Onur
Rtos task rate and minor_cycle relationship |
Posted: Mon Aug 10, 2009 3:53 am |
Hello I want to ask about Rtos
this is main Rtos parameters
Code: | #use rtos(timer=0,minor_cycle=1ms) |
My tasks are
Code: | #task(rate=1s,max=1ms)
void The_first_rtos_task ( );
void The_second_rtos_task ( );
#task(rate=500ms,max=1ms)
void The_third_rtos_task ( );
void The_fourth_rtos_task ( );
#task(rate=250ms,max=1ms)
void The_fifth_rtos_task ( );
void The_sixth_rtos_task ( );
#task(rate=125ms,max=1ms)
void The_seventh_rtos_task ( );
void The_eighth_rtos_task ( );
#task(rate=65ms,max=1ms)
void The_nineth_rtos_task ( );
void The_tenth_rtos_task ( );
#task(rate=4ms,max=1ms)
void The_eleventh_rtos_task ( ); |
inside of task
if (flag==0){
flag=1;
rtos_disable(The_second_rtos_task);
}else{
rtos_enable(The_second_rtos_task);
flag=0;
output_toggle(LED1);
other tasks are similar just timings are different.
the problem is
this two tasks doesnt start from begining. what im doing is just flashing leds.
after I reset pic those two task doesnt start. maybe it tooks about 7sec to start.
if I use minor_cycle grater than 4or 5ms every thing is ok. the thing is I will add lots of task and I want to use faster minor.
Im not use but maybe minor_cycle uses 1byte varible or
rate uses 1byte varible
so when minor_cycle = 1ms if task rate=500 then multiply result grater than 1 byte.
What do you think?
Thank you for reading.
Onur
Im just guessing |
Posted: Mon Aug 10, 2009 7:54 am |
I guess
Task rate /minor_cycle =should be less then 255 (1 byte )
For example
Code: | #use rtos(timer=0,minor_cycle=2ms) |
#task(rate=500ms,max=2ms)
void The_first_rtos_task ( ); | This will be work correctly.
#task(rate=1000ms,max=2ms)
void The_first_rtos_task ( ); | This will not work correctly.
Is there any way to fix? |
