Problem with strings
pictastic
PostPosted: Sat Jul 04, 2009 3:48 pm     Reply with quote
I'm trying to port some code from another complier to CCS and I'm struggling to get anywhere. Any ideas what is going wrong?
Code segment below which doesn't compile. I'm using CCS version 4.084.
/* Context definitions */
static char Anything[] = "";
static char Nothing[] = " ";
/* Phoneme definitions */
static char Pause[] = " ";
static char Silent[] = "";
#define LEFT_PART   0
#define MATCH_PART   1
#define RIGHT_PART   2
#define OUT_PART   3
typedef char *Rule[4];   /* Rule is an array of 4 character pointers */
/*0 = Punctuation */
**   LEFT_PART   MATCH_PART   RIGHT_PART   OUT_PART
static Rule punct_rules[] =
   {Anything,   " ",      Anything,   Pause   },
   {Anything,   "-",      Anything,   Silent   },
   {".",      "'S",      Anything,   "z"   },
   {"#:.E",   "'S",      Anything,   "z"   },
   {"#",      "'S",      Anything,   "z"   },
   {Anything,   "'",      Anything,   Silent   },
   {Anything,   ",",      Anything,   Pause   },
   {Anything,   ".",      Anything,   Pause   },
   {Anything,   "?",      Anything,   Pause   },
   {Anything,   "!",      Anything,   Pause   },
   {Anything,   0,      Anything,   Silent   },
PICs do more than washing machines...
PostPosted: Sat Jul 04, 2009 5:31 pm     Reply with quote
1. Always post your PIC.
2. Preferably, put that code into a test program. Just a minimal program
would have the #include for the PIC, #fuses, #use delay, and a main().
Put that code either above main() or in it (whichever is applicable).
3. Compile the test program and post the error messages.
pictastic
Problem with strings (full code)
PostPosted: Sun Jul 05, 2009 6:40 am     Reply with quote
Full listing of the code below. The .h file is first followed by the main code.
Compilation gives bad expression syntax at the commented line followed by numerous "Expecting a declaration" and "Expecting a (" errors. The main code does nothing at all. It the is declaration of the types and arrays that give the problems. The code is for the 18LF14k50 chip.
#include <18LF14K50.h>
#device adc=8
#FUSES WDT128                   //Watch Dog Timer uses 1:128 Postscale
#FUSES INTRC_IO                 //Internal RC Osc, no CLKOUT
#FUSES FCMEN                    //Fail-safe clock monitor enabled
#FUSES BORV19
#FUSES NOXINST                  //Extended set extension and Indexed Addressing mode disabled (Legacy mode)
#FUSES NOWRTD                   //Data EEPROM not write protected
#FUSES NOWRTC                   //configuration not registers write protected
#FUSES NOEBTR                   //Memory not protected from table reads
#FUSES NOEBTRB                  //Boot block not protected from table reads
#FUSES MCLR                     //Master Clear pin enabled
#FUSES NOCPB                    //No Boot Block code protection
#FUSES NOWRTB                   //Boot block not write protected
#FUSES NOHFOFST
#FUSES WRT0
#FUSES WRT1
#FUSES USBDIV2
#FUSES PCLKEN
#FUSES BBSIZ2K                  //2K words Boot Block size
#FUSES PLLEN
#FUSES CPUDIV4                  //System Clock by 4
#use delay(clock=8000000)
// End of the t2p.h file
// Start of the main code
#include "C:\Program Files\PICC\Projects\t2p.h"
#include <string.h>
   setup_adc_ports(ALL_ANALOG|VSS_VDD);
   setup_spi(SPI_SS_DISABLED);
   setup_wdt(WDT_OFF);
   setup_timer_0(RTCC_INTERNAL);
   setup_timer_1(T1_DISABLED);
   setup_comparator(NC_NC_NC);// This device COMP currently not supported by the PICWizard
   setup_oscillator(OSC_8MHZ|OSC_TIMER1);
   // TODO: USER CODE!!
static char Anything[] = "";   /* No context requirement */
static char Nothing[] = " ";   /* Context is beginning or end of word */
static char Pause[] = " ";   /* Short silence */
static char Silent[] = "";   /* No phonemes */
#define LEFT_PART   0
#define OUT_PART   3
const Rule punct_rules[] =
   {Anything,   " ",      Anything,   Pause   }, //Bad expression syntax here
PostPosted: Sun Jul 05, 2009 2:30 pm     Reply with quote
To solve this problem, I stripped it down and made a test program.
I was able to make it work by moving the storage allocations for
the strings so they are outside of the array. Then the initialization
only consists of pointers to the strings. That got rid of the compiler
error messages.
Here's the output of the program below:
A AP
A-AS
.'SAz
#:.E'SAz
#'SAz
A'AS
A,AP
A.AP
A?AP
A!AP
AAAS
Here's the test program. In some cases where you had empty strings
or spaces, I put in character instead, so I could see the output.
#include <18F452.h>
#fuses XT,NOWDT,PUT,NOBROWNOUT
#use rs232(baud=9600,xmit=PIN_C6,rcv=PIN_C7,ERRORS)
static char Anything[] = "A";
static char Nothing[] = "N";
static char Pause[] = "P";
static char Silent[] = "S";
char dash[] = {"-"};
char space[] = {" "};
char period[] = {"."};
char comma[] = {","};
char question_mark[] = {"?"};
char exclamation_point[] = {"!"};
char pound_sign[] = {"#"};
char apostrophe[] = {"'"};
char apostrophe_S[] = {"'S"};
char z[] = {"z"};
char special[] = {"#:.E"};
Rule punct_rules[11] =
   {Anything,   space,         Anything,     Pause  },
   {Anything,   dash,          Anything,     Silent },
   {period,     apostrophe_S,  Anything,     z      },
   {special,    apostrophe_S,  Anything,     z      },
   {pound_sign, apostrophe_S,  Anything,     z      },
   {Anything,   apostrophe,    Anything,     Silent },
   {Anything,   comma,         Anything,     Pause },
   {Anything,   period,        Anything,     Pause },
   {Anything,   question_mark, Anything,     Pause },
   {Anything,   exclamation_point, Anything, Pause },
   {Anything,   Anything,      Anything,     Silent},
int8 row, col;
for(row=0; row<11; row++)
    for(col=0; col<4; col++)
        printf(punct_rules[row][col]);
    printf("\r");
PostPosted: Sun Jul 05, 2009 3:00 pm     Reply with quote
I'd 'suspect', that the compiler automatically treats strings inside a declaration as 'constant', till the moment they are actually allocated RAM, by putting them into an array. Works if you declare them as character arrays first, but since they haven't yet been put into RAM, the compiler won't accept trying to generate a pointer to them.....
pictastic
PostPosted: Sun Jul 05, 2009 3:22 pm     Reply with quote
Cool Cool
Many thanks for the help guys!!
