| PIC16F727 problem with input on pin |
Posted: Fri Aug 07, 2009 6:10 am |
Hello.
First of all i'm using PICC (CCS)
[+5V]---[ 10K pullup] ---|^|---[KEY (button)]---[GROUND]
[^] is the Pin of PIC.
All of keyboard Pic Pins have 10K Pullups. (in theory) when button is pressed the pin is grounded and should give logical 0;
However when im reading the value of pin without pushing the key it is readed as 0.
the pin list:
#define KDB0 PIN_A5
#define KDB1 PIN_A4
#define KDB2 PIN_A3
#define KDB3 PIN_A2
#define KDB4 PIN_A1
#define KDB5 PIN_A0
#define KDB6 PIN_B7
#define KDB7 PIN_B6
#define KRS PIN_B5
#define KRW PIN_B4
#define KE PIN_B3
2'nd problem is with PIN B0 and B1.
The pin are High after powerup. Then...
When i try to change value of the pin (no matter if i try to output HIGH or LOW by output_LOW or output_HIGH) the pin goes LOW.
When i use output_float(PIN_B0) and output_float(PIN_B1) the pin goes HIGH
but when i do that PIN_B2 goes LOW ;/
the concept is [+5V]------[RESISTOR]-----[PIC PIN].
in theory when pin goes LOW the diode flashes. |
Posted: Fri Aug 07, 2009 6:56 am |
you might want to post
1- what pic ?
2- YOUR CODE ( with #fuse statements )
3- your compiler version ( which you can get when you enter +V on the command line and hit enter )
based on the little i see - perhaps you are using a 16F62x ?
and perhaps the 'trouble' pins are set to be UART mode or whatever
but you aren't sharing enuf info to tell
so it is all surmise so far |
Posted: Fri Aug 07, 2009 8:57 am |
the fuses are : #NOWDT, #PLLEN, #INTRC_IO, #NOPUT
+ device =* (duno what it is);
+ noadc
the wrote the test code ... that is olny based on output_HIGH/LOW and delay_ms( ) ...
if(input(KEYBOARD_KEY)) { blinkink code (output high, delay, low ect) } // this do not work
but : if (!input(KEYBOARD_KEY)) {blinkink code (output high, delay, low ect) } // this work all the time ... no matter if i push the button or not... for that reason i suspect that i've always get logical 0 on the pin.
the pic type is in the subject (16F727) |
Posted: Fri Aug 07, 2009 9:01 am |
Some one wrote on the microchip forum (as a reply for my post there):
The pin's are configured as analog-inputs by default. You have to configure them to digital mode, before you can use them as digital i/o. This is explained in the i/o-ports chapter of the datasheet, where you'll find the description of the ANSELx - registers.
I think, your second problem with port b might be caused by this, too.
Hope this helps,
Stefan
// my question is : how to make pins to run in 'digital' mode ? |
Posted: Fri Aug 07, 2009 12:55 pm |
| Quote: | | how to make pins to run in 'digital' mode ? |
It would help us to understand your posts if you identified yourself
as someone other than "guest". I wasn't sure who did the last post.
Also, if you're quoting someone, highlight the text and press the Quote
button. This will clearly show it's a quote.
To answer your question, normally CCS puts in start-up code (which can
be seen in the .LST file, just after main) you) to configure the Analog pins
for Digital i/o. When the PIC is newly supported, sometimes they don't
do this correctly.
To manually configure the Analog pins for digital i/o, do this:
| Code: | | setup_adc_ports(NO_ANALOGS); |
Look in the .h file for your PIC to see other configuration options for
that function. |
Posted: Sat Aug 08, 2009 2:13 pm |
First of all I'm posting as 'guest' cuz I've not created account... for now.
Software details:
IDE Version: 4.074
PCB Version: 4.074
PCM Version: 4.074
PCH Version: 4.074
PCB Version: 4.068
MPLAB IDE v8.30
I'm using ICD2 programmer/debugger.
Program details:
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <16F727.h>
#device *=16
//#device ICD=TRUE // when used compiler returns error
#device adc=8
#FUSES BORV19
#FUSES PLLEN
#FUSES DEBUG //Debug mode for use with ICD
#FUSES NOVCAP
#use delay(clock=8000000)
port_b_pullups(FALSE); // < EXTERNAL PULLUPS ALREADY INSTALLED
setup_adc_ports(all_ANALOG); // < SHOULD BE NO ANALOGS (all digital) but input returns 0... still.
setup_spi(SPI_SS_DISABLED);
setup_timer_1(T1_DISABLED);
setup_oscillator(OSC_8MHZ);
IN THEORY ADC PINS SHOULD BE DIGITAL... BUT THEY ARE NOT...
they behave as analog inputs pins ;/
PLZ HLP ... somebody.. :(( |
Posted: Sat Aug 08, 2009 2:37 pm |
What do you think 'NO_ANALOGS' means.
What do you think 'ALL_ANALOG' means.....
Posted: Sat Aug 08, 2009 2:48 pm |
If you have problem and you don't understand it, then make a simple
little program to test that one thing. In your case, you believe that
input pins are not acting as digital pins. So, make a program that reads
one pin over and over again. If the pin is read as a "logic high" level,
then send a '1' to the terminal window. If it's read as a "logic low" level,
then send a '0'. This will tell you if your code and hardware are working
correctly. Example:
#include <16F727.h>
#fuses INTRC_IO,NOWDT,NOBROWNOUT,NOPUT
if(input(PIN_B0)) // Read pin B0
putc('1'); // If read a high level, then send a '1'
putc('0'); // If read a low level, then send a '0'
delay_ms(500); // Wait 1/2 second
The sample rate is kept at once every 1/2 second, so we don't fill up the
whole terminal window with 1's and 0's too quickly. |
Posted: Sat Aug 08, 2009 3:02 pm |
| Quote: |
This shows up a common problem with newbies. A 'pro' tells you to
change something, but it doesn't immediately solve the whole problem,
probably because there are multiple problems in the code.
So then a newbie changes the line back to the incorrect code.
Suppose your car wouldn't run properly. Suppose someone said that
one of your tires is flat. You pump it up, but the car still doesn't run.
There might be an additional problem of a dead battery.
Would you let the air out of the tire and make it flat again, simply
because fixing that problem didn't make the car start ? |
Posted: Sun Aug 09, 2009 1:00 pm |
| PCM programmer wrote: | If you have problem and you don't understand it, then make a simple
correctly. Example:
#include <16F727.h>
The readed value is 0 all the time...
ps. by setting NO_ANALOGS the compiler should set all pins in to the digital mode. (i think)... |
Posted: Sun Aug 09, 2009 3:13 pm |
| Quote: | PCM Version: 4.074
The readed value is 0 all the time... |
Your compiler version has bugs for the 16F727. The setup_adc_ports()
function does not make Port B into a digital port if you specify
NO_ANALOGS. To fix that bug, you need to add the two lines shown in
bold below:
| Quote: |
#include <16F727.h>
#byte ANSELB = 0x186
ANSELB = 0; // Set Port B to be all digital i/o
Also, the 16F727 has an internal voltage regulator. It requires an
external ceramic capacitor (0.1 to 1.0 uF) to operate correctly.
They want you to choose one of the following PIC pins for the capacitor:
pin A0, A5, or A6. Then add one of the following parameters to the
#fuses statement, to enable that pin: VCAP_A0, VCAP_A5, or VCAP_A6
For example, if you select pin A0, then use this fuse:
| Quote: | | #fuses INTRC_IO,NOWDT,NOBROWNOUT,NOPUT, VCAP_A0 |
Then put a 0.1 uF (100 nF) ceramic capacitor between pin A0 and ground.
Keep the leads very short.
Question: Do you really need to use this PIC ? It's a specialized PIC.
It has many features which are different from a normal PIC.
If you are just experimenting with PICs to learn about them, I suggest
that you choose a more simple, ordinary PIC, such as a 16F877 or
16F88, or something like that.
Also, there is no comparator on the 16F727. I put that line in there
because you had it in your program. I wasn't at a location where I
had access to the PIC data sheet. So don't use setup_comparator()
with this PIC. |
Posted: Sun Aug 09, 2009 5:20 pm |
Tomorrow i'll try this solution
I hope it 'll work
Thx for your time... |
