RickMarsen
| Problem with PIC18F4685 Bootloader |
Posted: Sat Nov 14, 2009 7:05 pm |
I am trying to use the bootloader functionality for the first time, but I am having little luck with it.
Since I couldn't make heads or tails of the ex_bootloader.c / ex_bootload.c in the "examples" folder, I used the Wizard to create the attached code.
One minor change I made is to place the PIC into bootloader mode when RC0 is HIGH - I have a PB switch on my board that is pulls RC0 high when pressed (otherwise C0 is low via a 10K resistor)
The problem I'm having is that when I run the code below, the PIC either freezes, or I get a message from SIOW - "Timeout while downloading".
I looked through the forums for similar posts and found only one but the solution turned out to be replacing a bad MAX232 IC - my MAX232 was thoroughly tested in both directions and works fine.
If I comment out the
#include "C:\boot_test\boot_test_bootloader.h"
the PIC starts up OK.
Commenting out
//real_load_program();
does not prevent PIC freezing
I am using a PIC18F4685
with PCH 4.083
Running at 5Vdc at 40MHz (Via external oscillator)
boot_test.c (Main File)
#include "C:\boot_test\boot_test.h"
//BOOTLOADER AT START - Include Bootloader.h in your application - See sample application Ex_Bootload.c
//BOOTLOADER AT END - Always include the projectname_bootloader.h file in future versions of the project
// NOTE - User must include PROJECTNAME_bootloader.C in his final Application program
{// Enter Bootloader if Pin B5 is low after a RESET
if(input(PIN_C0))
setup_psp(PSP_DISABLED);
setup_spi(SPI_SS_DISABLED);
setup_wdt(WDT_OFF);
setup_timer_0(RTCC_INTERNAL);
setup_timer_1(T1_DISABLED);
setup_vref(FALSE);
//Setup_Oscillator parameter not selected from Intr Oscillator Config tab
output_high(PIN_B4); //LED ON
delay_ms(50);
output_high(PIN_B4); //LED OFF
delay_ms(50);
// TODO: USER CODE!!
boot_test.h
#include <18F4685.h>
#device adc=8
#FUSES HS //High speed Osc (> 4mhz for PCM/PCH) (>10mhz for PCD)
#FUSES BORV20 //Brownout reset at 2.0V
#FUSES PBADEN //PORTB pins are configured as analog input channels on RESET
#FUSES BBSIZ4K //4K words Boot Block size
#use delay(clock=40000000)
//bootloader code
// APPLICATION_ISR_VECTOR - Where the compiler is going to put the ISR
#define FIRMWARE_UPGRADE_VECTOR 0 // Bootloader at Start of memory
#define MAX_UPGRADE_AREA (0x500) // Space required by bootloader
#define MIN_FIRMWARE_UPGRADE_MEMORY_AREA (0x20) // Start of bootloder code
#define MAX_FIRMWARE_UPGRADE_MEMORY_AREA (MAX_UPGRADE_AREA-1) // End of bootloder code
#define APPLICATION_RESET_VECTOR 0x500 // New RESET Vector
#define APPLICATION_ISR_VECTOR 0x508 // New Interrupt Vector
// Re-vectored RESET vector from 0x0000 to 0x0500
// Re-vectored Interrupt vector from 0x0008 to 0x0508
#build(reset=APPLICATION_RESET_VECTOR, interrupt=APPLICATION_ISR_VECTOR)
#define LOADER_END MAX_UPGRADE_AREA -1
#define LOADER_ADDR MIN_FIRMWARE_UPGRADE_MEMORY_AREA
#define BUFFER_LEN_LOD 64
int buffidx;
char buffer[BUFFER_LEN_LOD];
#define ACKLOD 0x06
#define XON 0x11
#define XOFF 0x13
#SEPARATE
unsigned int atoi_b16(char *s);
#ORG LOADER_ADDR+10, LOADER_END auto=0 default
void real_load_program (void)
int1 do_ACKLOD, done=FALSE;
int8 checksum, line_type;
int16 l_addr,h_addr=0;
int32 addr;
#if getenv("FLASH_ERASE_SIZE")>2
int32 next_addr;
int8 dataidx, i, count;
int8 data[32];
while (!done) // Loop until the entire program is downloaded
buffidx = 0; // Read into the buffer until 0x0D ('\r') is received or the buffer is full
do {
buffer[buffidx] = getc();
} while ( (buffer[buffidx++] != 0x0D) && (buffidx <= BUFFER_LEN_LOD) );
putchar (XOFF); // Suspend sender
do_ACKLOD = TRUE;
// Only process data blocks that start with ':'
if (buffer[0] == ':') {
count = atoi_b16 (&buffer[1]); // Get the number of bytes from the buffer
// Get the lower 16 bits of address
l_addr = make16(atoi_b16(&buffer[3]),atoi_b16(&buffer[5]));
line_type = atoi_b16 (&buffer[7]);
addr = make32(h_addr,l_addr);
#if defined(__PCM__) // PIC16 uses word addresses
addr /= 2;
// If the line type is 1, then data is done being sent
if (line_type == 1) {
done = TRUE;
} else if ((addr < LOADER_ADDR || addr > LOADER_END) && addr < 0x2000){
#elif defined(__PCH__)
} else if ((addr < LOADER_ADDR || addr > LOADER_END) && addr < 0x300000){
checksum = 0; // Sum the bytes to find the check sum value
for (i=1; i<(buffidx-3); i+=2)
checksum += atoi_b16 (&buffer[i]);
checksum = 0xFF - checksum + 1;
if (checksum != atoi_b16 (&buffer[buffidx-3]))
do_ACKLOD = FALSE;
else {
if (line_type == 0) {
// Loops through all of the data and stores it in data
// The last 2 bytes are the check sum, hence buffidx-3
for (i = 9,dataidx=0; i < buffidx-3; i += 2)
data[dataidx++]=atoi_b16(&buffer[i]);
#if getenv("FLASH_ERASE_SIZE") > getenv("FLASH_WRITE_SIZE")
if ((addr!=next_addr)&&(addr&(getenv("FLASH_ERASE_SIZE")-1)!=0))
#else
if ((addr!=next_addr)&&(addr&(getenv("FLASH_ERASE_SIZE")/2-1)!=0))
erase_program_eeprom(addr);
next_addr = addr + 1;
write_program_memory(addr, data, count);
else if (line_type == 4)
h_addr = make16(atoi_b16(&buffer[9]), atoi_b16(&buffer[11]));
if (do_ACKLOD)
putchar (ACKLOD);
putchar(XON);
putchar (ACKLOD);
putchar(XON);
#ifndef _bootloader
reset_cpu();
unsigned int atoi_b16(char *s) { // Convert two hex characters to a int8
unsigned int result = 0;
int i;
for (i=0; i<2; i++,s++) {
if (*s >= 'A')
result = 16*result + (*s) - 'A' + 10;
result = 16*result + (*s) - '0';
return(result);
