davefromnj
| first time USB question...PIC18F4450 |
Posted: Sat Oct 10, 2009 6:10 pm |
Hey all,
All I want to do is have the PIC18F4450 act as a USB keyboard. I looked at the examples, but they are less than intuitive for me.
What would an example program look like that sent the letter "f" to a PC if let's say port B2 went high.
I don't get this because I see the usb_putc() function in the manual, but not used in the examples, and the examples using usb_put_packet(2,tx_msg,sizeof(tx_msg),USB_DTS_TOGGLE);
where array tx_msg gets stuffed with values earlier.
Thanks, sorry for not understanding well.
OK, I now see that the usb_putc() function is actually usb_cdc_putc() for applications where you'd want the PIC to act as a seril-to-usb interface.
So, just for sending a keyboard character to windows I have to use:
davefromnj2 Guest
| newbie city... |
Posted: Sat Oct 10, 2009 11:18 pm |
I am basically trying to implement a simple keyboard in windows using a pic18F4450: a switch closes on an input pin and the pic sends a keyboard letter to windows via USB.
So I have a few questions for usb_put_packet(A,B,C,D)
A = Endpoint ----- I want to send data to, ok which one is the PC host, address 1?
B = Data ----- Can this just be an ASCII code? For example, can I put 0x46h in here for "F" ? Will windows know this is a keyboard character?
C = Length ----- Since I'm only sending one keyboard key at a time, should this just be 1?
D = DTS_TOGGLE ----- How does this work? What should go here if I only want the PIC to be a keyboard?
Also, what is the basic frame work for the files to include, and what is the necessary order?
What else would be missing from the following test code?
| Code: | #include <18F4550.h>
#DEFINE USB_HID_DEVICE TRUE
#fuses HSPLL,NOWDT,NOPROTECT,NOLVP,NODEBUG,USBDIV,PLL5,CPUDIV1,VREGEN
#use delay(clock=48000000)
#include <pic18_usb.h
#include <usb_desc_kbmouse.h>
#include <usb.c>
void usb_keyboard_task(void);
usb_init_cs();
if (input(PIN_B3))
usb_keyboard_task();
static int8 tx_msg[7]={0,0,0,0,0,0,0};
static int8 leds;
if (!input(BUTTON))
tx_msg[2]=4;
tx_msg[2]=0;
usb_put_packet(2, 0x46, 1, USB_DTS_TOGGLE);
//receive NUM LOCK, CAPS LOCK, etc LED status from PC.
//we won't do anything with it.
if (usb_kbhit(2))
{usb_get_packet(2, &leds, 1);
FvM
Posted: Sun Oct 11, 2009 1:41 am |
| You apparently didn't consider the fact, that an USB keyboard usually is following the HID (human interface device) class specification and not sending ASCII codes. If you intend to build a device, that can be recognized by a computer as keyboard, you should use HID. You can find more informations about USB device classes at www.usb.org/developers. If you just want to build some kind of terminal, you can use CDC (communication device class) and usb_putc(). |
davefromnj
| Thanks |
Posted: Sun Oct 11, 2009 1:18 pm |
| FvM wrote: | | You apparently didn't consider the fact, that an USB keyboard usually is following the HID (human interface device) class specification and not sending ASCII codes. If you intend to build a device, that can be recognized by a computer as keyboard, you should use HID. You can find more informations about USB device classes at www.usb.org/developers. If you just want to build some kind of terminal, you can use CDC (communication device class) and usb_putc(). |
I don't know anything about doing this project or I wouldn't post here.
Thank you for pointing out that a USB keyboard doesn't just send ascii codes, that I did not know or that I will have to use the HID class.
Does the USB spec. actually say what data needs to be sent in order for windows to see a keyboard keypress since it's not ascii?
Does the USB spec. define what values, etc are supposed to go into CCS's usb_put_packet(A,B,C,D) function?
Is there another spec. I'm missing?
I don't think I want to use the CDC mode because I don't want to write / support ANY driver for windows, linux, etc -- I really do only want to make a plain old usb keyboard. |
