74HC595!!!!!!!PROGRAM
Sparta
PostPosted: Fri Nov 06, 2009 12:46 pm     Reply with quote
hi...In my project, I am using the pic to control my 22 x 12 RGB led board to display the words and some animation.
I have totally no idea how to control the 74HC595. And I also don't no how to use 1 bit to control 8 bits output...Hope any know the idea or EXAMPLE of simple program can show.
Beside that, I am not sure how to transfer the serial input of first 595 to the second 595. Hope anyone know it, can share the idea with me. THANKS
PostPosted: Fri Nov 06, 2009 1:08 pm     Reply with quote
Look at these CCS example and driver files for the 74595.
c:\program files\picc\examples\ex_expio.c
c:\program files\picc\drivers\74595.c
Use the forum's search page to search for 74595 and also for 74HC595.
There are many posts on this topic. Examples:
http://www.ccsinfo.com/forum/viewtopic.php?t=34740
http://www.ccsinfo.com/forum/viewtopic.php?t=17368
PostPosted: Sat Nov 07, 2009 12:11 pm     Reply with quote
//------ Do 74HC595 serial chip --------------
//MSB > xxxx xxxx     xxxx xxxx < LSB
void Do_Serial_Chip(int8 Fuera1,int8 Fuera2)
   int8 i;
   int16 ajuera;
   ajuera = Fuera1;
   ajuera = ajuera<<8;
   ajuera = ajuera | Fuera2;
   // Output to serial line
   for(i=0; i<16; i++)
      if(ajuera & 0x8000)
         {Serial = 1;}
         {Serial = 0;}
      ajuera = ajuera<<1;
      SLOK = 0;     //Shift data
      SLOK = 1;
   RCK = 0;         //Output on pins
   RCK = 1;
