how to transmit data in spi slave mode?
Goto page Previous  1, 2, 3, 4  Next
PostPosted: Wed Mar 16, 2011 3:13 am     Reply with quote
hayee wrote:
PCM Programmer
Its pin #7 of 18f252. /SS
I have change the hardware from A0 to A5 on slave side, but I am not using that pin in the slave software, so will it work without declaring that pin? Is it necessary to change the pin of master from A0 to A5?
Slave select, is _enabled by default_ on slave devices.
It is possible to run SPI without slave select, _but_ very likely to go wrong, and makes code hard to ensure a resynchronise takes place, if a bit is missed. Your code is currently using SS, and won't work without it....
hayee
PostPosted: Wed Mar 16, 2011 4:53 am     Reply with quote
This code is not working
Master
#include <18f252.h>
#fuses HS,NOWDT,NOLVP,PUT,NOBROWNOUT,protect
#use delay(clock=20000000)
#use rs232(xmit=PIN_C6, rcv=PIN_C7, baud=9600)
#define SPI_SS PIN_A5
char c;
int result;
 output_high(SPI_SS);
 setup_spi(SPI_MASTER | SPI_MODE_0 | SPI_CLK_DIV_4);
 setup_adc_ports(NO_ANALOGS);
  c=getc();
  c=toupper(c);
  switch(c)
   case 'A':
   output_low(SPI_SS);
   spi_write(1);
   delay_us(100);
   output_low(SPI_SS);
   result=spi_read(0);
   printf("value =%u\r\n",result);
   case 'B':
   output_low(SPI_SS);
   spi_write(2);
   delay_us(100);
   output_low(SPI_SS);
   result=spi_read(0);
   case 'C':
   output_low(SPI_SS);
   spi_write(3);
   delay_us(100);
   output_low(SPI_SS);
   result=spi_read(0);
Slave
#include <18f252.h>
#byte SSPBUF = 0xFC9//register value for 18f252
int counter;
int buffer;
#int_ssp
void ssp_isr(void)
 int command;
 command=SSPBUF;
 switch(command)
  case 1:
  SSPBUF=5;
  case 2:
  SSPBUF=46;
  case 3:
  SSPBUF=12;
 output_toggle(PIN_C0);
 setup_spi(SPI_SLAVE | SPI_MODE_0);
 clear_interrupt(INT_SSP);
 enable_interrupts(INT_SSP);
But this code is working
Master
#include <18f252.h>
int counter;
  counter++;
  output_low(SPI_SS);
  spi_write(counter);
  delay_ms(2000);
Slave
#include <18f252.h>
//#byte SSPBUF = 0xFC9//register value for 18f252
int counter;
int buffer;
#int_ssp
void ssp_isr(void)
 buffer=spi_read();
  if(counter==1)
  printf("buffer=%u",buffer);
  counter=0;
Dont know what is happening, where i am wrong?
nahumof
PostPosted: Wed Apr 13, 2011 6:25 pm     Reply with quote
whats the advantage to use directly the register SSPBUF like the program of PCM (for select comands) instead use read spi and write spi
tks Very Happy
PostPosted: Thu Apr 14, 2011 2:12 pm     Reply with quote
You are right. The .LST file shown below shows that calling spi_read()
and reading SSPBUF directly, both produce the same code:
.................... #int_ssp
.................... void ssp_isr(void)
....................  int command;
....................  command=SSPBUF;
00AE:  MOVFF  SSPBUF,command
....................  command=spi_read();
00B2:  MOVFF  SSPBUF,command
nahumof
PostPosted: Thu Apr 14, 2011 3:33 pm     Reply with quote
jejeje good to know Very Happy
tks pcm
PostPosted: Fri Apr 15, 2011 1:58 am     Reply with quote
If you go 'back in time', the functions differed, with the compiler SPI_READ always checking the data available bit before reading. Sensible if using the code in a main program, but pointless in an ISR, where the ISR triggering implies that a byte has been clocked in. Hence people wanting to avoid the extra test talked directly to the registers. It appears that at some point the compiler behaviour has been improved in this regard.
nahumof
PostPosted: Fri Apr 15, 2011 9:05 am     Reply with quote
so if I'm going to use ISR the best thing to do is work with the register directly...
I GET THIS .LST!!!
ISR SPI READ
........................char a;
.....................   a=spi_read();
0035:  MOVF   13,W
0036:  BSF    03.5
0037:  MOVWF  2C
ISR USING SSPBUF
....................   char a;
....................   a=SSPBUF;
0035:  MOVF   13,W
0036:  BSF    03.5
0037:  MOVWF  2C
SSPBUF IN MAIN without ISR
....................  while(true)
..........................char a;
.......................   a=SSPBUF;
035F:  MOVF   13,W
0360:  MOVWF  72
SPI_READ IN MAIIN without ISR
....................    {char a;
035F:  MOVF   13,W
0360:  MOVWF  72
to me looks like the same... I'm wrong?
...where is sspbuf? ... Question
PostPosted: Fri Apr 15, 2011 9:13 am     Reply with quote
No, as I said 'if you go back in time'. The early spi_read function tested the BF bit. CCS have dropped this, probably when they added the 'spi_data_is_in' function, so that you have the _option_ to test the bit if you want. As now coded, the spi_read is identical to the direct read.
It was an annoyance in the early days when trying to code a SPI ISR, hence a lot of people took the safe route, and went to direct register I/O.
nahumof
PostPosted: Fri Apr 15, 2011 9:17 am     Reply with quote
ok tks Very Happy
nahumof
mmm
PostPosted: Wed May 11, 2011 7:55 pm     Reply with quote
Hi I had to rebuild my circuit because I was using 2 PIC'S comunicating with software SPI, after a few bumps I get the answer. There is no way to get a software slave spi!!! using #use_SPI.
So I rebuild my slave for use hardware SPI. I connect to my software master SPI and now I realize that I have to waste one byte to get an answer from slave HW SPI!!! I just don't get it... Sad
I got 2 questions for you:
1.- There is any way to set the speed of my master SPI with #use_spi besides the baud rate?
2.- There is a way to send a byte from master get in slave and return to the answer to the master in one instruction? Or always I have to sent a dummy byte?
master
#include <18f4550.h>
#fuses HS,NOPUT,NOMCLR,NOWDT,NOPROTECT,NOLVP,NODEBUG,NOUSBDIV,PLL1,CPUDIV1,NOVREGEN
#use delay(clock=8000000)
#use spi(DO=PIN_D6,DI=PIN_D5,CLK=PIN_D4,MODE=0,BITS=8,MSB_FIRST)
#define SPI_SS PIN_C0
void inicializar()
  set_tris_d(0b00100000);
  set_tris_c(0b00000000);
  delay_us(100);
  output_low(PIN_D4);
  output_low(PIN_D6);
  output_float(PIN_D5);
  int a=0;
  int ret;
  inicializar();
  while(true)
    output_LOW(SPI_SS);
    SPI_XFER(0);                         //dumy waste of time!!!
    output_HIGH(SPI_SS);
    delay_us(200);
    output_LOW(SPI_SS);
    ret=SPI_XFER(a);                  //usefull data in and out!!!
slave
#include <16f876A.h>
#device ADC=8
#fuses HS,NOWDT,NOPROTECT,NOLVP,NODEBUG
#byte SSPBUF=0x13
#define SPI_MODE_0_0 0x4000
#int_ssp
void ssp_isr(void)
  int comando;
  static int count;
  comando=SSPBUF;   //also i use comando=spi_read(count)
  count++;                                                //geting wrong data!!!
  SSPBUF=count;
inicializacion()
  // habilita iterrupcion por spi
  // Initialize the hardware SSP for SPI Slave mode.
  setup_spi(SPI_SLAVE |SPI_L_TO_H|SPI_XMIT_L_TO_H);
  inicializacion();
  while(true)
result
any help wold be great!!!
nahumof
PostPosted: Wed May 11, 2011 8:36 pm     Reply with quote
i need to return the same data i'm sending
i also try with spi_read();
with no results... Sad
PostPosted: Wed May 11, 2011 9:32 pm     Reply with quote
I don't see any method of setting the baud rate listed in the manual
for #use spi, except for the BAUD=n method.
I don't use the #use spi() method for hardware SPI. I use setup_spi().
dummy byte?
I need to return the same data i'm sending
with no results
spi_read(); won't clock in any data to the Master. You need to give it a
parameter to make the Master generate the clock (SCLK).
For example, the line below will transmit a 0x00 byte to the slave, and it
will force the slave to transmit the byte in it's buffer to the master.
result = spi_read(0);
SPI is just two shift registers. The master has one, and the slave has
one. There is no way get back the transmitted data with just 8 clocks
from the master. It would take 16 clocks, total. Look at this diagram
http://en.wikipedia.org/wiki/Serial_Peripheral_Interface_Bus#Data_transmission
Here is another diagram of the two SPI shift registers:
http://elm-chan.org/docs/spi_e.html
Here is an SPI tutorial from Microchip:
http://ww1.microchip.com/downloads/en/devicedoc/spi.pdf
nahumof
PostPosted: Thu May 12, 2011 10:52 am     Reply with quote
tks for the answer and the info
and yes i understoot everything you say but:
the master send 0xff
a=spi_xfer(0xff);
and the slave get the 0xff and save into resp and return 0x05 to the master:
resp=spi_read(0x05);
what is the result for a? i guess it should be 0x05?
I'm not getting 0x05!!! my code is wrong?
slave
#device ADC=8
#byte SSPBUF=0x13
int resp;
#int_ssp
void ssp_isr(void)
inicializacion()
  setup_spi(SPI_SLAVE |SPI_MODE_0_0);
  inicializacion();
  while(true)
master
#define SPI_SS PIN_C6
#byte porta=0xf80
#byte portb=0xf81
#byte portc=0xf82
#byte portd=0xf83
void inicializar()
  delay_us(100);
  output_low(PIN_D4);
  output_low(PIN_D6);
  int a;
  inicializar();
  while(true)
      output_LOW(SPI_SS);
      a=SPI_XFER(0xff);
      delay_ms(2000);
wrong result??? Question[/code]
thanks
PostPosted: Thu May 12, 2011 6:15 pm     Reply with quote
I note the problems. I'm still working on it.
nahumof
PostPosted: Fri May 13, 2011 9:56 am     Reply with quote
ok PCM tks
well after a few test i discover that my program send a byte (0x0f)to the slave and save a returning byte in B:
B=SPI_XFER(0x0f);
i receive the byte in the slave and return the same to master
a=SSPBUF;
when this happen i receive the half of whatever i send...
if i send 0x0f i get 0x07
if i send 0x08 i get 0x04
if i send 0x02 i get 0x01
only if i send 0xfx i get f something wrong
if i send 0xf0 i get 0xf8
i don't know what is causing this? maybe a configuration? speed?compiler?
some help would be great
Page 3 of 4
