PIC18F44K20 64 Mhz
Evan Griffith
PIC18F44K20 64 Mhz
PostPosted: Wed Jun 24, 2009 6:37 pm     Reply with quote
I am trying to set up the PIC18F44K20 to run at 64 Mhz using the internal OSC. I know I have to set it to HS and I am doing so in the #fuse section. But after that I am a little confused as to how I should be setting the registers. I currently am using #byte to set the OSCTUNE and OSCCON registers in the beginning. Anyone have experience doing this?
Thanks!
PostPosted: Thu Jun 25, 2009 2:14 am     Reply with quote
Use the method shown in this program, except change the #use delay()
value and the setup_oscillator() constant to 64 MHz.
http://www.ccsinfo.com/forum/viewtopic.php?t=38761&start=1
Evan Griffith
PIC18F44K20 64 Mhz
PostPosted: Mon Jun 29, 2009 11:18 am     Reply with quote
Thanks for the reply. I am trying to program the pic with the code but I am running into issues with CCSLOAD, it does not see my PIC. Arg.
