bruin Guest
CCS ZigBee/ Ember board- sleepy mode current draw |
Posted: Fri Jul 03, 2009 8:38 pm |
I'm trying to reduce the average current draw of the "sleepy" sensor portion of the CCS ZigBee development kit. Right now it's drawing around 7-10mA on average, even if I stop calling any of the ember functions. I suspect the chip itself has some timer which calls the coordinator periodically. How do I change this?
Am I supposed to do something in particular to put the EM260 to sleep? The EM260 chip is supposed to draw very little current in sleep, so I suspect I have to do something besides #define this is a sleepy sensor.
Thanks! |
bruin Guest
getting closer... still not there |
Posted: Mon Jul 06, 2009 8:05 am |
I've figured out if I make NO_SLEEP 1 (make the device sleep after each command), I can make the device sleep - but the wireless connection no longer works (push the button to make the display increment). NO_SLEEP is used in EM260SendCommand.
If I make a new function such that EZSP_FRAME_CONTROL_INDEX is 1 only when the button is pressed, as below, but is 0 for sensorApplicationTick() and EM260Tick() commands, I don't get any current savings, but the button pushed/ increment function works.
Any help/ examples out there?
Thanks!
Code: | while(TRUE)
sensorApplicationTick();
EM260Tick();
if(!input(PUSH_BUTTON1))
i++;
messagedata[0]=i;
ezspSendUnicastSleep(EMBER_OUTGOING_DIRECT,indexOrDestination,&apsframe,messagetag,messageLength,&messagedata[0]);
if(!input(PUSH_BUTTON2))
i--;
messagedata[0]=i;
//delay_ms(200);
bruin Guest
modified... still not there |
Posted: Mon Jul 06, 2009 10:49 am |
I have modified the code, where I send a NOP command and that NOP calls the EM260SendCommand with the EM260SpiBuffer[EZSP_FRAME_CONTROL_INDEX]= 0x01;
The current on the Ember board is 3.8mA, which seems awfully high considering the deep sleep mode is supposed to draw 1uA.
Thanks!
while(true)
for(ii=0;ii<1;++ii)
EM260Tick();
i++;
messagedata[0]=i;
ezspSendUnicast(EMBER_OUTGOING_DIRECT,indexOrDestination,&apsframe,messagetag,messageLength,&messagedata[0]);
ezsp_response();
ezspNop();
while(input(PUSH_BUTTON1));
