EA DOGM Multi I/O LCD Driver v2.01 (updated 11/25/09)
mbradley
PostPosted: Sat Jul 11, 2009 10:42 pm     Reply with quote
Hi every one.
I was having issues with an EA DOG LCD, and I found very little examples out there, so I dove in and just got it done, and I thought I would share what I have thus far.
This works with the three models:
EADOGM081, EADOGM162, EADOGM163
And it works with 3.3volts or just 5volts.
EDIT:
I continue to update the source in this original post, to reflect current version, updates, and bug fixes.
In this version 2.01, I replaced several functions with macros, and I was able to reduce the amount of ROM used when compiled. A simple application I have showed 11 Bytes of rom saved, and 1 byte stack saved.
There is no syntax changes, if you are already using this driver, just drop it in.
Here is a simple example of header needed:
New version 2 allows for 8bit, SPI HW, or SPI SW (bit bang)
Example for 8bit mode
#define EADOGM162 1 // the model we selected
#define EADOGMVDD 5 // 5v LCD Vdd
#define EADOGM_8BIT    1 // 8 bit data bus i/o
#define EADOGM_NOCSB 1         // set to 1 if pin 38 (CSB) on lcd is tied to Vss
//#define EADOGM_PIN_CSB PIN_C2   // /CSB line, (pin 38 on the LCD) Req for SPI Opt for 8BIT
#define EADOGM_PIN_E   PIN_B1   // E (pin 36 on the LCD)
#define EADOGM_PIN_RW  PIN_B2   // RW (pin 37 on the LCD)
#define EADOGM_PIN_RS  PIN_B3   // RS line, (pin 39 on the LCD)
// we need to define how the byte goes out
//#define EADOGM_8BIT_PORT(d) output_b(d);   // single 8bit port output
#include "EA-DOGM_MIO.c"
Example for SPI SW (bit bang)
#define EADOGM163 1  // to use MODEL EADOG163
#define EADOGMVDD 5  // if single 5v instead a 3.3v supply otherwise skip
#define EADOGM_SPI_SW 1 // what mode
#define EADOGM_PIN_CSB PIN_C2  // /CS line, C2 is default if you skip this
#define EADOGM_PIN_RS PIN_C1  // RS line, C1 is default if you skip this
// if you want to use internal software SPI bit bang, other wise skip these
#define EADOGM_SCLK_BB PIN_C3 // C3 default for Bit Bang
#define EADOGM_MOSI_BB PIN_C5 // C5 default for Bit Bang
and in your program main()
   eaDogM_Initialize();
   eaDogM_DisplayOn();
   eaDogM_SetPos(0,0);
   eaDogM_WriteString("This is Row 0");
Ok, here is the code:
EA-DOGM_MIO.c
 *            file: EA-DOGM_MIO.c
 *         version: 2.01
 *     description: Multi I/O driver for EA DOGM displays
 *                : Uses 8Bit, SPI HW or SPI SW (bitbang)
 *     written by : Michael Bradley (mbradley@ontura.com)
 *   contributions: Imaginos (CCS forum), Emil Nad (8Bit testing)
 *   Changelog:
 *       11/25/2009 v2.01 Minor changes, replaced some functions with macros
 *       09/17/2009 v2.00 Major change, IO is now 8Bit or SPI (hw or sw)
 *                  rewrote some defines as related to pins
 *       09/15/2009 v1.13 added function eaDogM_WriteIntAtPos()
 *                  and eaDogM_WriteStringAtPos()
 *                  added some defines to clean source
 *       08/28/2009 v1.12 EADOGM_COLSPAN defined internaly, allowing for
 *                  162 model to position correcty (noted by Imaginos, CCS forum)
 *                  Added support for 2nd SPI HW port (suggested by Imaginos, CCS forum)
 *                  defined a few more special chr's
 *       07/12/2009 v1.11 Fixed #define error surrounding BB SPI ini
 *                  added eaDogM_ClearRow(row);
 *       07/11/2009 Created/Consolidated this file from my testing sets
 * Usage:
 *   In your source, you need to define which EA DOGM display you are using,
 *   there are 3 units supported EADOGM081 , EADOGM162 , EADOGM163 To use
 *   define with a 1.
 * #define EADOGM081 1  // to use MODEL EADOG081
 * #define EADOGM162 1  // to use MODEL EADOG162
 * #define EADOGM163 1  // to use MODEL EADOG163
 * #define EADOGMVDD  5   // 5v LCD Vdd
 * //#define EADOGMVDD  3   // 3.3v LCD Vdd
 * // we need to define the IO mode we want, select only one of these, set to 1
 * #define EADOGM_SPI_HW  1   // hw spi, uses on chip spi
 * #define EADOGM_SPI_HW2 1 // hw spi, 2nd on chip spi
 * #define EADOGM_SPI_SW  1   // sw bit bang, can use any io pins
 * #define EADOGM_8BIT    1 // 8 bit data bus
 * // for 8Bit mode only, we need to define the output port
 * // however, this can be our own function if need be.
 * // example shows output to port b
 * #define EADOGM_8BIT_PORT(d) output_b(d);   // we need to define how the byte goes out
 * //#define EADOGM_8BIT_PORT(d) your_func(d);   // we need to define how the byte goes out
 * // we need to define a few pins
 * #define EADOGM_PIN_RS  PIN_C1   // RS line, (pin 39 on the LCD)
 * #define EADOGM_PIN_CSB PIN_C2   // /CSB line, (pin 38 on the LCD) Req for SPI Opt for 8BIT
 * // for 8 bit mode, we need to define a few more pins
 * #define EADOGM_NOCSB 1         // set to 1 if pin 38 (CSB) on lcd is tied to Vss
 * #define EADOGM_PIN_E   PIN_C2   // E (pin 36 on the LCD)
 * #define EADOGM_PIN_RW  PIN_C6   // RW (pin 37 on the LCD)
 * // set these if you are using EADOGM_SPI_SW (bit bang)
 * #define EADOGM_SCLK_BB PIN_C3 // Connects to pin 29 on LCD
 * #define EADOGM_MOSI_BB PIN_C5 // Connects to pin 28 on LCD
 * #include "EA-DOGM_MIO.c"
 *    In your main code, do an ini call
 * eaDogM_Initialize();
 * eaDogM_DisplayOn();
 * Available Functions:
 *    eaDogM_Cls();                 // clears the screen, homes cursor
 *    eaDogM_ClearRow(row);         // clears a row (v1.11)
 *    eaDogM_CursorOn();            // turns on the cursor
 *    eaDogM_CursorOff();           // turns of the cursor
 *    eaDogM_DisplayOn();           // turns on display with cursor off
 *    eaDogM_DisplayOff();          // turns off display
 *    eaDogM_SetPos(row, col);      // sets position row:0-2, col:0-15
 *    eaDogM_WriteChr(byte);        // writes a single chr to the display
 *    eaDogM_WriteString(char str); // writes a string to the display
 *                                  // note: add this line after device selection
 *                                  // to do this: eaDogM_WriteString("Constant")
 *                                  //   #device PASS_STRINGS=IN_RAM
 *    // writes a 2 digit integer at row,col set flag = 1 to diable interrupts
 *    eaDogM_WriteIntAtPos(row,col,int[,flag])
 *    // writes a string at row,col set flag = 1 to diable interrupts
 *    eaDogM_WriteStringAtPos(row,col,char str[,flag])
 *    eaDogM_SetContrast(c);      // set contrast 0 to 15
 *    eaDogM_DoubleHeight(row);     // turn on double height, row = 0 or 1
 *    eaDogM_DoubleHeightOff();     // turn off double height
#ifndef EADOGM_SPI
   #define EADOGM_SPI 1
// some special symbol chrs defined
#define EADMSYM_DEG     0b11011111     // degree symbol
#define EADMSYM_DARWL   0b11111011     // double <<
#define EADMSYM_DARWR   0b11111100     // double >>
#define EADMSYM_LT      0b00111100     // less than <
#define EADMSYM_GT      0b00111110     // greater than >
#define EADMSYM_OHM     0b00011110     // ohm symbol
// some command defines
#define EADMCMD_CONTRAST 0b0111000      // contrast command (0b0111xxxx)
// we noticed some issues with GLOBAL on pic24 devices
#ifndef GLOBAL
  #define GLOBAL INTR_GLOBAL
// 1x16
#ifdef EADOGM081
   #define EADOGM_ROWS 1
   #if EADOGMVDD == 5
     #define EADOGM_INIT_BIAS_SET 0x1C
     #define EADOGM_INIT_POWER_CONTROL 0x51
     #define EADOGM_INIT_FOLLOWER_CONTROL 0x6A
     #define EADOGM_INIT_CONTRAST_SET 0x74
   #else
     #define EADOGM_INIT_BIAS_SET 0x14
     #define EADOGM_INIT_POWER_CONTROL 0x55
     #define EADOGM_INIT_FOLLOWER_CONTROL 0x6D
     #define EADOGM_INIT_CONTRAST_SET 0x7C
   #define EADOGM_INIT_FS1 0x31
   #define EADOGM_INIT_FS2 0x30
   #define EADOGM_INIT_CLEAR_DISPLAY 0x01
   #define EADOGM_INIT_ENTRY_MODE 0x06
   #define EADOGM_COLSPAN 16
// 2x16
#ifdef EADOGM162
   #define EADOGM_ROWS 2
    #if EADOGMVDD == 5
     #define EADOGM_INIT_POWER_CONTROL 0x52
     #define EADOGM_INIT_FOLLOWER_CONTROL 0x69
   #else
     #define EADOGM_INIT_CONTRAST_SET 0x78
   #define EADOGM_INIT_FS1 0x39
   #define EADOGM_INIT_FS2 0x38
   #define EADOGM_COLSPAN 40  // suggested that this be 40 on model 162
// 3x16
#ifdef EADOGM163
   #define EADOGM_ROWS 3
    #if EADOGMVDD == 5
     #define EADOGM_INIT_BIAS_SET 0x1D
     #define EADOGM_INIT_POWER_CONTROL 0x50
     #define EADOGM_INIT_FOLLOWER_CONTROL 0x6C
   #else
     #define EADOGM_INIT_BIAS_SET 0x15
     #define EADOGM_INIT_FOLLOWER_CONTROL 0x6E
     #define EADOGM_INIT_CONTRAST_SET 0x72
#define EADOGM_CMD_CLR 1
#define EADOGM_CMD_CURSOR_ON     0b00001111
#define EADOGM_CMD_CURSOR_OFF    0b00001100
#define EADOGM_CMD_DISPLAY_ON    0b00001100
#define EADOGM_CMD_DISPLAY_OFF   0b00001000
#define EADOGM_CMD_DDRAM_ADDR    0b10000000
#define EADOGM_CMD_SELECT_R0     0b00011000
#define EADOGM_CMD_SELECT_R1     0b00010000
#define EADOGM_CMD_SET_TABLE2    0b00101010
// sw spi emulation routine (bit bang)
#ifdef EADOGM_SPI_SW
   #ifndef EADOGM_SCLK_BB
   #ifndef EADOGM_MOSI_BB
void eaDogM_iniSPI_BB(void)
   output_drive(EADOGM_SCLK_BB);
   output_drive(EADOGM_MOSI_BB);
   output_low(EADOGM_SCLK_BB);
   output_low(EADOGM_MOSI_BB);
void eaDogM_spiWrite_BB(int8 regData)
  int1 bitOut;
  int8 SPICount;                               // Counter used to clock out the data
  int8 SPIData;                                // Define a data structure for the SPI data.
  output_low(EADOGM_SCLK_BB);                         // and CK low
  SPIData = regData;
  for (SPICount = 0; SPICount < 8; SPICount++) // Prepare to clock out the Address byte
    bitOut = bit_test(SPIData,7);
    output_bit(EADOGM_MOSI_BB,bitOut);
    output_high(EADOGM_SCLK_BB);                      // Toggle the clock line
    //delay_us(10);
    //delay_us(10);
    SPIData = SPIData << 1;                    // Rotate to get the next bit
    }                                          // and loop back to send the next bit
// wrapper for sw spi calls in main program
// v2.01 moved to macro define
#define eaDogM_outSPI(c) eaDogM_spiWrite_BB(c)
// wrapper for hw spi calls in main program
// v2.01 moved to a macro define
#ifdef EADOGM_SPI_HW
   #define eaDogM_outSPI(c) spi_write(c)
// wrapper for hw2 spi calls in main program
#ifdef EADOGM_SPI_HW2
   #define eaDogM_outSPI(c) spi_write2(c)
#ifdef EADOGM_8BIT
void eaDogM_ini8Bit(void)
#ifndef EADOGM_NOCSB
   output_drive(EADOGM_PIN_CSB);
   output_high(EADOGM_PIN_CSB);
   output_drive(EADOGM_PIN_E);
   output_drive(EADOGM_PIN_RW);
   output_drive(EADOGM_PIN_RS);
   output_low(EADOGM_PIN_E);
   output_low(EADOGM_PIN_RS);
   output_low(EADOGM_PIN_RW);
#ifdef EADOGM_8BIT
// 8bit mode
void eaDogM_WriteChr(char value)
   output_high(EADOGM_PIN_RS);
     output_low(EADOGM_PIN_CSB);
   output_high(EADOGM_PIN_E);
   delay_ms(1);
   EADOGM_8BIT_PORT(value);
   delay_ms(1);
   delay_ms(1);
void eaDogM_WriteCommand(int8 cmd)
   delay_ms(1);
   EADOGM_8BIT_PORT(cmd);
   delay_ms(1);
   delay_ms(1);
#else
// spi mode
   eaDogM_outSPI(value);
   delay_ms(1);
   eaDogM_outSPI(cmd);
   delay_ms(1);
void eaDogM_Initialize(void)
   eaDogM_iniSPI_BB();
#ifdef EADOGM_8BIT
   eaDogM_ini8Bit();
#else
   delay_ms(200);
   eaDogM_WriteCommand(EADOGM_INIT_FS1);
   eaDogM_WriteCommand(EADOGM_INIT_BIAS_SET);
   eaDogM_WriteCommand(EADOGM_INIT_POWER_CONTROL);
   eaDogM_WriteCommand(EADOGM_INIT_FOLLOWER_CONTROL);
   eaDogM_WriteCommand(EADOGM_INIT_CONTRAST_SET);
   eaDogM_WriteCommand(EADOGM_INIT_FS2);
   eaDogM_WriteCommand(EADOGM_INIT_CLEAR_DISPLAY);
   eaDogM_WriteCommand(EADOGM_INIT_ENTRY_MODE);
// sets contrast, call with a value from 0 to 15
// we also mask off upper 4 bits from c
#define eaDogM_SetContrast(c) eaDogM_WriteCommand(EADMCMD_CONTRAST + (c & 0b00001111))
// only tested on 3 line display at the moment,
// thus no constants defined. when fully tested, I will define them
void eaDogM_DoubleHeight(int8 row) // row 0 or 1
   eaDogM_WriteCommand(EADOGM_CMD_SET_TABLE2); // set instruction table 2
   if (row == 0) {
     eaDogM_WriteCommand(EADOGM_CMD_SELECT_R0); // select row 0
   if (row == 1) {
     eaDogM_WriteCommand(EADOGM_CMD_SELECT_R1); // select row 1
   eaDogM_WriteCommand(0b00101100); // turns on double line mode
                                    // and set instruction table back to 0
// v2.01 moved functions to macros
#define eaDogM_DoubleHeightOff() eaDogM_WriteCommand(0b00101000)
#define eaDogM_Cls()             eaDogM_WriteCommand(EADOGM_CMD_CLR)
#define eaDogM_CursorOn()        eaDogM_WriteCommand(EADOGM_CMD_CURSOR_ON)
#define eaDogM_CursorOff()       eaDogM_WriteCommand(EADOGM_CMD_CURSOR_OFF)
#define eaDogM_DisplayOn()       eaDogM_WriteCommand(EADOGM_CMD_DISPLAY_ON)
#define eaDogM_DisplayOff()      eaDogM_WriteCommand(EADOGM_CMD_DISPLAY_OFF)
void eaDogM_SetPos(int8 r, int8 c)
   int8 cmdPos;
   cmdPos = EADOGM_CMD_DDRAM_ADDR + (r * EADOGM_COLSPAN) + c;
   eaDogM_WriteCommand(cmdPos);
void eaDogM_ClearRow(int8 r)
   int8 i;
   eaDogM_SetPos(r,0);
   for(i=0; i<EADOGM_COLSPAN; i++) {
     eaDogM_WriteChr(' ');
void eaDogM_WriteString(char *strPtr)
   while (*strPtr != 0)
     eaDogM_WriteChr(*strPtr);
     strPtr++;
// Optional DisGIE, set to 1 to disable interrupts
// v1.4 -- provided by Imaginos
void eaDogM_WriteStringAtPos(int8 r, int8 c, char *strPtr, int1 DisGIE=0)
   if (DisGIE) {
      disable_interrupts(GLOBAL);
   eaDogM_WriteCommand((EADOGM_CMD_DDRAM_ADDR + (r * EADOGM_COLSPAN) + c));
      strPtr++;
   if (DisGIE) {
void eaDogM_WriteIntAtPos(int8 r, int8 c, int8 i, int1 DisGIE=0)
   if (DisGIE) {
   eaDogM_WriteChr(i/10+'0');
   eaDogM_WriteChr(i%10+'0');
   if (DisGIE) {
mbradley
PostPosted: Sun Jul 12, 2009 5:15 pm     Reply with quote
I am so sorry, I found a single error when moving this to another chip this morning.
EDIT: I didnt know I could edit a post, I made the corrections in the above listing.
This part should be changed:
eaDogM_iniSPI_BB();
To this:
#ifdef EADOGM_SPI_BB
eaDogM_iniSPI_BB();
yeti
PostPosted: Mon Sep 14, 2009 2:02 pm     Reply with quote
Hi, Bradley,
will you be so kind and tell me do you have experience with drive this display but over the normal I/0 port and on parallel 8-bit port? Can you see if your driver is accptable for DOG162M , 3V, PIC24FJ?
Thanks in advance..
Zdenko
eaDogM_iniSPI_BB();
To this:
eaDogM_iniSPI_BB();
mbradley
PostPosted: Mon Sep 21, 2009 12:56 am     Reply with quote
the updated driver v2.00 now works with DOG162M , 3V, PIC24FJ over 8bit
yeti
PostPosted: Mon Sep 21, 2009 1:18 am     Reply with quote
Where I can find this new version v2.00. I didn't find any attachment in your post?
Regards
Zdenko
mbradley
PostPosted: Tue Sep 22, 2009 1:53 am     Reply with quote
v2.00 is in the main post, instead of adding all the bug fixes and updates to a really long post and having things scattered, I decided to edit and always update the source in the first post.
mbradley
PostPosted: Wed Dec 02, 2009 11:02 pm     Reply with quote
This driver is now hosted, and maintained at the following:
http://www.mculabs.com/drivers/eadogm.html
Michael Bradley
www.mculabs.com
Open Drivers and Projects
luciano_schirmer
PostPosted: Sun Feb 09, 2014 9:11 pm     Reply with quote
Hello mbradley,
Thanks for posting the code, it was really helpful. Actually I needed a 4Bit version, so I dove in your code and adapted to work with 4Bit mode also.
Example for 4Bit mode:
#define EADOGM_4BIT     1        // 4Bit tmode
#define EADOGM_PIN_E    PIN_D3   // E line (pin 36 on the LCD)
#define EADOGM_PIN_RW   PIN_D2   // RW line (pin 37 on the LCD)
#define EADOGM_PIN_RS   PIN_D1   // RS line (pin 39 on the LCD)
#define EADOGM_DATA4    PIN_D4
#define EADOGM_DATA5    PIN_D5
#define EADOGM_DATA6    PIN_D6
#define EADOGM_DATA7    PIN_D7
#include "ea-dogm_mio.c"
Modified code for EA-DOGM_CIO.C:
 *         version: 2.03a (unofficial)
 *                : Uses 8Bit, 4Bit, SPI HW or SPI SW (bitbang)
 *     written by : Michael Bradley (mbradley@mculabs.com)
 *                  jgschmidt (CCS forum)
 *    modified by : Eng. Luciano Schirmer (luciano.igtech@gmail.com)
 *   Changelog:
 *       02/08/2014 v2.03a added 4Bit mode (Eng. Luciano Schirmer)
 *       04/22/2010 v2.03 Minor update, changed EADOGM_SPI_HW for HW SPI 1 and 2
 *                  Added setup_spi() for HW SPI use, and spi_clk_div option
 *                  thanks to jgschmidt (ccs forum) for noticing hw setup issues
 *       12/03/2009 v2.02 bug fix and printChr change, no user change needed for use
 *       08/28/2009 v1.12 EADOGM_COLSPAN defined internally, allowing for
 *                  162 model to position correctly (noted by Imaginos, CCS forum)
 * Usage:
 *   define with a 1.
 * #define EADOGM_SPI_HW  2   // hw spi, 2nd on chip spi
 * #define EADOGM_SPI_DIV SPI_CLK_DIV_64 // used to slow hw spi clock (you can use other constants)
 * #define EADOGM_4BIT    1   // 4 bit data bus
 * // for 4/8 bit mode, we need to define a few more pins
 * // set these if you are using EADOGM_4BIT
 * #define EADOGM_DATA4 PIN_D4
 * #define EADOGM_DATA5 PIN_D5
 * #define EADOGM_DATA6 PIN_D6
 * #define EADOGM_DATA7 PIN_D7
 *    // writes a 2 digit integer at row,col set flag = 1 to disable interrupts
 *    // writes a string at row,col set flag = 1 to disable interrupts
#ifndef EADOGM_SPI
#ifndef GLOBAL
// 1x16
#ifdef EADOGM081
   #if EADOGMVDD == 5
   #else
   #ifdef EADOGM_4BIT
     #define EADOGM_INIT_FS1 0x21
     #define EADOGM_INIT_FS2 0x20
   #else
// 2x16
#ifdef EADOGM162
    #if EADOGMVDD == 5
   #else
   #ifdef EADOGM_4BIT
     #define EADOGM_INIT_FS1 0x29
     #define EADOGM_INIT_FS2 0x28
   #else
// 3x16
#ifdef EADOGM163
    #if EADOGMVDD == 5
   #else
   #ifdef EADOGM_4BIT
   #else
#define EADOGM_CMD_CGRAM_ADDR    0b01000000
// spi hw clock div, v2.03 fix
#ifndef EADOGM_SPI_DIV
   #define EADOGM_SPI_DIV SPI_CLK_DIV_4
  int1 bitOut;
  SPIData = regData;
    //delay_us(10);
    //delay_us(10);
#if EADOGM_SPI_HW == 1
// v2.01 moved to a macro define, v2.03 using EADOGM_SPI_HW to test condition
#if EADOGM_SPI_HW == 2
#if (defined(EADOGM_4BIT) || defined(EADOGM_8BIT))
   #ifdef EADOGM_4BIT
   output_drive(EADOGM_DATA4);
   output_drive(EADOGM_DATA5);
   output_drive(EADOGM_DATA6);
   output_drive(EADOGM_DATA7);
   #ifdef EADOGM_4BIT
   output_low(EADOGM_DATA4);
   output_low(EADOGM_DATA5);
   output_low(EADOGM_DATA6);
   output_low(EADOGM_DATA7);
#if defined(EADOGM_8BIT)
// 8bit mode
   delay_ms(1);
   delay_ms(1);
   delay_ms(1);
   delay_ms(1);
   delay_ms(1);
   delay_ms(1);
#elif defined(EADOGM_4BIT)
// 4bit mode
void eaDogM_WriteNibble(int8 value)
   output_bit(EADOGM_DATA4, bit_test(value, 4));
   output_bit(EADOGM_DATA5, bit_test(value, 5));
   output_bit(EADOGM_DATA6, bit_test(value, 6));
   output_bit(EADOGM_DATA7, bit_test(value, 7));
   delay_cycles(1);
   delay_us(2);
   eaDogM_WriteNibble(value);
   eaDogM_WriteNibble(value<<4);
   delay_us(10);
   eaDogM_WriteNibble(cmd);
   eaDogM_WriteNibble(cmd<<4);
   delay_ms(1);
#else
// spi mode
   delay_ms(1);
   eaDogM_outSPI(cmd);
   delay_ms(1);
#ifdef EADOGM_4BIT
    int i;
// v2.03 fix
   setup_spi( SPI_MASTER | SPI_H_TO_L | EADOGM_SPI_DIV );
// v2.03 fix
   setup_spi2( SPI_MASTER | SPI_H_TO_L | EADOGM_SPI_DIV );
   eaDogM_iniSPI_BB();
   eaDogM_ini8Bit();
#else
   delay_ms(200);
#ifdef EADOGM_4BIT
   for(i=1;i<=3;++i)
      eaDogM_WriteNibble(0x30);
      delay_ms(5);
   eaDogM_WriteNibble(0x20);
   delay_ms(5);
   if (row == 0) {
   if (row == 1) {
   int8 cmdPos;
   int8 i;
   eaDogM_SetPos(r,0);
   printf(eaDogM_WriteChr,"%s",strPtr);
   if (DisGIE) {
   if (DisGIE) {
   if (DisGIE) {
   if (DisGIE) {
// this writes a byte to the internal CGRAM (v2.02)
// format for ndx: 00CCCRRR = CCC = character 0 to 7, RRR = row 0 to 7
void eaDogM_WriteByteToCGRAM(char ndx, char data)
   unsigned int cmd;
   cmd = ndx & 0b00111111; // mask off upper to bits
   cmd = cmd | EADOGM_CMD_CGRAM_ADDR; // set bit cmd bits
   eaDogM_WriteCommand(cmd);
   eaDogM_WriteChr(data);
   // this is done to make sure we are back in data mode
   eaDogM_SetPos(0,0);
I tested the code and it works great in 4Bit, 8Bit and SPI SW (all running in 3.3V). I just didn't test the SPI HW mode. I tested with a PIC18F45K80 and a PIC18F45K20 (Pik Kit Demo Board, PCH Compiler).
Images:
https://db.tt/jDBSAIYz
https://db.tt/7XE3Egjd
mbradley
PostPosted: Sun Feb 09, 2014 11:12 pm     Reply with quote
That's awesome, I am happy to see someone add to it...
I will implement your changes into my main source, and give you credit as well!
main source:
Michael Bradley
www.mculabs.com
luciano_schirmer
PostPosted: Mon Feb 10, 2014 7:04 am     Reply with quote
I feel happy to contribute. Thanks for the credit.
I also noticed that the eaDogM_WriteCommand function needs a 1ms time between commands, but the eaDogM_WriteChr worked with as low as 5us, so I reduced the delay in my 4Bit mode to 10us. I think this reduced time may work with the other modes too.
This matters when you want to write a full 3x16 display in one single step without hanging your main loop for 48ms.
main source:
