Audi80
| Nokia 6100 display with 18F8722 |
Posted: Thu May 07, 2009 6:45 am |
Hi there, i´ve bought two nokia displays to work in the new project i´m developing. And i´ve searched in the net for a good ccs example and found this one:
#include <18F8722.h>
#FUSES INTRC //Crystal Osc (<= 4mhz)
#FUSES PUT //Power Up Timer
#FUSES NOBROWNOUT //Don't Reset when brownout detected
#define LCD_RESET PIN_J6
#define LCD_CS PIN_J7
#define SPI_CLK PIN_C3
#define SPI_DO PIN_C5
#define LED1 PIN_J0
#define LED2 PIN_J1
#bit SSPEN = 0xFC6.5
#include <bmp.h>
// Epson S1D15G10 Command Set
#define DISON 0xaf
#define DISOFF 0xae
#define DISNOR 0xa6
#define DISINV 0xa7
#define SLPIN 0x95
#define SLPOUT 0x94
#define COMSCN 0xbb
#define DISCTL 0xca
#define PASET 0x75 // 00,131
#define CASET 0x15 // 00,131
#define DATCTL 0xbc
#define RGBSET8 0xce
#define RAMWR 0x5c
#define RAMRD 0x5d
#define PTLIN 0xa8
#define PTLOUT 0xa9
#define RMWIN 0xe0
#define RMWOUT 0xee
#define ASCSET 0xaa
#define SCSTART 0xab
#define OSCON 0xd1
#define OSCOFF 0xd2
#define PWRCTR 0x20
#define VOLCTR 0x81
#define VOLUP 0xd6
#define VOLDOWN 0xd7
#define TMPGRD 0x82
#define EPCTIN 0xcd
#define EPCOUT 0xcc
#define EPMWR 0xfc
#define EPMRD 0xfd
#define EPSRRD1 0x7c
#define EPSRRD2 0x7d
#define NOP 0x25
#define ENDPAGE 131
#define ENDCOL 131
//a few basic colors
#define RED 0xE0 // Color Code
#define GREEN 0x1C
#define BLUE 0x03
#define YELLOW 0xFC
#define MAGENTA 0xE3
#define CYAN 0x1F
#define BLACK 0x00
#define WHITE 0xFF
#use fast_io(C)
/* Table Font Size 5x7 Pixel */
const unsigned char font[475] =
0x00 , 0x00 , 0x00 , 0x00 , 0x00 , // Sp
0x00 , 0x06 , 0x5F , 0x06 , 0x00 , // !
0x07 , 0x03 , 0x00 , 0x07 , 0x03 , // ,
0x24 , 0x7E , 0x24 , 0x7E , 0x24 , // #
0x24 , 0x2B , 0x6A , 0x12 , 0x00 , // $
0x63 , 0x13 , 0x08 , 0x64 , 0x63 , // %
0x36 , 0x49 , 0x56 , 0x20 , 0x50 , // &
0x00 , 0x07 , 0x03 , 0x00 , 0x00 , // //
0x00 , 0x3E , 0x41 , 0x00 , 0x00 , // (
0x00 , 0x41 , 0x3E , 0x00 , 0x00 , // )
0x08 , 0x3E , 0x1C , 0x3E , 0x08 , // *
0x08 , 0x08 , 0x3E , 0x08 , 0x08 , // +
0x00 , 0xE0 , 0x60 , 0x00 , 0x00 , // ,
0x08 , 0x08 , 0x08 , 0x08 , 0x08 , // -
0x00 , 0x60 , 0x60 , 0x00 , 0x00 , // .
0x20 , 0x10 , 0x08 , 0x04 , 0x02 , // /
0x3E , 0x51 , 0x49 , 0x45 , 0x3E , // 0
0x00 , 0x42 , 0x7F , 0x40 , 0x00 , // 1
0x62 , 0x51 , 0x49 , 0x49 , 0x46 , // 2
0x22 , 0x49 , 0x49 , 0x49 , 0x36 , // 3
0x18 , 0x14 , 0x12 , 0x7F , 0x10 , // 4
0x2F , 0x49 , 0x49 , 0x49 , 0x31 , // 5
0x3C , 0x4A , 0x49 , 0x49 , 0x30 , // 6
0x01 , 0x71 , 0x09 , 0x05 , 0x03 , // 7
0x36 , 0x49 , 0x49 , 0x49 , 0x36 , // 8
0x06 , 0x49 , 0x49 , 0x29 , 0x1E , // 9
0x00 , 0x6C , 0x6C , 0x00 , 0x00 , // :
0x00 , 0xEC , 0x6C , 0x00 , 0x00 , // ;
0x08 , 0x14 , 0x22 , 0x41 , 0x00 , // <
0x24 , 0x24 , 0x24 , 0x24 , 0x24 , // =
0x00 , 0x41 , 0x22 , 0x14 , 0x08 , // >
0x02 , 0x01 , 0x59 , 0x09 , 0x06 , // ?
0x3E , 0x41 , 0x5D , 0x55 , 0x1E , // @
0x7E , 0x09 , 0x09 , 0x09 , 0x7E , // A
0x7F , 0x49 , 0x49 , 0x49 , 0x36 , // B
0x3E , 0x41 , 0x41 , 0x41 , 0x22 , // C
0x7F , 0x41 , 0x41 , 0x41 , 0x3E , // D
0x7F , 0x49 , 0x49 , 0x49 , 0x41 , // E
0x7F , 0x09 , 0x09 , 0x09 , 0x01 , // F
0x3E , 0x41 , 0x49 , 0x49 , 0x7A , // G
0x7F , 0x08 , 0x08 , 0x08 , 0x7F , // H
0x00 , 0x41 , 0x7F , 0x41 , 0x00 , // I
0x30 , 0x40 , 0x40 , 0x40 , 0x3F , // J
0x7F , 0x08 , 0x14 , 0x22 , 0x41 , // K
0x7F , 0x40 , 0x40 , 0x40 , 0x40 , // L
0x7F , 0x02 , 0x04 , 0x02 , 0x7F , // M
0x7F , 0x02 , 0x04 , 0x08 , 0x7F , // N
0x3E , 0x41 , 0x41 , 0x41 , 0x3E , // O
0x7F , 0x09 , 0x09 , 0x09 , 0x06 , // P
0x3E , 0x41 , 0x51 , 0x21 , 0x5E , // Q
0x7F , 0x09 , 0x09 , 0x19 , 0x66 , // R
0x26 , 0x49 , 0x49 , 0x49 , 0x32 , // S
0x01 , 0x01 , 0x7F , 0x01 , 0x01 , // T
0x3F , 0x40 , 0x40 , 0x40 , 0x3F , // U
0x1F , 0x20 , 0x40 , 0x20 , 0x1F , // V
0x3F , 0x40 , 0x3C , 0x40 , 0x3F , // W
0x63 , 0x14 , 0x08 , 0x14 , 0x63 , // X
0x07 , 0x08 , 0x70 , 0x08 , 0x07 , // Y
0x71 , 0x49 , 0x45 , 0x43 , 0x00 , // Z
0x00 , 0x7F , 0x41 , 0x41 , 0x00 , // [
0x02 , 0x04 , 0x08 , 0x10 , 0x20 , // Back slash
0x00 , 0x41 , 0x41 , 0x7F , 0x00 , // ]
0x04 , 0x02 , 0x01 , 0x02 , 0x04 , // ^
0x80 , 0x80 , 0x80 , 0x80 , 0x80 , // _
0x00 , 0x03 , 0x07 , 0x00 , 0x00 , // `
0x20 , 0x54 , 0x54 , 0x54 , 0x78 , // a
0x7F , 0x44 , 0x44 , 0x44 , 0x38 , // b
0x38 , 0x44 , 0x44 , 0x44 , 0x28 , // c
0x38 , 0x44 , 0x44 , 0x44 , 0x7F , // d
0x38 , 0x54 , 0x54 , 0x54 , 0x18 , // e
0x08 , 0x7E , 0x09 , 0x09 , 0x00 , // f
0x18 , 0xA4 , 0xA4 , 0xA4 , 0x7C , // g
0x7F , 0x04 , 0x04 , 0x78 , 0x00 , // h
0x00 , 0x00 , 0x7D , 0x00 , 0x00 , // i
0x40 , 0x80 , 0x84 , 0x7D , 0x00 , // j
0x7F , 0x10 , 0x28 , 0x44 , 0x00 , // k
0x00 , 0x00 , 0x7F , 0x40 , 0x00 , // l
0x7C , 0x04 , 0x18 , 0x04 , 0x78 , // m
0x7C , 0x04 , 0x04 , 0x78 , 0x00 , // n
0x38 , 0x44 , 0x44 , 0x44 , 0x38 , // o
0xFC , 0x44 , 0x44 , 0x44 , 0x38 , // p
0x38 , 0x44 , 0x44 , 0x44 , 0xFC , // q
0x44 , 0x78 , 0x44 , 0x04 , 0x08 , // r
0x08 , 0x54 , 0x54 , 0x54 , 0x20 , // s
0x04 , 0x3E , 0x44 , 0x24 , 0x00 , // t
0x3C , 0x40 , 0x20 , 0x7C , 0x00 , // u
0x1C , 0x20 , 0x40 , 0x20 , 0x1C , // v
0x3C , 0x60 , 0x30 , 0x60 , 0x3C , // w
0x6C , 0x10 , 0x10 , 0x6C , 0x00 , // x
0x9C , 0xA0 , 0x60 , 0x3C , 0x00 , // y
0x64 , 0x54 , 0x54 , 0x4C , 0x00 , // z
0x08 , 0x3E , 0x41 , 0x41 , 0x00 , // {
0x00 , 0x00 , 0x7F , 0x00 , 0x00 , // |
0x00 , 0x41 , 0x41 , 0x3E , 0x08 , // }
0x02 , 0x01 , 0x02 , 0x01 , 0x00 // ~
void pset(unsigned char color, unsigned char x, unsigned char y);
void spi_command(int);
void spi_data(int);
void LCD_Set_Box(unsigned char x1, unsigned char y1, unsigned char x2, unsigned char y2);
void LCD_Fill_Screen(unsigned char color,unsigned char x1, unsigned char y1,unsigned char x2,unsigned char y2);
void LCD_Initial(void);
void Draw_Color_Bar(void);
void LCDWrite130x130bmp(void);
void LCD_Print_Char(unsigned char fcolor, unsigned char bcolor, unsigned char x, unsigned char y,char c);
void LCD_Print_String(unsigned char fcolor,unsigned char bcolor, unsigned char x, unsigned char y,char *text);
int aux = 0;
int16 i,index;
char String_Buff[30]; // String Array Buffer
setup_oscillator(OSC_4MHZ);
setup_adc_ports(NO_ANALOGS);
setup_adc(ADC_OFF);
setup_spi(SPI_MASTER|SPI_L_TO_H|SPI_XMIT_L_TO_H|SPI_CLK_DIV_4);
// setup_spi(SPI_MASTER|SPI_L_TO_H|SPI_XMIT_L_TO_H);
setup_timer_1(T1_DISABLED);
setup_timer_2(T2_DISABLED, 0, 1);
set_tris_c(0x00); // all outputs, can change to mask only hardware SPI bits if needed
set_tris_j(0x00);
/*Just to be sure that the pic is running*/
while(aux++<50){
output_high(LED1);
output_low(LED2);
delay_ms(50);
output_low(LED1);
output_high(LED2);
delay_ms(50);
LCD_Initial();
Draw_Color_Bar();
delay_ms(2000);
LCD_Fill_Screen(RED,0,0,131,131);
LCD_Fill_Screen(GREEN,0,0,131,131);
LCD_Fill_Screen(BLUE,0,0,131,131);
LCD_Fill_Screen(YELLOW,0,0,131,131);
LCD_Fill_Screen(MAGENTA,0,0,131,131);
LCD_Fill_Screen(CYAN,0,0,131,131);
LCD_Fill_Screen(BLACK,0,0,131,131);
LCDWrite130x130bmp();
delay_ms(2000);
spi_command(DATCTL); // datctl
spi_data(0x00);
spi_data(0);
spi_data(0x01);
spi_data(0);
LCD_Fill_Screen(BLACK,0,0,131,131); // Fill Screen with Black Color
sprintf(String_Buff," TEST ET-LCD6610 ");
LCD_Print_String(YELLOW, BLACK, 7, 5,String_Buff);
sprintf(String_Buff," WWW.ETTEAM.COM ");
LCD_Print_String(CYAN, BLACK, 7, 15,String_Buff);
sprintf(String_Buff," TEST RED COLOR ");
LCD_Print_String(RED, BLACK, 7, 30,String_Buff);
sprintf(String_Buff," TEST GREEN COLOR ");
LCD_Print_String(GREEN, BLACK, 7, 45,String_Buff);
sprintf(String_Buff," TEST BLUE COLOR ");
LCD_Print_String(BLUE, BLACK, 7, 60,String_Buff);
sprintf(String_Buff," TEST WHITE COLOR ");
LCD_Print_String(WHITE, BLACK, 7, 75,String_Buff);
sprintf(String_Buff," TEST MAGENTA COLOR ");
LCD_Print_String(MAGENTA, BLACK, 7, 90,String_Buff);
sprintf(String_Buff," TEST CYAN COLOR ");
LCD_Print_String(CYAN, BLACK, 7, 105,String_Buff);
sprintf(String_Buff," TEST YELLOW COLOR ");
LCD_Print_String(YELLOW, BLACK, 7, 120,String_Buff);
delay_ms(5000);
void pset(unsigned char color, unsigned char x, unsigned char y){
// sets the starting page(row) and column (x & y) coordinates in ram,
// then writes the colour to display memory. The ending x & y are left
// maxed out so one can continue sending colour data bytes to the 'open'
// RAMWR command to fill further memory. issuing any other command
// finishes RAMWR.
x += 2; // for some reason starts at 2
spi_command(PASET); // page start/end ram
spi_data(x);
spi_data(ENDPAGE);
spi_command(CASET); // column start/end ram
spi_data(y);
spi_data(ENDCOL);
spi_command(RAMWR); // write
spi_data(color);
void spi_command(int dat){
output_low(LCD_CS); // enable chip
SSPEN = 0; // shut off hardware SPI allowing direct access to SPI in/out pins
output_low (SPI_DO); // output low on data out (9th bit low = command)
output_high (SPI_CLK);
delay_cycles(1); // send clock pulse
output_low (SPI_CLK);
SSPEN=1; // turn hardware SPI back on
spi_write(dat); // make PIC do the work for the command byte
output_high(LCD_CS); // disable
void spi_data(int dat){
SSPEN = 0; // turn off hardware SPI allowing us direct access to SPI in/out pins
output_high (SPI_DO); // output high on data out (9th bit high = data)
spi_write(dat); // make PIC do the work for the data byte
/* Initial LCD-NOKIA6610 */
// reset display
output_high (LCD_CS);
output_low (LCD_RESET);
output_high (LCD_RESET);
//init'd, now drop CS to send commands/data and raise when finished
spi_command(DISCTL); // display control
spi_data(0x0C); // 12 = 1100 - CL dividing ratio [don't divide] switching period 8H (default)
spi_data(0x20); // 32 = (128/4)-1 (round up) number of display lines for scanning
spi_data(0x0C); // 12 = 1100 - number of lines to be inversely highlighted
spi_data(0x00);
spi_command(COMSCN); // common scanning direction
spi_data(0x01);
// 0 0 0 = 1 -> 80 81 -> 160
// 0 0 1 = 1 -> 80 81 <- 160
// 0 1 0 = 1 <- 80 81 -> 160
// 0 1 1 = 1 <- 80 81 <- 160
spi_command(OSCON); // internal oscialltor ON
spi_command(SLPOUT); // sleep out
spi_command(VOLCTR); // electronic volume, this is the contrast/brightness
spi_data(0x23); // volume (contrast) setting - fine tuning
spi_data(0x03); // internal resistor ratio - coarse adjustment
spi_command(PWRCTR); // power ctrl
spi_data(0x0f); //everything on, no external reference resistors
spi_command(DISINV); // invert display mode
spi_command(DATCTL); // data control
spi_data(0x00); // normal display of page/column address, page scan direction
spi_data(0x00); // normal RGB arrangement
spi_data(0x01); // 8-bit grayscale
spi_command(RGBSET8); // setup 8-bit color lookup table [RRRGGGBB]
//RED
spi_data(0);
spi_data(2);
spi_data(4);
spi_data(6);
spi_data(8);
spi_data(10);
spi_data(12);
spi_data(15);
// GREEN
spi_data(0);
spi_data(2);
spi_data(4);
spi_data(6);
spi_data(8);
spi_data(10);
spi_data(12);
spi_data(15);
//BLUE
spi_data(0);
spi_data(4);
spi_data(9);
spi_data(15);
spi_command(NOP); // nop
LCD_Fill_Screen(WHITE,0,0,131,131);
spi_command(DISON); // Display On
/* (x1,y1) */
/* (x2,y2) */
unsigned char y1,
unsigned char x2,
unsigned char y2)
spi_command(CASET); // Page Start/Eend ram
spi_data(x1);
spi_data(x2);
spi_command(PASET); // Column Start/End ram
spi_data(y1);
spi_data(y2);
/* Fill Screen With Color */
unsigned char x1,
unsigned char y1,
unsigned char x2,
unsigned char y2)
unsigned int16 j;
unsigned int16 total_bytes1;
unsigned int16 total_bytes2;
unsigned int16 total_bytes;
LCD_Set_Box(x1, y1, x2, y2);
spi_command(RAMWR);
total_bytes1 = (x2 - x1 + 1);
total_bytes2 = (y2 - y1 + 1);
total_bytes = total_bytes1 * total_bytes2;
for (j = 0; j < total_bytes; j++)
spi_data(color);
/* Create 4-Bar Color */
LCD_Fill_Screen(RED,0,0,131,33);
LCD_Fill_Screen(GREEN,0,34,131,66);
LCD_Fill_Screen(BLUE,0,67,131,99);
LCD_Fill_Screen(WHITE,0,100,131,131);
unsigned int16 j; // loop counter
// Data control (need to set "normal" page address for Olimex photograph)
spi_data(0x00); // P1: 0x00 = page address normal, column address normal, address scan in column direction
spi_data(0x01); // P2: 0x01 = RGB sequence B-> G-> R(Invert Direction)
spi_data(0x02); // P3: 0x02 = Grayscale -> 16
// Display OFF
spi_command(DISOFF);
// Column address set (command 0x2A)
spi_command(CASET);
spi_data(0);
spi_data(131);
// Page address set (command 0x2B)
spi_command(PASET);
spi_data(0);
spi_data(131);
// WRITE MEMORY
spi_command(RAMWR);
// for(j = 0; j < 25740; j++)
for (j=0;j<sizeof(picture);j++)
spi_data(picture[j]);
// Data control (return to "inverted" page address)
spi_data(0x00); // P1: 0x01 = page address inverted, column address normal, address scan in column direction
spi_data(0x01); // P3: 0x02 = Grayscale -> 16
// Display On
spi_command(DISON);
/* Print Char on Screen */
unsigned char x,
unsigned int i;
LCD_Set_Box(x,y,x,y+7);
spi_command(RAMWR);
for(i=0;i<8;i++)
if (1<<i & c)
spi_data(fcolor);
spi_data(bcolor);
/* Print String on Screen */
unsigned char x,
unsigned char c;
unsigned char t;
unsigned int16 i;
unsigned int16 j;
while(*text != 0)
t = *text;
i = t - 32;
i = i * 5;
for(j = i; j < i+5; j++)
c = font[j];
LCD_Print_Char(fcolor, bcolor, x++, y, c);
LCD_Print_Char(fcolor, bcolor, x++, y, 0);
text++;
Im using a PIC18F8722 my problem is that the only thing i can see the display doing is changing its color from blue to white nothing else happens, when i was searching in the www i´ve found that this display may have two controllers one from epson and another from phillips and the diference is in the back PCB that changes (Green for Philips and Brown for epson) and i have both of them, is there any problem in this routines?? Thanks |
