| peterl
				| 12F675 configure ports |
				|  Posted: Fri Oct 09, 2009 2:28 pm |   |
				| hi guys, I use PIC-C compiler version 4.074. I want to make PIN_A0, PIN_A2 as input and PIN_A1 as output. To enable PULLUPS resistor of PIN_A0, PIN_A2, I wrote this :
  	  | Code: |  	  | #include "D:\Dimer V.2\main.h"
 setup_adc_ports(NO_ANALOGS);
 setup_adc(ADC_OFF);
 setup_timer_1(T1_DISABLED);
 setup_comparator(NC_NC);
 setup_vref(FALSE);
 set_tris_A(0b10110000);
 port_a_pullups(TRUE);
 Am I right? Because I tried it, but pullups resistor does not work. My second question is: if I use INPUT() function in this way is it necessary to use set_tris_x to configure which pin is input/output?
 Thank's a lot !
