24LC256.c multi page and multi chip write
treitmey
PostPosted: Thu Jun 04, 2009 10:43 am     Reply with quote
This driver is designed to look at multiple I2C chips as one large address space. And the multi-write driver spans the 64 byte boundary and the chip boundary.
//  Name   : 24CLC256.c                                                  //
//  Author : Timothy Reitmeyer                                           //
//  Date   : 06/04/2009                                                  //
//  Version: 0.1                                                         //
// Library for a Microchip 24LC256 Serial EEPROM,  32768 int8  memory  ////
// init_ext_eeprom();    Call before the other functions are used      ////
// write_ext_eeprom(a,d);  Write the int8 d to the address a           ////
// d = read_ext_eeprom(a);  Read the int8 d from the address a         ////
// multi_write_ext_eeprom(a,char *d,size);//can cross page/chip boundary////
// multi_read_ext_eeprom(a,char *d,size);//can cross page/chip boundary ////
// The main program may define EEPROM_SDA, EEPROM_SCL to override      ////
// 2^15=32768 address space.  2^3=8   3 bits for 8 chips               ////
// For a total of 18 bits  (using int32)                               ////
//((very similar to my fram driver))
// 8 chips, 32768 BYTES each chip
// start addr's 0,32768,65536,98304,131072,163840,196608,229376
// Page write boundary at 64 bytes
// microchip note: Page write operations are limited to writing
// bytes within a single physical page,
// regardless of the number of bytes actually
// being written. so... don't check the number of bytes written, check if the
// address is on a 64 byte boundary
#ifndef EEPROM_SDA
#define EEPROM_SDA  PIN_C4
#define EEPROM_SCL  PIN_C3
#use I2C(MASTER,SDA=EEPROM_SDA,SCL=EEPROM_SCL,FORCE_HW,FAST=400000,RESTART_WDT)
//#use I2C(MASTER,SDA=EEPROM_SDA,SCL=EEPROM_SCL,FORCE_HW,RESTART_WDT) //start with slow
#define EEPROM_ADDRESS int32
#define EEPROM_PAGE_BDY 64 //can do page write at 64 byte boundrys
#define EEPROM_SIZE    32768
#ifndef EEPROM_CHIPS
#define EEPROM_CHIPS   4
#define EEPROM_MAX_ADDRESS (EEPROM_SIZE*EEPROM_CHIPS)-1 //4 chips 0,1,2,3
//#define hi(x)  (*(&x+1))  //data held at addr of x + 1
#define hi(x)  (*((int8*)&x+1)) //new Ttelmah future proof
#define lo(x)  (*(&x))    //data held at addr of x
//======================init_ext_eeprom===========================//
void init_ext_eeprom(){
  output_float(EEPROM_SCL);
  output_float(EEPROM_SDA);
//======================read_ext_eeprom===========================//
int8 read_ext_eeprom(int32 address) {
  int8 data;
  //  if(address>EEPROM_MAX_ADDRESS)
  //    bit_set(ERRORS,4);
  //    //fprintf(DEBUG,"ERROR address too big!\n\r%lu\n\r",address);
  i2c_start();
  i2c_write((0xA0|(int8)(address>>14))&0xFE);//&0xFE forces to write
  i2c_write(hi(address));
  i2c_write(lo(address));
  i2c_start();
  i2c_write((0xA0|(int8)(address>>14))|1);//|1 forces to read
  data=i2c_read(0);
  i2c_stop();
  return(data);
//======================multi_read_ext_eeprom===========================//
//start addr 0,32768,65536,98304,131072,163840,196608,229376
BOOLEAN multi_read_ext_eeprom(int32 address,char *data,int32 size){
  int1  flag_first_one=TRUE;
  //fprintf(DEBUG,"-mr-");
  for(;size;data++,size--,address++)
    if(address%EEPROM_SIZE==0 || flag_first_one)
      if (flag_first_one) flag_first_one=FALSE;
      //fprintf(DEBUG,"sending slave address=%lu\n\r",address);
      i2c_start();
      i2c_start();
    if((address+1)%EEPROM_SIZE && size!=1)
      *data=i2c_read(1);//The ack will put next data on bus
      //fprintf(DEBUG,"read with ack %lu=%u\n\r",address,*data);
      *data=i2c_read(0);//No ack on last read of chip
      //fprintf(DEBUG,"read without ack %lu=%u\n\r",address,*data);
      //fprintf(DEBUG,"I2c stop\n\r");
      i2c_stop();
  //fprintf(DEBUG,"-mr- done!\n\r");
  return(TRUE);
//======================write_ext_eeprom===========================//
void write_ext_eeprom(int32 address,int8 data)
  int1 status;
  i2c_start();
  i2c_write(data);
  i2c_stop();
  i2c_start();
  status=  i2c_write((0xA0|(int8)(address>>14))&0xFE);//&0xFE forces to write
  while(status==1)
    i2c_start();
  i2c_stop();
//======================multi_write_ext_eeprom===========================//
BOOLEAN multi_write_ext_eeprom(int32 address,char *data,int32 size)
  int1 status, FirstTime=TRUE;
    //fprintf(DEBUG,"a=%lu s=%lu\n\r",address,size);
    if(address%EEPROM_PAGE_BDY==0 || address%EEPROM_SIZE==0 || FirstTime)
    //if(address%EEPROM_SIZE==0 || FirstTime)
      //fprintf(DEBUG,"start %lu\n\r",address);
      if(FirstTime) FirstTime=FALSE;
      i2c_start();
    i2c_write(*data);
    if((address+1)%EEPROM_PAGE_BDY==0 || size-1==0)
      //fprintf(DEBUG,"stop/pg %lu\n\r",address);
      i2c_stop();
      i2c_start();
      while(status==1)
        i2c_start();
      i2c_stop();
  return(TRUE);
BOOLEAN clr_ext_eeprom(int32 address,int32 size,char data)  //fill/clear seep with a given int8
  for(;size;size--,address++)
      i2c_start();
    i2c_write(data);
      //fprintf(DEBUG,"pg %lu\n\r",address);
      i2c_stop();
      i2c_start();
      while(status==1)
        i2c_start();
      i2c_stop();
  return(TRUE);
////======================clr_ext_eeprom===========================//
//BOOLEAN clr_ext_eeprom(int32 address,int32 size,char data)  //fill/clear seep with a given int8
//  int32 start_size;
//  //fprintf(DEBUG,"-c-\n\r");
//  start_size=size;
//  i2c_start();
//  i2c_write((0xA0|(int8)(address>>14))&0xFE);
//  i2c_write(hi(address));
//  i2c_write(lo(address));
//  for(;size;size--,address++){
//    if(address>EEPROM_MAX_ADDRESS){
//    if(address%EEPROM_SIZE==0 && size!=start_size && size!=1){
//      //fprintf(DEBUG,"chip boundary -c- addr=%lu\n\r",address);
//      //reissue I2C for next chip
//      i2c_stop();
//      output_float(EEPROM_SCL);
//      output_float(EEPROM_SDA);
//      i2c_start();
//    i2c_write(data);
//  i2c_stop();
//  return(TRUE);
//=======================eeprom_chksum============================//
int8 eeprom_chksum(int32 address,int32 size)
  int8 chksum=0;
  int32 start_size;
  //fprintf(DEBUG,"-cs-\n\r");
  if(size==0){
    chksum=0;
    return(chksum);
  start_size=size;
  i2c_start();
  i2c_start();
    restart_wdt();
    if(size==1){
      //fprintf(DEBUG,"last addr=%lu\n\r",address);
      chksum+=i2c_read(0);//last read requires no ack
      i2c_stop();
      return(chksum);
    if(address%(EEPROM_SIZE-1)==0 && size!=start_size)
      //fprintf(DEBUG,"chip boundary addr=%lu\n\r",address);
      i2c_stop();
      //fprintf(DEBUG,"-cs-noack-%lu=%u\n\r",address,chksum);
      size--;address++;
      i2c_start();
      i2c_start();
    chksum+=i2c_read(1);//The ack will put next data on bus
    //fprintf(DEBUG,"-cs-%lu=%u\n\r",address,chksum);
  //fprintf(DEBUG,"wrong exit\n\r");
Little test program, change array size to bigger than 64 and address
to cross chips ect..
//05/14/2009 9:54AM Single 24LC256 EEPROM
//05/15/2009 3:39PM multi-read
#define FIRM_MAJOR (int8) 'i'
#define FIRM_MINOR  (int8) 14
#include <18F4525.h>
#fuses hs,nowdt,noprotect,nolvp,put
#use delay(clock=18432000,RESTART_WDT)
#use rs232(baud=19200,xmit=PIN_D7,invert,stream=DEBUG)
#case
#zero_ram
#define HARD_MAJOR  (int8) 0
#define HARD_MINOR  (int8) 0 //KPD315
#define BEEP  PIN_C0
#define RELAY PIN_C1
//start addrs 0,32768,65536,98304,(((131072)))
#define AddrVal       125
int8 ERRORS;
#include "Microchip_24LC256.C"
#include <STDLIB.H>
void init(void);
  int8 i,tmp;
  int8 w[10];//1024 byte write array with random data
  int8 r[10];//1024 byte empty array for read data
  int32 addr;//array is written to and read from address
  int32 cnt;//counter for setting up array
  int8 inside_chip;//must loop 32 times the 1024 arrray to fill a chip
  int8 chip_cnt;//must loop 4 times.  Once for each FRAM chip
  init();
  init_ext_eeprom();
  addr=AddrVal;
  for (cnt=0;cnt<sizeof(w);cnt++)w[cnt]=rand();//fill the array with rand data
  multi_write_ext_eeprom(addr,w,sizeof(w));//write the array
  //for(addr=AddrVal,cnt=0;cnt<sizeof(w);cnt++,addr++)write_ext_eeprom(addr,w[cnt]);//write the array
  addr=AddrVal;
  multi_read_ext_eeprom(addr,r,sizeof(r));//read the array
  for (cnt=0;cnt<sizeof(w);cnt++)//check the array
    if(r[cnt]!=w[cnt])
      fprintf(DEBUG,"\w\rr=%03u w=%03u c=%lu\n\r",r[cnt],w[cnt],cnt);
  fprintf(DEBUG,"\n\rDone!\n\r");
