PWM resolution??
switchblademaster
PWM resolution??
PostPosted: Tue Jul 21, 2009 3:18 pm     Reply with quote
ok.......so I set up my timer 2 and pwm.
I am operating at an oscillator frequency of 16KHz
with a timer 2 of:
setup_timer_2(T2_DIV_BY_1,255,1);
thus my period of PWM is: 64uS which s equal to 15.625KHz
The resolution of my PWM becomes 10-bit.
My question is, if PR2=255 at maximum and I have a 10-bit resolution PWM (0-1024) which determines what value the duty cycle could be. How, could this be possible.
How does one utilize a 10-bit resolution if PR2 is only 8-bit?????
I means that every time that TMR2=PR2 the pulse goes high.......however
if TMR2 reaches value in the duty cycle register PWM goes low.
If PR2=255 and the duty cycle is a10-bit number (say 512) then PWM will never happen the output will remain high always.....
Can anybody help me??
siwtchblademaster
PostPosted: Tue Jul 21, 2009 3:20 pm     Reply with quote
ok.........i have been thinking is it that:
if i have a 10-bit resolution and say duty cycle is 512 and pr2=255 then pwm:
(512/1023)*255
is that it?????
PostPosted: Tue Jul 21, 2009 3:30 pm     Reply with quote
If you give the set_pwmx_duty() function a parameter that is larger than
8-bits, the compiler changes the generated code so that it's using 10-bit
mode.
This thread has more information:
http://www.ccsinfo.com/forum/viewtopic.php?t=17729&start=12
switchblademaster
PostPosted: Tue Jul 21, 2009 4:12 pm     Reply with quote
ok...........I realised that.
I simulated my code and it worked that way. Thanks man.....
