adalucio
| pic18f2455 oscillator problem |
Posted: Sat May 09, 2009 4:35 am |
Hi all
I have a pic18f2455, a 20mhz crystal, two 15pF capacitors.
this is the program
#include "C:\pic\18f2455_led\main.h"
setup_spi(SPI_SS_DISABLED);
setup_wdt(WDT_OFF);
setup_timer_0(RTCC_8_BIT);
setup_timer_1(T1_DISABLED);
setup_vref(FALSE);
output_high(PIN_A0);
delay_ms(1500);
output_low(PIN_A0);
delay_ms(1500);
#include <18F2455.h>
#device adc=8
#FUSES HSPLL //High Speed Crystal/Resonator with PLL enabled
#FUSES BORV20 //Brownout reset at 2.0V
#FUSES PUT //Power Up Timer
#FUSES LVP //Low Voltage Programming on B3(PIC16) or B5(PIC18)
#FUSES PBADEN //PORTB pins are configured as analog input channels on RESET
#FUSES LPT1OSC //Timer1 configured for low-power operation
#FUSES XINST //Extended set extension and Indexed Addressing mode enabled
#FUSES PLL5 //Divide By 5(20MHz oscillator input)
#FUSES USBDIV //USB clock source comes from PLL divide by 2
#FUSES CPUDIV1 //System Clock /1
#FUSES VREGEN //USB voltage regulator enabled
led should blink every 1500, but it doesn't. it blink very fast.
(this is a test program, the next step is adding usb full speed support, so the configuration must work also for the usb)
what is the problem?
sorry for my english
bungee-
Posted: Sat May 09, 2009 5:47 am |
Here is your problem.
Your clock is not 20MHz but much higher.... with settings like that on PIC18F4550 clock would be 48MHz  |
adalucio
Posted: Sat May 09, 2009 6:52 am |
so I have to write
#use delay(clock=48000000)
is it ok? |
adalucio
Posted: Sat May 09, 2009 6:58 am |
| adalucio wrote: | so I have to write
is it ok? |
I tried it. it doesn't work, led blink very fast  |
adalucio
Posted: Sat May 09, 2009 7:06 am |
adalucio
Posted: Sat May 09, 2009 7:18 am |
OMG
now it works
#FUSES BORV43 //Brownout reset at 4.3V
#FUSES CPUDIV1 //System Clock by 1
Big thanks |
Posted: Sat May 09, 2009 7:23 am |
However you won't get much other code to work, till you get rid of the XINST fuse.
CCS, does _not_ use/support XINST.
A really simple program (LED flasher), won't do anything using the extended instructions, but as soon as you try to code anything more complex, the code will stop working....
