convert int to char
Goto page Previous  1, 2
apcaye
PostPosted: Mon Mar 29, 2010 6:06 am     Reply with quote
I don't know if I understood your question correctly, Simbo, but my suggestion is to call "kbd_getc()" three times to get three digits. Call the macro "toint(c)" on each digit and then do this calculation:
PWM = (First digit*100) + (Second digit*10) + Third digit;
Regards,
Adriano.
Simbo
PostPosted: Wed Mar 31, 2010 2:34 pm     Reply with quote
hi,
Sorry I was a bit vague with my question but I think you get the jist of it!
I think your suggestion should do it.
I'll adapt the code and try it again soon.
Thank you for the reply.
Simbo
<~Simbo~>
PostPosted: Wed Mar 31, 2010 3:37 pm     Reply with quote
Can I suggest a fractionally different approach.
Assuming characters are available, from a buffer, or using getc, something like:
int32 total=0; //start with total=0
int8 chr;
while (isdigit(chr=getc()) { //Get a character - is it a digit?.
   total=mult_with10(total)+(chr-'0'); //if so, multiply total*10,
                                                     //and add the digit value
//total now contains the value typed in....
Multiple key things:
stdlib.h, has a very efficient *10, supporting up to an int32.
All you do, is multiply the total 'so far' by ten, and add in the value of the new digit, stopping when something that is not a digit arrives.
Obviously you can use a smaller type (int8, int16 etc.), but as shown this will handle integers of any normal size, quickly and efficiently.
Page 2 of 2
