Piccolo
| problem with shift_left function |
Posted: Fri Nov 20, 2009 4:25 pm |
I have been working with PCWH compiler version 4.100 for a couple of days now. I have been able to get my circuit to function, but in the process I have discovered that the functions shift_left and shift_right do not work. I have reported the issue to CCS technical support.
I used the following code as a work-around:
Instead of the built-in,
shift_left(&MyBuffer,2,input(PIN_A1));
I used
MyBuffer<<=1;
if(input(PIN_A1))
MyBuffer += 1;
Posted: Fri Nov 20, 2009 4:38 pm |
| Post your PIC. Post a compilable test program. |
Piccolo
Posted: Fri Nov 20, 2009 5:11 pm |
I'm using the PIC16F1937. I didn't post it because I guess it's not part-specific, but I could be wrong.
Code something like this:
To read 16 bits of data from PIN_A1 into a 16-bit:
int16 MyBuffer;
for(i=0;i<16;i++)
..wait for some sync. signal, like another IO line going high..
MyBuffer<<=1;
if(input(PIN_A1)
MyBuffer +=1;
..wait for sync signal like IO line going low..
When I compiled my original code, which had been working just fine on previous versions, examination of the ASM file showed the shift_left function actually had "???" instead of a GOTO command. I'm sure it will be fixed. I only posted this in case someone else was having the same trouble and this may help. Enjoy the weekend. |
Posted: Fri Nov 20, 2009 6:09 pm |
I made a test program and compiled it with versions 4.099 and 4.100.
It produces the same code for each version. You said it worked with
version 4.099. If it's the same .LST code, how can it then fail in vs.
4.100 ?
There appear to be at least 3 bugs. There's apparently an illegal opcode,
and the RLF instruction operates on the wrong memory addresses for
'MyBuffer'.
These bugs don't exist for the 16F877. I would guess they are only
in the new 16F19xx series, which has a new architecture and a new
register map.
vs. 4.100
00576 ...... shift_left(&MyBuffer,2,input(PIN_A1));
001C 148C 00577 BSF 0C.1 // Set TRISA.1 = input
001D 0020 00578 MOVLB 00 // Bank 0
001E 188C 00579 BTFSC 0C.1 // Test PortA.1
001F 2822 00580 GOTO 022 // Jump if PortA.1 = 1
0020 1003 00581 BCF 03.0 // Clear LSB bit in MyBuffer
0021 2823 00582 GOTO 023
0022 1403 00583 BSF 03.0 // Set the LSB bit in MyBuffer
0023 0060 00584 ??? // Unknown opcode (Bug ?)
// Rotate MyBuffer left 1 bit position
0024 0D81 00585 RLF 01,F // Should be RLF 21,F (Bug ?)
0025 0D82 00586 RLF 02,F // Should be RLF 22,F (Bug ?)
vs. 4.099
00474 ..... shift_left(&MyBuffer,2,input(PIN_A1));
001C 148C 00475 BSF 0C.1
001D 0020 00476 MOVLB 00
001E 188C 00477 BTFSC 0C.1
001F 2822 00478 GOTO 022
0020 1003 00479 BCF 03.0
0021 2823 00480 GOTO 023
0022 1403 00481 BSF 03.0
0023 0060 00482 ???
0024 0D81 00483 RLF 01,F
0025 0D82 00484 RLF 02,F
SYMBOL TABLE
LABEL VALUE
main.MyBuffer 00000021
Test program:
#include <16F1937.h>
#fuses XT,NOWDT,BROWNOUT,PUT,NOLVP
int16 MyBuffer;
Piccolo
Posted: Mon Nov 23, 2009 10:52 am |
| FYI: I received notice today from CCS Tech Support that the fix is in the next release. |
