quote
MY BAD.. it should be 16F882.. I made a typo and and being brainwashed in trying to figure out the problem kept reading the 16f822 as 16f882...
cheers all..
PostPosted: Mon Jan 04, 2010 1:55 am     Reply with quote
What is the Vdd voltage of the PIC ? Is it 3.3v ? The CCS programmer
may be doing a bulk-erase operation, and that won't work if the Vdd
on the 16F882 is less than 4.5 volts.
Also, to find out what sections are not being erased, use the CCS
programmer to read the PIC. Then look at the program memory and
the Config bits that have been read.
