seidleroni
| Using a RealTek Ethernet Switch (RTL8305SC) with a PIC |
Posted: Fri Nov 06, 2009 8:15 pm |
I'm starting a project using the Realtek RTL8305SC ethernet switch. Does anybody have a good idea of how to use it, some code for it, or even a flow diagram of how it should be used in conjunction with an Ethernet enabled PIC?
Any help would be appreciated! I'm currently wondering what I need to do to get it working with the PIC, specifically the order of events. Do I need to reset the switch before enabling the ethernet in the PIC, or do I enable the ethernet on the PIC while the switch is in reset mode?
Thanks! |
