Problem on revise function to operate many commands once
Wing
PostPosted: Thu Jan 14, 2010 1:47 pm     Reply with quote
void receive_packet()
   int8 pn, pos, checksum, num_bytes, save_bytes;
   num_bytes=read_usb();//get the number of bytes
   buffer[0]=num_bytes;
   save_bytes = num_bytes;//save a copy
   pos=1;
   while(num_bytes--)
      buffer[pos++]=read_usb();
   checksum=0;
   for(pn=0; pn<save_bytes+1; pn++)
      checksum ^= (int8)buffer[pn];
   if(read_usb() == checksum)//if checksums match
      delay_us(100);
      if(input(RXF)==0)//if more data in FIFO
         delay_ms(5);//still have data in the FIFO but not exceed 100 bytes, read out. Or error!
                        while(input(RXF)==0)//clear the FIFO
                                 delay_ms(5);
                                 read_usb();
                                 send(0xAb);//error!
                                 packet_ready=0;
                       for(num_bytes=0; num_bytes++; num_bytes=60000)
                            if(num_bytes<=100)
                                      send(0x55);//no error
                                      delay_us(100);
                                      packet_ready=1;
else//checksum failed
      send(0xaa);//error!
      packet_ready=0;
   strobe_SND();//send now
I have a problem of writing the function 'receive_packet'. This function can only operate one command (several lines) at once. But as I want it to read many commands and operate once, I tried to revise the code. After compiling, no results came out, either the only one command. The code above is what I revised. Could you help me with this? Thank you very much! The code below is the original code for one command.
      delay_us(100);
         //still have data in the FIFO -- ERROR!
         delay_ms(5);
            delay_ms(5);
            read_usb();
         send(0xAb);//error!
           packet_ready=0;
         delay_us(100);
         packet_ready=1;
      send(0xaa);//error!
      packet_ready=0;
