LCD Driver fix for Optrex 4x20 C-51847NFJ-SLW-ADN
Stuckeymax
PostPosted: Tue Apr 28, 2009 8:31 pm     Reply with quote
////                             LCD.C                                ////
////                 Driver for common LCD modules                     ////
////  lcd_init()   Must be called before any other function.           ////
////  lcd_putc(c)  Will display c on the next position of the LCD.     ////
////                     The following have special meaning:           ////
////                      \f  Clear display                            ////
////                      \n  Go to start of second line               ////
////                      \b  Move back one position                   ////
////  lcd_gotoxy(x,y) Set write position on LCD (upper left is 1,1)    ////
////  lcd_getc(x,y)   Returns character at position x,y on LCD         ////
////  Note repair 100 uS delay added Line 190                          ////
////        (C) Copyright 1996,2003 Custom Computer Services           ////
//// This source code may only be used by licensed users of the CCS C  ////
//// compiler.  This source code may only be distributed to other      ////
//// licensed users of the CCS C compiler.  No other use, reproduction ////
//// or distribution is permitted without written permission.          ////
//// Derivative programs created using this software in object code    ////
//// form are not restricted in any way.                               ////
//// CCS lcd_init modified by SMc to correct LCD startup problems      ////
//// with an Optrex C-51847NFJ-SLW-ADN 4x20 Transreflective Display    ////
//// DK P/N 73-1249-ND     100 uS delay inserted Line 193              ////
#ifndef __LCD_C__
#define __LCD_C__
#ifndef LCD_TYPE
   #define LCD_TYPE 2           // 0=5x7, 1=5x10, 2=2 or 4 lines
#define LCD_DELAY_CYCLES   3
#define NUM_COLS 20
//#if NUM_COLS==20
 //these maps are for 4x20
 const int8 lcd_line_off[] = {0x80, 0xc0, 0x94, 0xd4};
//#elif NUM_COLS==16
 //these maps are for 4x16
// const int8 lcd_line_off[] = {0x80, 0xc0, 0x90, 0xd0};
//#endif
#define NUM_LINES (sizeof(lcd_line_off)/sizeof(int8))
int8 g_LCDCurrX, g_LCDCurrY;
int8 const LCD_INIT_STRING[4] = {0x20 | (LCD_TYPE << 2), 0xc, 1, 6};
                             // These bytes need to be sent to the LCD
                             // to start it up.
// use the following block if pins are on one port
typedef struct
   int1 enable;
   int1 rs;
   int1 rw;
   int1 blank;
   int8 dataPort:4;
} LCDPinout;
LCDPinout g_LCDLAT, g_LCDPORT, g_LCDTRIS;
#locate g_LCDLAT=getenv("SFR:LATD")
#locate g_LCDPORT=getenv("SFR:PORTD")
#locate g_LCDTRIS=getenv("SFR:TRISD")
#define lcd_data_set(d)       g_LCDLAT.dataPort = d
#define lcd_data_get()        (g_LCDPORT.dataPort)
#define lcd_tris_read()       g_LCDTRIS.dataPort = 0xF
#define lcd_tris_write()      g_LCDTRIS.dataPort = 0
#define lcd_tris_init()       g_LCDTRIS = 0x08
#define lcd_output_enable(x)  g_LCDLAT.enable = x
#define lcd_output_rs(x)      g_LCDLAT.rs = x
#define lcd_output_rw(x)      g_LCDLAT.rw = x
// use the following block if pins are all over the place
#define lcd_output_enable(x) output_bit(LCD_ENABLE_PIN, x)
#define lcd_output_rs(x) output_bit(LCD_RS_PIN, x)
#define lcd_output_rw(x) output_bit(LCD_RW_PIN, x)
void lcd_data_set(int8 data)
   output_bit(LCD_D4_PIN, bit_test(data,0));
   output_bit(LCD_D5_PIN, bit_test(data,1));
   output_bit(LCD_D6_PIN, bit_test(data,2));
   output_bit(LCD_D7_PIN, bit_test(data,3));
int8 lcd_data_get(void)
   int8 ret=0;
   if (input(LCD_D4_PIN))  bit_set(ret,0);
   if (input(LCD_D5_PIN))  bit_set(ret,1);
   if (input(LCD_D6_PIN))  bit_set(ret,2);
   if (input(LCD_D7_PIN))  bit_set(ret,3);
   return(ret);
void lcd_tris_read(void)
   output_float(LCD_D4_PIN);
   output_float(LCD_D5_PIN);
   output_float(LCD_D6_PIN);
   output_float(LCD_D7_PIN);
void lcd_tris_write(void)
   output_drive(LCD_D4_PIN);
   output_drive(LCD_D5_PIN);
   output_drive(LCD_D6_PIN);
   output_drive(LCD_D7_PIN);
void lcd_tris_init(void)
    output_drive(LCD_ENABLE_PIN);
    output_drive(LCD_RS_PIN);
    output_drive(LCD_RW_PIN);
int8 lcd_read_byte(void)
      int8 low,high;
      lcd_tris_read();
      lcd_output_rw(1);
      delay_cycles(LCD_DELAY_CYCLES);
      lcd_output_enable(1);
      high = lcd_data_get();
      lcd_output_enable(0);
      delay_us(1);
      low = lcd_data_get();
      lcd_tris_write();
      return( (high<<4) | low);
void lcd_send_nibble( int8 n )
      lcd_data_set(n);
      delay_us(2);
void lcd_send_byte( int8 address, int8 n ) {
      lcd_output_rs(0);
      while ( bit_test(lcd_read_byte(),7) ) ;
      lcd_output_rs(address);
      lcd_output_rw(0);
      lcd_send_nibble(n >> 4);
      lcd_send_nibble(n & 0xf);
      delay_us(75);
void lcd_init(void)
    int8 i;
    lcd_output_rs(0);
    lcd_output_rw(0);
    lcd_tris_init();
    lcd_tris_write();
    delay_ms(5);
    for(i=1;i<=3;++i) {
       lcd_send_nibble(3);
       delay_ms(5);
    lcd_send_nibble(2);
    delay_us(100);  //Provides a short delay between nibble(2) and init string
                    //to correct LCD startup/cursor positioning problems
    for(i=0;i<=3;++i) {
       lcd_send_byte(0,LCD_INIT_STRING[i]);
void lcd_gotoxy(int8 x, int8 y)
  int8 address;
  // set new cursor position
  g_LCDCurrX = x % NUM_COLS;
  g_LCDCurrY = y % NUM_LINES;
  // wrap the y position by number of lines
  address = lcd_line_off[g_LCDCurrY];
  address += g_LCDCurrX;
  lcd_send_byte(0, address);
void lcd_gotoxy(int8 xy)
   int8 address;
   g_LCDCurrX = xy % NUM_COLS;
   g_LCDCurrY = xy / NUM_COLS;
void lcd_putc( char c)
   switch (c) {
     case '\f'   : lcd_send_byte(0,1);
                   delay_ms(2);
                   lcd_gotoxy(0,0);
     case '\n'   : lcd_gotoxy(g_LCDCurrX, g_LCDCurrY+1);        break;
     case '\r'   : lcd_gotoxy(0, g_LCDCurrY);        break;
     case '\b'   : lcd_send_byte(0,0x10);  break;
     default     : lcd_send_byte(1,c);     break;
void lcd_cursor_off(void) {
        lcd_send_byte(0,0x0C);           //turn LCD cursor OFF
void lcd_cursor_on(void) {
        lcd_send_byte(0,0x0F);           //turn LCD cursor ON
