Suggestions for ISR code... int_global or ??
bkamen
PostPosted: Fri Jul 31, 2009 1:42 pm     Reply with quote
I have an application I'm writing where I have 4 identical devices on INT0 through INT3 on a PIC18F97J60.
For the proto - I kept them separate for other coding reasons, but now that I see I might be able get along with optimizing them.
Now, this means I could write 4 of the same ISR's that are prefaced with
#EXT_INT0 (,1,2,3)
But I'd like to avoid having the potential for 4 sets of code -- although they have some differences (basically addresses they access).
So I either write a routine that gets inserted 4 times using the #inline or I write a global ISR (not feeling so great about that).
I haven't considered if it can even be done to define a single ISR routine written as such: (literally)
#INT_EXT0
#INT_EXT1
#INT_EXT2
#INT_EXT3
void isr_routine () {
EDIT: Nevermind - the above doesn't work. Embarassed
I'd like to hear from the coders with experience writing weird ISR and maybe custom global interrupt handlers.
Thanks!
PostPosted: Fri Jul 31, 2009 2:05 pm     Reply with quote
This thread discusses your problem. See Ttelmah's response and
the orginal poster's decision:
http://www.ccsinfo.com/forum/viewtopic.php?t=36791
bkamen
PostPosted: Fri Jul 31, 2009 2:35 pm     Reply with quote
That's definitely one way of doing it...
Right now I have a routine that's called with a parm by the 4 different IRQ's.
Anyone else?
-Ben
p.s. thanks PCM
p.p.s. the #INT_DEFAULT description in the CHM Help could be a LOT better worded.
