No ACK from Slave (I2C communication PIC16f1459 & LM75)
adda
PostPosted: Mon Oct 12, 2015 9:37 am     Reply with quote
I am unable to receive an ACK from the slave. I send the initial address with write bit, but do not get an acknowledgement.
--main.c
 #include <xc.h>
#include <stdlib.h>
#include "I2C.h"
#define CDC_DATA_OUT_EP_SIZE    64
#define CDC_DATA_IN_EP_SIZE     64
#define _XTAL_FREQ 32000000
unsigned char Byte1;
    unsigned char Byte2;
    unsigned int Int1;
unsigned char readBuffer[CDC_DATA_IN_EP_SIZE];
       I2CInit();
      //  __delay_ms(5);
        I2CStart();
      //  __delay_ms(5);
        //I2CWait();
        I2CSend(0x48|0x27);
        I2CAck();
        I2CSend(0x00);
        I2CAck();
        I2CRestart();
        I2CSend(0x49|0x27);
        I2CAck();
        Byte1 = I2CRead();
        I2CNak();
        I2CStop();
I2C lib
/** INCLUDES *******************************************************/
#include <xc.h>
#include <stdlib.h>
#include <stdint.h>
#include <string.h>
#include <stddef.h>
#include "I2C.h"
#define BUFF_SIZE 64
#define SDA     TRISBbits.TRISB4 // I2C bus
#define SCL     TRISBbits.TRISB6 //
#define SCL_IN  PORTBbits.RB6    //
#define SDA_IN  PORTBbits.RB4    //
/** VARIABLES ******************************************************/
typedef struct buffer{
    float buff[BUFF_SIZE];
    int readIndex;
    int writeIndex;
}buffer;
static char buttonMessage[] = "Button pressed.\r\n";
static char buttonMessage2[] = "Button pressed2.\r\n";
static uint8_t readBuffer[CDC_DATA_OUT_EP_SIZE];
static uint8_t writeBuffer[CDC_DATA_IN_EP_SIZE];
unsigned char readBuffer1[CDC_DATA_IN_EP_SIZE];
    unsigned int Int1;
    float float1;
/*I2C Implementation*/
    void I2CInit(void)
      SDA = 1;
    SCL = 1;
    SDA_IN = 0;
    SCL_IN = 0;
    SSPADDbits.SSPADD = 0x8;
   SSPSTAT = 0xA8;//0b10101000;      //No slew rate
    SSPADD = 0x27;
   SSPCON1bits.SSPM = 0x08;
   SSPCON1 = 0x28;
   SSPSTATbits.SMP = 1;
   SSPSTATbits.CKE = 0;
      //Disable SMBus inputs
  // SSPADD = 0x27;         //100 KHz
 //   SSPCON1 = 0b00101000;  //I2C Master mode
   SSPCON3 = 0x00;  //Rien de slave
Function: I2CStart
Return:
Arguments:
Description: Send a start condition on I2C Bus
void I2CStart()
   SSPCON2bits.SEN = 1;         /* Start condition enabled */
   //while(SSPCON2bits.SEN);      /* automatically cleared by hardware */
    //LATCbits.LATC0 = 1;                 /* wait for start condition to finish */
Function: I2CStop
Return:
Arguments:
Description: Send a stop condition on I2C Bus
void I2CStop()
   SSPCON2bits.PEN = 1;         /* Stop condition enabled */
   //while(SSPCON2bits.PEN);      /* Wait for stop condition to finish */
    LATCbits.LATC0 = 1;                /* PEN automatically cleared by hardware */
Function: I2CRestart
Return:
Arguments:
Description: Sends a repeated start condition on I2C Bus
void I2CRestart()
   SSPCON2bits.RSEN = 1;        /* Repeated start enabled */
   //while(SSPCON2bits.RSEN);     /* wait for condition to finish */
Function: I2CAck
Return:
Arguments:
Description: Generates acknowledge for a transfer
void I2CAck()
   SSPCON2bits.ACKDT = 0;       /* Acknowledge data bit, 0 = ACK */
   SSPCON2bits.ACKEN = 1;       /* Ack data enabled */
   //while(SSPCON2bits.ACKEN);  /* wait for ack data to send on bus */
Function: I2CNck
Return:
Arguments:
Description: Generates Not-acknowledge for a transfer
void I2CNak()
   SSPCON2bits.ACKDT = 1;       /* Acknowledge data bit, 1 = NAK */
Function: I2CWait
Return:
Arguments:
Description: wait for transfer to finish
void I2CWait()
   while ((SSPCON2 == 0x1F ) || ( SSPSTAT == 0x04 ) );
    /* wait for any pending transfer */
Function: I2CSend
Return:
Arguments: dat - 8-bit data to be sent on bus
           data can be either address/data byte
Description: Send 8-bit data on I2C bus
void I2CSend(unsigned char dat)
   SSPBUF = dat;    /* Move data to SSPBUF */
   //while(BF);       /* wait till complete data is sent from buffer */
   I2CWait();       /* wait for any pending transfer */
Function: I2CRead
Return:    8-bit data read from I2C bus
Arguments:
Description: read 8-bit data from I2C bus
unsigned char I2CRead(void)
   unsigned char temp;
/* Reception works if transfer is initiated in read mode */
   SSPCON2bits.RCEN = 1;        /* Enable data reception */
   //while(!SSPSTATbits.BF);      /* wait for buffer full */
   temp = SSPBUF;   /* Read serial buffer and store in temp register */
   I2CWait();       /* wait to check any pending transfer */
   return temp;     /* Return the read data from bus */
/*end implementation functions*/
PostPosted: Mon Oct 12, 2015 9:47 am     Reply with quote
#include <xc.h>
This is XC8 code. You're on the wrong forum. Every PIC C compiler
has its own forum. Try these two forums:
Microchip XC8 forum:
http://www.microchip.com/forums/f249.aspx
Microchip i2c forum:
http://www.microchip.com/forums/f10.aspx
